Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > HUA Team Products > HUA GOLD Old
HUA GOLD Old BY HUA TEAM
Old 09-05-2013, 11:07   #1 (permalink)
Asansam Box's Avatar
Member: 1911891
Thanks Meter: 6,241
How to repair imei GT-i9500 galaxy s4?
1-Select model
2-Select interface port in select port part
3-Goto general service
4-Insert imei in IMEI1
5-Press repair imei button
6-Remove usb and insert uart cable to phone(step2)
7-Repair successfully
please tested this code after repair for fix network
http://www.youtube.com/watch?v=n8b3FRG-p6U
The Following 7 Users Say Thank You to Asansam Box For This Useful Post:
Old 09-05-2013, 14:08   #2 (permalink)
Member: 1059051
Thanks Meter: 10
imei repair ok but no network register, maybe his luck then me, how to solve repair network problem thx for advance...
The Following 2 Users Say Thank You to gsmtech_tr For This Useful Post:
Old 09-05-2013, 14:50   #3 (permalink)
Member: 1911891
Thanks Meter: 6,241
why use imei repair?i think you phone was no network register before use imei repair?
About Not register on network problem
Before or after change imei
Contact to 100.1587178 if you have this problem and need Fix
Need Asansam orginal box/Root/USB/S7070 uart red cable
The Following User Says Thank You to Asansam Box For This Useful Post:
Old 09-05-2013, 14:55   #4 (permalink)
Member: 1059051
Thanks Meter: 10
i have use asansam dongle... before i dont know but repair imei no network.
Old 09-05-2013, 15:14   #5 (permalink)
riajul1988's Avatar
Member: 1511441
Sonork: 100.1604057
Thanks Meter: 1,162
http://forum.gsmhosting.com/vbb/9602714-post1.html
Asansam Box can solve this problem - if yes guide here step by step for Asansam Box user
The Following User Says Thank You to riajul1988 For This Useful Post:
Old 09-05-2013, 15:39   #6 (permalink)
Member: 1911891
Thanks Meter: 6,241
your phone was not registered and no need use imei repair
contact to me 100.1587178
Old 09-05-2013, 15:46   #7 (permalink)
Member: 1759766
Thanks Meter: 28
http://forum.gsmhosting.com/vbb/f716...m-box-1709841/
Old 09-05-2013, 15:54   #8 (permalink)
Member: 1911891
Thanks Meter: 6,241
yes i can repair this porblem
contact to me for fix(100.1587178)
Old 09-05-2013, 19:56   #9 (permalink)
Member: 72847
Sonork: 100.1614232
Thanks Meter: 16
network problem
he use in the video nother imei but have network this imeii not orginal i9500 or wht mean special imei
Model : GT-I9500
Android Version : 4.2.2
PDA Version : I9500XXUAMDK
CS Version : I9500OJVAMDK
Phone Version : I9500XXUAMDK
IMEI : NULL
Disabling Security ...Done!
Rebooting... OK!
Now Remove USB Cable and Wait Phone Powering Up Completely (Media Scanners Passed) Then insert UART cable to Phone to Continue
Delay 60 Seconds...
Searching for phone on COM13 ... Phone Found
Reading Data from phone...
Model : GT-I9500
S/W Version : I9500XXUAMDK
Unique ID : CV3006704930D30
Memory ID : -
IMEI : none
Verifying MSL ... OK
Bypassing MSL ... OK
Preparing to write Special IMEI.
Generating IMEI... OK
Writing IMEI ... OK
Reset Done!
Operation Completed
Operation Time: 00:01:27
The Following User Says Thank You to arkun20 For This Useful Post:
Old 09-05-2013, 21:07   #10 (permalink)
Member: 1911891
Thanks Meter: 6,241
please note IMEI Policy in each country(same turkey)was diffrent so please check your country rules about IMEI or contact with our supporter about that
Your Location: turkey/istanbul
You are in turkey and cannot use any imei(dont forget IMEI Policy)
solution:
i can fix this problem for you
contact to me on sonork
Old 09-05-2013, 23:26   #11 (permalink)
Member: 15141
Thanks Meter: 30
pls solved fix network problem. I waittt. imei repair ok but no network. pls give fix network code...
video yu ekleyen arkadaşım bizede yardımcı olabilirmisin bu konuda. şimdiden teşekkürler...
Old 09-06-2013, 01:19   #12 (permalink)
Member: 215288
Thanks Meter: 65
Sure, Master. I added the video with friends, TA and can take the adv,, I think your ****ing with us. can take the adv can not solve, so how does the octopus + z3x + spt he'd be lying if I said I was not surprised. I tried doing the network device 10 does not work bro. Link them to my pc, I see they do it. regards to all of you.
Old 09-06-2013, 08:01   #13 (permalink)
Member: 1911891
Thanks Meter: 6,241
no need release any update about fix network
this problem is for your country only
solution for you:
i can fix for you but one phone only(contact to 100.1587178)
why send spam post ?
open eyes and read carefully about 2.3.3 update only
http://forum.gsmhosting.com/vbb/9707600-post1.html
i can fix no network for you but one phone only(contact to 100.1587178)
Old 09-06-2013, 08:35   #14 (permalink)
Member: 718848
Thanks Meter: 3
i do it for mys4.imei repair but no network register. why?
Old 09-06-2013, 08:38   #15 (permalink)
Member: 1911891
Thanks Meter: 6,241
Page generated in 0.21576 seconds with 8 queries
