HUA GOLD Old BY HUA TEAM |
04-26-2012, 22:30 | #1 (permalink) |
No Life Poster Join Date: Feb 2006 Location: In a point from Universe! Age: 40
Member: 235325 Status: Offline Sonork: 100.1593552 Thanks Meter: 523 | I9100 pattern unlock[ANSWERED] Is there any way to remove pattern unlock from i9100 without reset it or flash it? I need the contacts and all other informations from the phone. Thanks! Last edited by dr_moosavi; 05-31-2012 at 10:13. |
05-12-2012, 09:55 | #4 (permalink) | |
Member: 235325 Status: Offline Sonork: 100.1593552 Thanks Meter: 523 | Quote:
I know that is available now; at that time wasn't. I still have this phone but I'm in vacantion now Next week I'll test this on that phone. Regards! | |
05-30-2012, 14:05 | #5 (permalink) |
Junior Member Join Date: May 2012
Member: 1759345 Status: Offline Thanks Meter: 0 | Hi, Did this work? I have: Code: Device Found! Model : GT-I9000 Manufacturer : samsung Brand : samsung CPU info1: : armeabi-v7a CPU info2: : armeabi Serial No. : NULL Baseband Version : NULL GSM Baseband Version : I9000XXJW4 Bootloader Version : unknown Build Version : 2.3.6 Country : GB Language : en CID : NULL Build ID : GINGERBREAD Time-Zone : Europe/London IMEI : NULL IMSI : NULL Root User : se.infra Sales Code : CPW Country Code : CPW Built Date : Mon Mar 19 20:51:30 KST 2012 Code: Prepairing ...OK Device Found! Removing Pattern Lock ... OK Android Pattern Lock Removed. Code: Prepairing ...OK Device Found! Phone Reset Done! Dongle Ver 1.8.0 Please help. |
05-30-2012, 14:40 | #7 (permalink) |
No Life Poster Join Date: Apr 2008 Location: ♥ ♥ ♥ ♥ Age: 35
Member: 748880 Status: Offline Thanks Meter: 1,705 | MR@potatomangoco Turn-on the Phone Goto 'Settings > Application > Development' And Check 'Usb Debugging' Then Connect Usb Cable To Phone And Install Needed Driver. Prepairing ...OK Device Found! Removing Pattern Lock ... OK Android Pattern Lock Removed. i just done one phone Might work with your phone if you didn't produce same this . That's it |
05-30-2012, 16:36 | #8 (permalink) |
Member: 1759345 Status: Offline Thanks Meter: 0 | Thanks for your help, but I have already enabled USB debugging + have drivers installed. As you can see from my logs, I get the same result as you, only mine doesn't acutally carry out the request. My pattern lock is only when I attempt to do factory reset - Not sure if this is different? |
06-04-2012, 00:06 | #10 (permalink) |
Freak Poster Join Date: Mar 2011
Member: 1545317 Status: Offline Sonork: younes Thanks Meter: 32 | same probleme like you my friend im new user for asansam i buy it for this raison "RESET PATTERN LOCK" but in the logs rest pattern is ok and pattern lock not reseted i try many times many times no result and also try it with i new phone rooted but same broblem in the logs is ok and phone pattern not reseted pleeese product manager need your help verssion softwar is Asansam ver 1.8.0 |
06-05-2012, 01:43 | #11 (permalink) | |
Freak Poster Join Date: Jan 2007 Location: DUBAI/UAE
Member: 430770 Status: Offline Sonork: 100.1611576 Thanks Meter: 238 | Quote:
Is the patten is Blocked (too many attempts) ? If yes, then use unblock pattern button If no, then use reset pattern OR Bypass. | |
06-06-2012, 22:47 | #13 (permalink) |
Member: 1545317 Status: Offline Sonork: younes Thanks Meter: 32 | mr asan i read all your post and other poster videos ....i do the same steps like you do If yes, then use unblock pattern button........... nos result If no, then use reset pattern OR Bypass...........nos result ------------------------------------------------------------------------------------------------ Turn-on the Phone Goto 'Settings > Application > Development' And Check 'Usb Debugging' Then Connect Usb Cable To Phone And Install Needed Driver. ------------------------------------------------------------------------------------------------ Prepairing ...OK Device Found! Phone Reset Done! ------------------------------------------------------------------------------------------------ Operation Completed Operation Time: 00:00:04 ------------------------------------------------------------------------------------------------ Turn-on the Phone Goto 'Settings > Application > Development' And Check 'Usb Debugging' Then Connect Usb Cable To Phone And Install Needed Driver. ------------------------------------------------------------------------------------------------ Prepairing ...OK Device Found! Removing Pattern Lock ... OK Android Pattern Lock Removed. ------------------------------------------------------------------------------------------------ Operation Completed Operation Time: 00:00:05 ------------------------------------------------------------------------------------------------ Turn-on the Phone Goto 'Settings > Application > Development' And Check 'Usb Debugging' Then Connect Usb Cable To Phone And Install Needed Driver. ------------------------------------------------------------------------------------------------ Prepairing ...OK Device Found! Searching for Google Account .... OK Analyzing Security...OK Resetting Google Account ...OK Rebooting Device... OK Prepairing Account ... OK Regenerating Account ...OK Rebooting Device... OK Removing Account ...OK Now Remove Battery then Reinsert That and Turn On Device. ------------------------------------------------------------------------------------------------ Operation Completed Operation Time: 00:02:49 ------------------------------------------------------------------------------------------------ Turn-on the Phone Goto 'Settings > Application > Development' And Check 'Usb Debugging' Then Connect Usb Cable To Phone And Install Needed Driver. ------------------------------------------------------------------------------------------------ Prepairing ...OK Device Found! Removing Pattern Lock ... OK Android Pattern Lock Removed. ------------------------------------------------------------------------------------------------ Operation Completed Operation Time: 00:00:05 ------------------------------------------------------------------------------------------------ Turn-on the Phone Goto 'Settings > Application > Development' And Check 'Usb Debugging' Then Connect Usb Cable To Phone And Install Needed Driver. ------------------------------------------------------------------------------------------------ Prepairing ...OK Device Found! Removing User Code ... OK Android User Code Removed. ------------------------------------------------------------------------------------------------ Operation Completed Operation Time: 00:00:05 |
06-09-2012, 22:24 | #15 (permalink) |
Member: 1545317 Status: Offline Sonork: younes Thanks Meter: 32 | the first phone version is 2.3.6 and the second phone is i5800 with 2.1 Version i dont know wath is the probleme MR asan its 2 week ago and i unlock 0 piece with my new dongle if its not support 2.3.6 pleese ad it in next update tnkx br younes |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
FAQ about unlock n0kia | man0n | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 11-29-2010 19:06 |
