HUA GOLD Old BY HUA TEAM |
10-29-2013, 06:06 | #1 (permalink) |
Junior Member Join Date: Nov 2008 Location: Russia, Plesetsk Cosmodrome
Member: 898692 Status: Offline Thanks Meter: 5 | GT-N7100 unfortunately factory test has stopped Fixed via asansam box now Background The number is unknown - it originally came with a missing IMEI. After the firmware has appeared on the default IMEI, then had to get root rights and, accordingly, it has been restored with ASB. Currently, it works, But the Factory Test msg appears each time and I don't have a lock screen and no menu at shutdown. Info attached: Code: ----------------------------------------------------------------------------------------------- Turn-on the Phone Goto 'Settings > Application > Development' And Check 'Usb Debugging' Then Connect Usb Cable To Phone And Install Needed Driver. ----------------------------------------------------------------------------------------------- Prepairing ...OK Device Found! Model : GT-N7100 Manufacturer : samsung Brand : samsung CPU info1 : armeabi-v7a CPU info2 : armeabi Serial No. : 4df75d1f7e93cff7 Baseband Version : NULL GSM Baseband Version : N7100XXDLK7 Bootloader Version : N7100XXDMB2 Build Version : 4.1.2 Country : RU Language : en CID : NULL Build ID : JZO54K Time-Zone : NULL IMEI : NULL IMSI : NULL Root User : se.infra Sales Code : SER Country Code : SER Built Date : Mon Feb 4 09:52:37 KST 2013 ----------------------------------------------------------------------------------------------- Operation Completed Operation Time: 00:00:06 ----------------------------------------------------------------------------------------------- Last edited by dr_moosavi; 10-29-2013 at 16:44. |
10-29-2013, 09:14 | #3 (permalink) |
Member: 898692 Status: Offline Thanks Meter: 5 | Yes, and this operation was carried out too. However, a positive result is not achieved! Log file: Code: ----------------------------------------------------------------------------------------------- Turn-on the Phone Goto 'Settings > Application > Development' And Check 'Usb Debugging' Then Connect Usb Cable To Phone And Install Needed Driver. ----------------------------------------------------------------------------------------------- Prepairing ...OK Device Found! Cleaning... OK OK Repairing... OK OK Setting OwnerShips... OK OK Setting Permissions... OK OK Rebooting... OK! Operation Completed Operation Time: 00:00:13 ----------------------------------------------------------------------------------------------- |
10-29-2013, 12:16 | #9 (permalink) |
Product Manager Join Date: Apr 2013 Location: IRAN Age: 38
Member: 1911891 Status: Offline Thanks Meter: 6,241 | -Use Factoy reset in bypass pattern part on asansam -use wipe in recovery -backup efs folder in root explorer and write good efs on phone |
The Following User Says Thank You to Asansam Box For This Useful Post: |
10-29-2013, 17:09 | #10 (permalink) | |
Member: 898692 Status: Offline Thanks Meter: 5 | Quote:
Special thanks to Mr. Nazhmudin from GSMFORUN.RU for the working EFS. Нere logs: Code: ----------------------------------------------------------------------------------------------- Turn-on the Phone Goto 'Settings > Application > Development' And Check 'Usb Debugging' Then Connect Usb Cable To Phone And Install Needed Driver. ----------------------------------------------------------------------------------------------- Prepairing ...OK Device Found! Model : GT-N7100 Manufacturer : samsung Brand : samsung CPU info1 : armeabi-v7a CPU info2 : armeabi Serial No. : 4df75d1f7e93cff7 Baseband Version : NULL GSM Baseband Version : N7100XXDLK7 Bootloader Version : N7100XXDMB2 Build Version : 4.1.2 Country : GB Language : en CID : NULL Build ID : JZO54K Time-Zone : NULL IMEI : NULL IMSI : NULL Root User : se.infra Sales Code : SER Country Code : SER Built Date : Mon Feb 4 09:52:37 KST 2013 ----------------------------------------------------------------------------------------------- Operation Completed Operation Time: 00:00:08 ----------------------------------------------------------------------------------------------- Note: You Need Maybe try more than one time to doing this. Android Factory Resetting ... Done! Operation Completed Operation Time: 00:00:01 Note: You Need Maybe try more than one time to doing this. Android Factory Resetting ... Done! Operation Completed Operation Time: 00:00:01 ----------------------------------------------------------------------------------------------- Turn-on the Phone Goto 'Settings > Application > Development' And Check 'Usb Debugging' Then Connect Usb Cable To Phone And Install Needed Driver. ----------------------------------------------------------------------------------------------- Prepairing ...OK Device Found! Model : GT-N7100 Writing EFS ... OK EFS Restore Done Phone Reset Done! ----------------------------------------------------------------------------------------------- Operation Completed Operation Time: 00:00:18 ----------------------------------------------------------------------------------------------- ----------------------------------------------------------------------------------------------- Turn-on the Phone Goto 'Settings > Application > Development' And Check 'Usb Debugging' Then Connect Usb Cable To Phone And Install Needed Driver. ----------------------------------------------------------------------------------------------- Prepairing ...OK Device Found! Reading Phone Informations ... Model : GT-N7100 Android Version : 4.1.2 PDA Version : N7100XXDMB2 CS Version : N7100OXEDMC2 Phone Version : N7100XXDLK7 IMEI : NULL Checking Root ...OK Phone Root OK. Continue.. Disabling Security ...Done! Rebooting... OK! Now Remove USB Cable then Insert Micro UART Cable to Phone to Continue.. Delay 40 Seconds... Searching for phone on COM11 ... Phone Found Reading Data from phone... Model : GT-N7100 S/W Version : N7100XXDMB2 Unique ID : CVTF75D1F7E93CF Memory ID : - IMEI : none MSL Addr : 0000000000 Verifying MSL ... OK Bypassing MSL ... OK Writing IMEI ... OK Reset Done! Operation Completed Operation Time: 00:00:58 | |
11-19-2013, 17:16 | #13 (permalink) |
Junior Member Join Date: Nov 2013
Member: 2068685 Status: Offline Thanks Meter: 0 | Please, help me. I have the same problem and I dont understand how to solve it. I have that message Factory tes has stopped and i cant make calls because the phone doesnt recognize my sim and i have a message Not registered on network. |
11-19-2013, 17:35 | #14 (permalink) |
Member: 1911891 Status: Offline Thanks Meter: 6,241 | _EFS_DATA_BACKUP_2013-10-23__19-05-27.rar ? ??????.???? download and write efs via asansam or free command or any other tools |
