HUA GOLD Old BY HUA TEAM |
12-05-2013, 17:04 | #1 (permalink) |
No Life Poster Join Date: Apr 2005 Age: 57
Member: 137980 Status: Offline Thanks Meter: 168 | How to repair network i9500[ANSWERED] Turn-on the Phone Goto 'Settings > Application > Development' And Check 'Usb Debugging' Then Connect Usb Cable To Phone And Install Needed Driver. ----------------------------------------------------------------------------------------------- Prepairing ...OK Device Found! Checking Root ...Fail ----------------------------------------------------------------------------------------------- Turn-on the Phone Goto 'Settings > Application > Development' And Check 'Usb Debugging' Then Connect Usb Cable To Phone And Install Needed Driver. ----------------------------------------------------------------------------------------------- Prepairing ...OK Device Found! Checking Root ...Fail ----------------------------------------------------------------------------------------------- Turn-on the Phone Goto 'Settings > Application > Development' And Check 'Usb Debugging' Then Connect Usb Cable To Phone And Install Needed Driver. ----------------------------------------------------------------------------------------------- Prepairing ...OK Device Found! Root Procedure Started! Uploading ROOTFILE(1) ... OK Prepairing Phone ... OK Uploading ROOTFILE(2) ... OK Uploading ROOTFILE(3) ... OK Preparing Phone ... OK Start Root Exploit ... OK Finalizing ...OK Root Procedure Finished! Operation Completed Operation Time: 00:03:21 ----------------------------------------------------------------------------------------------- ----------------------------------------------------------------------------------------------- Turn-on the Phone Goto 'Settings > Application > Development' And Check 'Usb Debugging' Then Connect Usb Cable To Phone And Install Needed Driver. ----------------------------------------------------------------------------------------------- Prepairing ...OK Device Found! Checking Root ...Fail Last edited by dr_moosavi; 12-07-2013 at 13:46. |
12-05-2013, 17:10 | #2 (permalink) |
No Life Poster Join Date: Jan 2011 Age: 29
Member: 1500648 Status: Offline Thanks Meter: 279 | Step :1 Need to Root Step :2 How to repair no network? -Open asansam -Select model via type -Goto android service -Select repair i9500 no network in misc.job -select usb cable to phone and wait 20 sec(need root) -select interface port in setting -Press do it button -Wait for finish step1 -Connect uart cable to phone now(rj45 s7070) -Wait for finish step2 -done and repaired successfully Last edited by Gsm-Rocky; 12-05-2013 at 17:21. |
12-05-2013, 17:14 | #3 (permalink) | |
Product Manager Join Date: Apr 2013 Location: IRAN Age: 38
Member: 1911891 Status: Offline Thanks Meter: 6,241 | Quote:
your phone is new security and need write kernel on phone or http://forum.gsmhosting.com/vbb/f716...e-box-1725898/ | |
