HUA GOLD Old BY HUA TEAM |
11-16-2014, 08:41 | #1 (permalink) |
Registered User Join Date: Jan 2008 Location: Where never ends.
Member: 669673 Status: Offline Thanks Meter: 301 | How to repair IMEI for I9300 mobile rooted and usb deb. already. mobile IMEI showing 004999....0 Asangsm show this when repair IMEI- Turn-on the Phone Goto 'Settings > Application > Development' And Check 'Usb Debugging' Then Connect Usb Cable To Phone And Install Needed Driver. ----------------------------------------------------------------------------------------------- Prepairing ...OK Device Found! Reading Phone Informations ... Fail Operation Completed Operation Time: 00:00:19 |
11-16-2014, 09:39 | #3 (permalink) |
Member: 669673 Status: Offline Thanks Meter: 301 | Turn-on the Phone Goto 'Settings > Application > Development' And Check 'Usb Debugging' Then Connect Usb Cable To Phone And Install Needed Driver. ----------------------------------------------------------------------------------------------- Prepairing ...OK Device Found! Reading Phone Informations ... Model : GT-I9300 Android Version : 4.1.2 PDA Version : I9300XXEMC2 CS Version : I9300ODDEMC1 Phone Version : I9300DDEMB1 IMEI : NULL Checking Root ...OK Phone Root OK. Continue.. Reading Data From Phone ...OK OK Prepairing Phone ...OK Disabling Security ...Done! Rebooting... OK! Now Remove USB Cable then Insert Micro UART Cable to Phone to Continue.. Delay 40 Seconds... Searching for phone on COM51 ...Fail Operation Completed Operation Time: 00:01:09 |
11-16-2014, 11:33 | #9 (permalink) | |
Member: 669673 Status: Offline Thanks Meter: 301 | Quote:
Turn-on the Phone Goto 'Settings > Application > Development' And Check 'Usb Debugging' Then Connect Usb Cable To Phone And Install Needed Driver. ----------------------------------------------------------------------------------------------- Prepairing ...OK Device Found! Reading Phone Informations ... Model : GT-I9300 Android Version : 4.1.2 PDA Version : I9300XXEMC2 CS Version : I9300ODDEMC1 Phone Version : I9300DDEMB1 IMEI : NULL Checking Root ...OK Phone Root OK. Continue.. Disabling Security ...Done! Rebooting... OK! Now Remove USB Cable then Insert Micro UART Cable to Phone to Continue.. Delay 40 Seconds... Searching for phone on COM52 ...Fail! Phone not found! Operation Completed Operation Time: 00:02:49 is this cable problem or other ? showing this. what should i do ? | |
