Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > HUA Team Products > HSB Box
HSB Box BY HUA TEAM
Old 04-29-2013, 18:50   #1 (permalink)
Asansam Box's Avatar
Member: 1911891
Thanks Meter: 6,150
How to repair N7100 dead boot?
Q:why we need jtag n7100 ?
A:No Power On or NAND Chip replacement.
(You must download repair file and pdf for screen shot)
Index of ./Asansam/N7100 Boot Repair/
The JTAG process is the same of GT-I9300, the differences are only the file to restore, bootloader and the resistor to short.
Pre- requisite
1. One working GT-N7100 (normally booted on)
2. External SD card (recommended Samsung 2GB)
3. JTAG files
You must use the Odin3 v.3.0.7
Put the GT-N7100_Recovery_bootloader.tar in bootloader section
-Using a good working GT-N7100, insert the SD Card and enter into download mode. Connect the device to the PC and click Start button in the Odin. This will copy the bootloader files onto the good working phone.
-After the phone has rebooted, enter into download mode again. This time we will copy the bootloader files from the Phone to the micro SD card (in the good phone). In Odin, ensure to tick T-flash option as below:
-Connect the phone to PC when it is in download mode.
You can see when the bootloader card is copied to the micro SD card, as below.
-You can confirm that the bootloader has been copied to the micro SD card when you see the message SD card is blank or has unsupported files.
Now you can use this micro SD card for all JTAG (on GT-N7100)
How to jtag ?
Insert the memory card (where bootloader was copied) into faulty PBA
Connect the LCD to PBA
Connect the 11 pin Anyway Jig with the Power Off
With Tweezers make short on R319 and power on the jig.
Keep the short for about 6 sec.
Once completed, disconnect the phone from Anyway Jig and proceed to follow the standard repair process
The Following 13 Users Say Thank You to Asansam Box For This Useful Post:
Old 04-29-2013, 19:16   #2 (permalink)
Moderator
...:::SHAMIM:::...'s Avatar
Member: 1676524
Sonork: 100.1608473
Thanks Meter: 1,701
We will try more then 10 phones but phone still binary failed appear.
also tried I9300 but same Result.
is there have any video tutorial?
if has just share with us.
I think i9300 & n7100 Not possible to repair JTAG.
Dont waste Time Just Replace the Emmc it should be work.
Old 04-29-2013, 20:48   #3 (permalink)
Member: 1911891
Thanks Meter: 6,150
please read carefully and step to step(this is samsung company solution and you can find report success for i9300 here via one search)
Old 04-30-2013, 06:40   #4 (permalink)
Member: 1197620
Sonork: 100.1602278
Thanks Meter: 553
team plz donnt mind in my area me charge to custamar jtag charges max 10 usd for 10 usd me pay round about 500 usd because me not have another n7100 it means me not like this solution may be other all people like it
may me not undestand plz reply here
Old 04-30-2013, 07:25   #5 (permalink)
dicle_gsm's Avatar
Member: 539148
Thanks Meter: 2,137
gt-n7100 bootrepair Note 2 same post
Old 04-30-2013, 07:42   #6 (permalink)
Member: 1911891
Thanks Meter: 6,150
i think you are sleep or your eyes is open???
Old 05-02-2013, 11:53   #7 (permalink)
Member: 376471
Sonork: 100.1608095
Thanks Meter: 107
Pre- requisite
3. JTAG files
How to jtag ?
Dear Member...
is there any other way to give power to phone, if we dont have Anyway JIG....
Because when i connet downloader JIG to phone, the phone gets power before shorting the component in I9300...
Old 05-02-2013, 15:01   #8 (permalink)
@matrix@'s Avatar
Member: 362515
Sonork: 100.1590585
Thanks Meter: 153
check this bro.tested by me.. but not in all cases.as u said some of the devices need to replace emmc chip......
Galaxy S3 i9300 successfully unbricked
Old 05-08-2013, 23:38   #9 (permalink)
Member: 389862
Sonork: guy_askali
Thanks Meter: 54
Pre- requisite
3. JTAG files
How to jtag ?
hey bro i tried ur solution buy can't write bootloader files onto the good working phone. always filed any one have success this T-N7100_Recovery_bootloader.tar
pls upload good working file here
Old 05-09-2013, 06:36   #10 (permalink)
Member: 1911891
Thanks Meter: 6,150
very tanx for report
Old 05-10-2013, 19:54   #11 (permalink)
Member: 389862
Sonork: guy_askali
Thanks Meter: 54
did u check is it work or not ?
Old 05-11-2013, 07:49   #12 (permalink)
Member: 1911891
Thanks Meter: 6,150
very tanx to guy_askali for send report
Old 05-13-2013, 07:56   #13 (permalink)
Member: 1911891
Thanks Meter: 6,150
Thanks for the detailed guide!
I would very much like to try it with my N7100 but the problem is that I don't have a good working N7100 here for downloading the bootloader files.
Can anyone upload the files and share with us?
Also, may I know if the bootloader files are universal (the same set of files can be used on N7100 phones with different firmware versions)?
Old 05-15-2013, 17:56   #14 (permalink)
Member: 194907
Thanks Meter: 96
ı same problem ı9300 step to step but not workiing how to 11 pin cable ı dont understand?
The Following User Says Thank You to leventc For This Useful Post:
Old 06-22-2013, 07:47   #15 (permalink)
Member: 23372
Thanks Meter: 18
why always failed cannot flash recovery boot maybe there is another way please share thanks
Page generated in 0.40932 seconds with 7 queries
