HUA GOLD Old BY HUA TEAM |
11-20-2013, 19:58 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: persian Age: 43
Member: 777729 Status: Offline Sonork: 100.1616470 Thanks Meter: 824 | I9300 repair no network fail[ANSWERED] Device Found! Reading Phone Informations ... Model : GT-I9300 Android Version : 4.3 PDA Version : I9300XXUGMJ9 CS Version : I9300VFGGMJ5 Phone Version : I9300BUUGMJ3 IMEI : NULL Checking Root ...OK Phone Root OK. Continue.. Reading Data From Phone ...OK OK Prepairing Phone ...Fail Last edited by dr_moosavi; 11-26-2013 at 11:09. |
11-20-2013, 20:07 | #2 (permalink) |
No Life Poster Join Date: Sep 2004 Location: in AXE control room Age: 54
Member: 84300 Status: Offline Thanks Meter: 74 | For shure, U flashed phone with some strange firmware . And U lost IMEI, and SR is 000000000 First, repair IMEI, and after that SN . If all other box-es fail, U can easyly do it with next metode : "To all i have made a lot of test and without other box, you can only use SRS samsung remote client unlock,this is a free software and can change the serial for free!It's crazy that z3x team can't do this and using a cable and this software is possibile. It's very strange because all modifications consists only to modify nv_data bin and here are store all data like imei,BT,serial,wifi,ecc and all are encrypted. I'm a software engineer and i haven't spend a lot of time to check what type of encryption use samsing but i think is the same to change IMEI and SERIAL and so why z3x can't do it?ANd if can't do why don't block option?because you can choose only 10 char and not 11. However use always i9100 option to change data like BT WIFI and PRODUCT code and remember to check COM and not USB during repair option. However i use always this software to change serial and it works. However change serial ins't needed because ariza patch can get you network with serial 000000 to but if you have to do this job for a customer (like me) it's not good see in info serial 00000000 To use this software you have to pay nothing!just login as test with username and pass written on software. Connect phone with usb and click on advanced option. Now insert imei and serial (both are needed) and make it. Now your serial is 100% good and sometimes you need to repir imei again with samsung tool. However remember to use i9100 option,with i9300 you can't repair product code ,wifi ,etc (programming is my job too and i don't understand how z3x engineer works) And remember to have good results it's almost needed to make a downgrade 100% WORKS and Thanks me " i repeat, this is what I found somwhere on this forum, not my original found |
11-20-2013, 22:47 | #4 (permalink) | |
Product Manager Join Date: Apr 2013 Location: IRAN Age: 38
Member: 1911891 Status: Offline Thanks Meter: 6,241 | Quote:
