Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > HUA Team Products > HUA GOLD Old
HUA GOLD Old BY HUA TEAM
Old 01-01-2015, 16:48   #1 (permalink)
Asansam Box's Avatar
Member: 1911891
Thanks Meter: 6,238
Cool How to unlock s7275R with asansam?
How to unlock s7275r with asansam?
download cert file and write on phone = unlocked
http://forum.gsmhosting.com/vbb/atta...6&d=1420130633
Old 01-04-2015, 12:11   #2 (permalink)
mubarak2344's Avatar
Member: 2001848
Sonork: 100.1658212
Thanks Meter: 558
dear asansam,,,,
only write cert will unlock it, or we need wipe efs before write cert????
Old 01-04-2015, 13:35   #3 (permalink)
Member: 1911891
Thanks Meter: 6,238
Write cert on phone and then unlocked
Old 01-14-2015, 07:54   #4 (permalink)
adi sukmono's Avatar
Member: 695310
Thanks Meter: 144
what choiice model in tab,use s7275?
Old 01-14-2015, 08:58   #5 (permalink)
Member: 1911891
Thanks Meter: 6,238
you can use all same models(chipset)
The Following User Says Thank You to Asansam Box For This Useful Post:
Old 01-14-2015, 09:40   #6 (permalink)
Member: 695310
Thanks Meter: 144
use tab s7275b or same model....select s7275R
log root
For Android 4.x.x and Above:
1- Turn-on the Phone Goto 'General > About' Tap 7 times on Build Number'
2- Return to General Tab Tap on Developer Options
3- And Check 'Usb Debugging' ON Then Connect Usb Cable To Phone
Prepairing ...OK
Device Found!
Installing FROOT... OK
Starting FROOT... OK
Now in Framaroot Application doing Following Steps:
1) Select Install SuperSU in Action to execute after root
2) Then select one of following exploit if progress was succseed
you will seen Success Result Window if not please select different exploit.
3) Please Doing These Steps below 120 Sec
Delay 120 Seconds...
Cleaning Environment... OK
Root Procedure Complete.
same like amazing root.
Prepairing ...OK
Device Found!
Uploading ROOTFILE 1 ...OK
Setting Permission ...OK
Uploading ROOTFILE 2 ...OK
Uploading ROOTFILE 3 ...OK
Uploading ROOTFILE 4 ...OK
Installing SU ...OK
Running Exploit ...OK
Cleaning ...OK
Rebooting ...OK
but all not root,,failed after restart,
Prepairing ...OK
Device Found!
Reading Phone Informations ...
Model : GT-S7275B
Android Version : 4.2.2
PDA Version : S7275BUBUANE2
CS Version : S7275BANCANE2
Phone Version : S7275BUBUAND1
IMEI : 351896060165848
S/N : R28F105ZHFR
Checking Root ...OK
Phone Root Fail. Please Root Your Phone.
Operation Time: 00:00:14
,,cause write cert. need root....
wheres tested root for s7275b 4.2.2
Old 01-14-2015, 09:54   #7 (permalink)
Member: 695310
Thanks Meter: 144
I cant report its true support or not....
tq
Old 01-14-2015, 10:18   #8 (permalink)
Member: 1911891
Thanks Meter: 6,238
amazing root not supported this model
solution:
You can try with latest versions of VRoot, Kingo Root, Towelroot, or Root Genius Software.
or
read here or here
select s7275r in qcn tools
Old 01-14-2015, 10:47   #9 (permalink)
Member: 695310
Thanks Meter: 144
yes I
did,,,all suggest link,,,and try....still not work/not root...VROOT,GENIU,CMW from xda link,but all not work for s7275B....
Old 01-14-2015, 10:50   #10 (permalink)
Member: 1911891
Thanks Meter: 6,238
you cannot use without root
Old 01-14-2015, 13:33   #11 (permalink)
Member: 2249287
Thanks Meter: 24
you can unlock without cert or lose imie i test it before
Old 01-14-2015, 19:25   #12 (permalink)
Member: 695310
Thanks Meter: 144
not work for s7275b,,,succesfully unlock log...but phone still lock
Certificate Parameteres Retrived.
Writing Certificate Procedure Started.
4- Dial *#0808# in USBSetting Window Select 'DM+MODEM+ADB'
5- Tap on Reboot When Phone Load Complete Connect Usb Cable To Phone
6- (Install All Needed Driver)
Prepairing ...OK
Device Found!
Model : GT-S7275B
S/N : R28F105ZHFR
Checking Root ...OK
Phone Root OK. Continue..
Prepairing... OK
Writing Certificate... OK
Rebooting... OK!
Operation Time: 00:00:10
Old 01-14-2015, 20:51   #13 (permalink)
Member: 1911891
Thanks Meter: 6,238
Contact to me on sonork for wipe efs
Old 01-15-2015, 09:44   #14 (permalink)
Member: 182669
Thanks Meter: 87
Phone DONE!
Prepairing ...OK
Device Found!
Model : GT-S7275R
PDA Version : S7275RXXUAMJ1
CS Version : S7275RPROAMJ1
Phone Version : S7275RXXUAMJ1
IMEI : 358xxxxxxxxxxxx
S/N : R28DC048SFD
Checking Root ...OK
Prepairing... OK
Rebooting... OK!
The Following User Says Thank You to lopotok For This Useful Post:
Old 01-15-2015, 19:04   #15 (permalink)
Member: 695310
Thanks Meter: 144
done by other tools.....................tq team,for care
Page generated in 0.31765 seconds with 7 queries
