HUA GOLD Old BY HUA TEAM |
12-04-2013, 15:21 | #3 (permalink) | |
No Life Poster Join Date: Jan 2011 Age: 29
Member: 1500648 Status: Offline Thanks Meter: 279 | Quote:
Need root Step:2 Manual via UART cable C3300K ------------------------------ Select com port box in software Press *#7284# and select "Modem" (Only show one option interface "UART") *default setting: "PDA" Press *#9090# and select "4 - DM over UART" *default setting: "DM/DUN over HS-USB" Step:3 1. Phone must be powered on. 2. Enable "USB debugging" ("Settings"-"Developer options" for Android 4.0+). 3. Choose correct com-port in Port settings. 4. Connect the phone to PC via micro-USB cable. 5. Press "Unlock" button. 6. When you have "Now connect phone to UART cable ... Checking phone at COM" massage, connect phone to micro-uart cable. Regards Gsm-Rocky | |
12-04-2013, 15:37 | #4 (permalink) |
No Life Poster Join Date: Mar 2008 Location: Pakistan
Member: 718146 Status: Offline Sonork: 100.1619088 Thanks Meter: 118 | Turn-on the Phone Goto 'Settings > Application > Development' And Check 'Usb Debugging' Then Connect Usb Cable To Phone And Install Needed Driver. ----------------------------------------------------------------------------------------------- Prepairing ...OK Device Found! Reading Phone Informations ... Model : GT-I9300 Android Version : 4.0.4 PDA Version : I9300XXBLG1 CS Version : I9300OLBBLF1 Phone Version : I9300DXLF3 IMEI : NULL Checking Root ...OK Phone Root OK. Continue.. Disabling Security ...Done! Rebooting... OK! Now Remove USB Cable then Insert Micro UART Cable to Phone to Continue.. Delay 40 Seconds... Searching for phone on COM10 ... Phone Found Reading Data from phone... Model : GT-I9300 S/W Version : I9300XXBLG1 Unique ID : CVTF1AD7D50ED9F Memory ID : - IMEI : 35479305110672 MSL Addr : RF1CACND0K Verifying MSL ... OK Bypassing MSL ... OK Unlocking ... Fail! Failed to Unlocking(0) Operation Completed Operation Time: 00:01:36 |
12-04-2013, 16:39 | #9 (permalink) |
Member: 718146 Status: Offline Sonork: 100.1619088 Thanks Meter: 118 | my reseller can't give me asansam dongle and cables he gave me only dongle and i don't have other box. Gsm-Rocky had helped me but with ufs DirectCOM we can not done. |
12-04-2013, 16:43 | #11 (permalink) |
Product Manager Join Date: Apr 2013 Location: IRAN Age: 38
Member: 1911891 Status: Offline Thanks Meter: 6,241 | YOU MUST BUY THIS CABLE GSMSP | Z3X BOX UART auto ignition Cable powered by GPGIndustries |
