HUA GOLD Old BY HUA TEAM |
01-01-2015, 17:48 | #1 (permalink) |
Product Manager Join Date: Apr 2013 Location: IRAN Age: 38
Member: 1911891 Status: Offline Thanks Meter: 6,241 | How to unlock s7275R with asansam? download cert file and write on phone = unlocked http://forum.gsmhosting.com/vbb/atta...6&d=1420130633 Last edited by Asansam Box; 01-15-2015 at 22:53. |
01-14-2015, 10:40 | #6 (permalink) |
Freak Poster Join Date: Feb 2008 Location: Street line baby
Member: 695310 Status: Offline Thanks Meter: 144 | use tab s7275b or same model....select s7275R log root For Android 4.x.x and Above: 1- Turn-on the Phone Goto 'General > About' Tap 7 times on Build Number' 2- Return to General Tab Tap on Developer Options 3- And Check 'Usb Debugging' ON Then Connect Usb Cable To Phone -------------------------------------------------------------------------------------- Prepairing ...OK Device Found! Installing FROOT... OK Starting FROOT... OK Now in Framaroot Application doing Following Steps: 1) Select Install SuperSU in Action to execute after root 2) Then select one of following exploit if progress was succseed you will seen Success Result Window if not please select different exploit. 3) Please Doing These Steps below 120 Sec Delay 120 Seconds... Cleaning Environment... OK Root Procedure Complete. same like amazing root. For Android 4.x.x and Above: 1- Turn-on the Phone Goto 'General > About' Tap 7 times on Build Number' 2- Return to General Tab Tap on Developer Options 3- And Check 'Usb Debugging' ON Then Connect Usb Cable To Phone -------------------------------------------------------------------------------------- Prepairing ...OK Device Found! Uploading ROOTFILE 1 ...OK Setting Permission ...OK Uploading ROOTFILE 2 ...OK Uploading ROOTFILE 3 ...OK Uploading ROOTFILE 4 ...OK Installing SU ...OK Running Exploit ...OK Cleaning ...OK Rebooting ...OK but all not root,,failed after restart, Prepairing ...OK Device Found! Reading Phone Informations ... Model : GT-S7275B Android Version : 4.2.2 PDA Version : S7275BUBUANE2 CS Version : S7275BANCANE2 Phone Version : S7275BUBUAND1 IMEI : 351896060165848 S/N : R28F105ZHFR Checking Root ...OK Phone Root Fail. Please Root Your Phone. Operation Time: 00:00:14 ,,cause write cert. need root.... wheres tested root for s7275b 4.2.2 |
01-14-2015, 20:25 | #12 (permalink) |
Member: 695310 Status: Offline Thanks Meter: 144 | not work for s7275b,,,succesfully unlock log...but phone still lock Certificate Parameteres Retrived. Writing Certificate Procedure Started. -------------------------------------------------------------------------------------- 1- Turn-on the Phone Goto 'General > About' Tap 7 times on Build Number' 2- Return to General Tab Tap on Developer Options 3- And Check 'Usb Debugging' ON 4- Dial *#0808# in USBSetting Window Select 'DM+MODEM+ADB' 5- Tap on Reboot When Phone Load Complete Connect Usb Cable To Phone 6- (Install All Needed Driver) -------------------------------------------------------------------------------------- Prepairing ...OK Device Found! Reading Phone Informations ... Model : GT-S7275B Android Version : 4.2.2 PDA Version : S7275BUBUANE2 CS Version : S7275BANCANE2 Phone Version : S7275BUBUAND1 IMEI : 351896060165848 S/N : R28F105ZHFR Checking Root ...OK Phone Root OK. Continue.. Prepairing... OK Writing Certificate... OK Rebooting... OK! Operation Time: 00:00:10 |
01-15-2015, 10:44 | #14 (permalink) |
Freak Poster Join Date: Sep 2005 Location: Bulgaria Age: 37
Member: 182669 Status: Offline Thanks Meter: 87 | Phone DONE! Prepairing ...OK Device Found! Reading Phone Informations ... Model : GT-S7275R Android Version : 4.2.2 PDA Version : S7275RXXUAMJ1 CS Version : S7275RPROAMJ1 Phone Version : S7275RXXUAMJ1 IMEI : 358xxxxxxxxxxxx S/N : R28DC048SFD Checking Root ...OK Phone Root OK. Continue.. Prepairing... OK Writing Certificate... OK Rebooting... OK! |
The Following User Says Thank You to lopotok For This Useful Post: |
