Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2005 Age: 46
Member: 137980 Status: Offline Thanks: 1,485
| i9100 repair baseband successfully by green method[REPORT OK] HOW TO REPIAR UB IN I 9100 ?PLEASE WHAT CAN I DO STEP BY STEP I USE 1ST TIME ------------------------------------------------------------------------------------------------ NVM Backed Up and saved in "C:/ASANSAM2/BACKUP/GT-I9100/NULL/NVM" Operation Completed Operation Time: 00:00:07 Last edited by dr_moosavi; 07-09-2012 at 13:37. |
| | #2 (permalink) |
| Turn-on the Phone Goto 'Settings > Application > Development' And Check 'Usb Debugging' Then Connect Usb Cable To Phone And Install Needed Driver. ------------------------------------------------------------------------------------------------ Prepairing ...OK Device Found! Model : GT-I9100 Manufacturer : samsung Brand : samsung CPU info1: : armeabi-v7a CPU info2: : armeabi Serial No. : NULL Baseband Version : NULL GSM Baseband Version : I9100XXKE7 Bootloader Version : unknown Build Version : 2.3.3 Country : US Language : en CID : NULL Build ID : GINGERBREAD Time-Zone : NULL IMEI : NULL IMSI : 000000000000000 Root User : root Sales Code : DBT Country Code : DBT Built Date : Thu Jun 9 18:16:44 KST 2011 ------------------------------------------------------------------------------------------------ Operation Completed Operation Time: 00:00:05 ----------------------------------------------------------------------------------------------- Turn-on the Phone Goto 'Settings > Application > Development' And Check 'Usb Debugging' Then Connect Usb Cable To Phone And Install Needed Driver. ------------------------------------------------------------------------------------------------ Prepairing ...OK Device Found! Model : GT-I9100 Manufacturer : samsung Brand : samsung CPU info1: : armeabi-v7a CPU info2: : armeabi Serial No. : NULL Baseband Version : NULL GSM Baseband Version : I9100XXKE7 Bootloader Version : unknown Build Version : 2.3.3 Country : US Language : en CID : NULL Build ID : GINGERBREAD Time-Zone : NULL IMEI : NULL IMSI : 000000000000000 Root User : root Sales Code : DBT Country Code : DBT Built Date : Thu Jun 9 18:16:44 KST 2011 ------------------------------------------------------------------------------------------------ Operation Completed Operation Time: 00:00:05 ------------------------------------------------------------------------------------------------ Turn-on the Phone Goto 'Settings > Application > Development' And Check 'Usb Debugging' Then Connect Usb Cable To Phone And Install Needed Driver. ------------------------------------------------------------------------------------------------ Prepairing ...OK Device Found! Root Procedure Started! Refreshing ... OK Prepairing ROOTFILE1(STEP 1) ... OK Prepairing ROOTFILE1(STEP 2) ... OK Prepairing ROOTFILE1(STEP 3) (Please Be Patient 'its take almost ~190 Sec')... OK Reconnecting Device ... ------------------------------------------------------------------------------------------------ if Procedure Stuck Here For a Long Time try This: Disconnecting USB Cable From Phone then Go to: 'Settings > Application > Development' and Toggle 'USB Debugging' (Uncheck then Check) Then Connect Cable to Phone ------------------------------------------------------------------------------------------------ Device Found! Prepairing ROOTFILE2(STEP 1) ... OK Prepairing ROOTFILE2(STEP 2) ... OK Prepairing ROOTFILE2(STEP 3) ... OK Prepairing ROOTFILE2(STEP 4) ... OK Prepairing ROOTFILE2(STEP 5) ... OK Prepairing ROOTFILE2(STEP 6) ... OK Prepairing ROOTFILE2(STEP 7) ... OK OK Prepairing ROOTFILE3(STEP 1) ... OK Prepairing ROOTFILE3(STEP 2) ... OK Prepairing ROOTFILE3(STEP 3) ... OK Prepairing ROOTFILE3(STEP 4) ... OK OK Prepairing Final Step ... OK Refreshing ... OK Rebooting ... OK Root Procedure Finished! Operation Completed Operation Time: 00:03:24 NOW WHAT CAN I DO |
| | #3 (permalink) |
| AFTER USE GREEN METHORD NOW BASE BAND COME BUT IMEI IS 0044XXXXXXX HOW TO FIX IT ----------------------------------------------------------------------------------------------- Turn-on the Phone Goto 'Settings > Application > Development' And Check 'Usb Debugging' Then Connect Usb Cable To Phone And Install Needed Driver. ------------------------------------------------------------------------------------------------ Prepairing ...OK Device Found! Model : GT-I9100 Manufacturer : samsung Brand : samsung CPU info1: : armeabi-v7a CPU info2: : armeabi Serial No. : NULL Baseband Version : NULL GSM Baseband Version : I9100XXKE7 Bootloader Version : unknown Build Version : 2.3.3 Country : US Language : en CID : NULL Build ID : GINGERBREAD Time-Zone : NULL IMEI : NULL IMSI : 000000000000000 Root User : root Sales Code : DBT Country Code : DBT Built Date : Thu Jun 9 18:16:44 KST 2011 ------------------------------------------------------------------------------------------------ Operation Completed Operation Time: 00:00:05 |
| | #5 (permalink) | |
| Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2011 Location: Iran
Member: 1707100 Status: Offline Sonork: 1590245/1587178 Thanks: 501
| Quote:
now you must change imei to any imei please attach picture or good report for Beginner user Last edited by Asansam dongle; 07-08-2012 at 19:02. | |
| The Following User Says Thank You to Asansam dongle For This Useful Post: |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| How to add a language in 51xx/61xx | tati | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 7 | 12-10-2012 04:46 |
| How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 28 | 08-30-2012 03:40 |
| How can I do a Welcome note for my 6110 a dosn't have any one ? | Viper | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 7 | 07-18-2012 07:57 |
| news headlines to gsm phone | mos | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 6 | 12-18-2011 11:00 |
| Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 1 | 06-10-1999 22:36 |
