HUA GOLD Old BY HUA TEAM |
04-08-2015, 07:52 | #1 (permalink) |
No Life Poster Join Date: Jul 2009 Location: India
Member: 1086393 Status: Offline Thanks Meter: 771 | G900H not registered on network(emergency call only) I have one g900H it shows only emergency call. no network. I tried changing IMEI as but asansam software always stuck when repairing IMEI. Need help. |
The Following User Says Thank You to Riteshgpt60 For This Useful Post: |
04-08-2015, 09:46 | #3 (permalink) |
Member: 1086393 Status: Offline Thanks Meter: 771 | I write cert and it shows error Code: Certificate Parameteres Retrived. Writing Certificate Procedure Started. -------------------------------------------------------------------------------------- 1- Turn-on the Phone Goto 'General > About' Tap 7 times on Build Number' 2- Return to General Tab Tap on Developer Options 3- And Check 'Usb Debugging' ON 4- Dial *#0808# in USBSetting Window Select 'DM+MODEM+ADB' 5- Tap on Reboot When Phone Load Complete Connect Usb Cable To Phone 6- (Install All Needed Driver) -------------------------------------------------------------------------------------- Prepairing ...OK Device Found! Reading Phone Informations ... Model : SM-G900H Android Version : 4.4.2 PDA Version : G900HXXU1ANG3 CS Version : G900HODD1ANG1 Phone Version : G900HXXU1ANG3 IMEI : 004999010640000 S/N : 00000000000 Checking Root ...OK Phone Root OK. Continue.. Prepairing... OK Writing Certificate... AT, ASANSAM TEAM, 2014 +MSLSECUR:2,OK OK AT, ASANSAM TEAM, 2014 +AKSEEDNO:1,381-12-5 OK AT, ASANSAM TEAM, 2014 +AKSEEDNO:0,OK OK AT, ASANSAM TEAM, 2014 ERROR Fail Cert Fail(Sign1) |
