Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > HUA Team Products > HSB Box
HSB Box BY HUA TEAM
Old 05-27-2012, 19:16   #16 (permalink)
Asansam dongle's Avatar
Member: 1707100
Sonork: 100.1590245
Thanks Meter: 13,594
http://forum.gsmhosting.com/vbb/f716...fully-1478319/
★★★★★ N7000 Repair Unknown Baseband First in the World !!! ★★★★★
The Following 2 Users Say Thank You to Asansam dongle For This Useful Post:
Old 05-27-2012, 20:15   #17 (permalink)
Member: 1286387
Sonork: Buns27
Thanks Meter: 5
wow!!! i got it!!!
1st: I used ASANSAM UB TOOL
2nd: Then i reflash the mobile
3rd: Edit the IMEI to Z3x
and i repaired S2 also bY ASANSAM UB TOOL...
Thanks brother!!!
The Following 3 Users Say Thank You to buns For This Useful Post:
Old 05-29-2012, 08:03   #18 (permalink)
Member: 1286387
Sonork: Buns27
Thanks Meter: 5
Searching Samsung USB Modem... Detected (COM5)
Model: GT-N7000
SW: N7000XXLA4
IMEI: 004999010640000
Done with Samsung Tool ver 11.4
Starting ADB Server... OK
Checking ROOT... TRUE
Reading Data From Phone... OK
Writing Data To Phone... OK
Searching Samsung USB Modem... Detected COM5
Bypass MSL... OK
Repairing IMEI... OK
New IMEI: 35957504115xxxx
Rebooting... OK
The Following User Says Thank You to buns For This Useful Post:
Old 05-29-2012, 09:06   #19 (permalink)
Member: 1707100
Sonork: 100.1590245
I have same issue....
i changed u100,mild heat u300,finished in UB TOOL 1.0.3
I wish there is a more solution....
only one click
n7000 no imei no baseband[ANSWERED]
The Following User Says Thank You to Asansam dongle For This Useful Post:
Old 05-30-2012, 09:14   #20 (permalink)
amer_a_82's Avatar
Member: 610529
Sonork: 100.1612153
Thanks Meter: 18
hi
hi bro what color select in method ???
Old 05-30-2012, 10:10   #21 (permalink)
Member: 1707100
Sonork: 100.1590245
you must check all method on phone
Each method offers its own work
Old 05-30-2012, 12:38   #22 (permalink)
amer_a_82's Avatar
Member: 610529
Sonork: 100.1612153
Thanks Meter: 18
i try it all and stel unknown base band
Old 05-30-2012, 13:25   #23 (permalink)
Member: 1707100
Sonork: 100.1590245
is very easy
Old 05-30-2012, 13:59   #24 (permalink)
amer_a_82's Avatar
Member: 610529
Sonork: 100.1612153
Thanks Meter: 18
no way i try all method and no way same problem
Old 05-30-2012, 20:19   #25 (permalink)
Member: 1707100
Sonork: 100.1590245
check hardware first and then contact to me (for check and fix) 100.1587178
Old 04-06-2013, 10:16   #26 (permalink)
Crazy Poster
Member: 338919
hello
my N7000 after update 4.1.2 no baseband so vere is parchase ubtool how much cost
thanks
Old 04-06-2013, 10:37   #27 (permalink)
Asansam Box's Avatar
Member: 1911891
Thanks Meter: 6,150
hello
thanks
Ubtool is free active on asb box
please contact to http://forum.gsmhosting.com/vbb/f716...eller-1406422/
Old 04-10-2013, 10:33   #28 (permalink)
Member: 1560187
Had Just bought Asansam Dongel for Note Imei Repair
Hi
Will appreciate if the forum helps me out to find the issue. Just bought Asansam dongel and want to repair a null imei N7000. As am not so familiar with the dongel am not able to do this. Phone is rooted, Once I click the imei repair butten it says to go in service mode to enter some config, when I am doing this am able to enter in service mode but no option is seen ..only blank screen n no option to select . Once I am bypassing this am getting error while connecting to uart point of time .means searching only . For your info am using z3x for uart with c3303 uart cable. Please guide me where am lacking.
Thanx in advance
Old 04-10-2013, 10:43   #29 (permalink)
Member: 1911891
Thanks Meter: 6,150
you can use imei repair or service menu when modem is damaged(unknown baseband)
modem is damaged and you must repair baseband first
No need when modem is damaged
-check ubtool method(need root and debugging)
-check write efs on phone and try again(ubtool method)
-write dump by jtag on phone(riff box)
-check u100 or u300 ic
your phone problem is unknown baseband and is software or hardware
Old 09-16-2013, 20:32   #30 (permalink)
Lesin KDR's Avatar
Member: 1988081
Sonork: 100.1627039
Thanks Meter: 38
n7000 imei problem
my n7000 imei:004999010640000/01.................any solution.....pls help me
what prog changes imei on 6110 and how do i do it? Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 07-31-2012 20:09
Nokia 51xx/61xx imei changer ver. 1.10?????? Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 04-06-2012 16:22
6110 imei changer !!!!!! Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 11-21-2011 00:44
no one can unlock 6110 05.40 25-5-99 fondas Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 09-22-1999 08:03
Page generated in 0.44608 seconds with 9 queries
