HUA GOLD Old BY HUA TEAM |
07-14-2014, 10:51 | #1 (permalink) |
No Life Poster Join Date: Dec 2012 Location: india mumbai
Member: 1847344 Status: Offline Thanks Meter: 300 | N7100 4.4.2 how to root? When Your Phone Enter in Recovery Mode Following This Steps: 1) Press The Volume Down until 'select apply update from adb' is highlighted 2) Connect USB Cable to Phone(if you dont before) 3) After That Press Power Down to Selected Item and Wait till Procedure Complete When it Complete Reboot Device from that Menu ----------------------------------------------------------------------------------------------- Prepairing ...OK Device Found! Root Procedure Started! Prepairing ROOTFILE ... OK Rooting Device ... Fail! [Err:0] Can not Read Loader! Operation Completed Operation Time: 00:00:09 ----------------------------------------------------------------------------------------------- ----------------------------------------------------------------------------------------------- Turn-on the Phone Goto 'Settings > Application > Development' And Check 'Usb Debugging' Then Connect Usb Cable To Phone And Install Needed Driver. ----------------------------------------------------------------------------------------------- Prepairing ...OK Device Found! Uploading ROOTFILE 1 ...OK Setting Permission ...OK Uploading ROOTFILE 2 ...OK Uploading ROOTFILE 3 ...OK Uploading ROOTFILE 4 ...OK Installing SU ...OK Running Exploit ...OK Cleaning ...OK Rebooting ...OK ----------------------------------------------------------------------------------------------- Operation Completed Operation Time: 00:00:12 ----------------------------------------------------------------------------------------------- ----------------------------------------------------------------------------------------------- Turn-on the Phone Goto 'Settings > Application > Development' And Check 'Usb Debugging' Then Connect Usb Cable To Phone And Install Needed Driver. ----------------------------------------------------------------------------------------------- Prepairing ...OK Device Found! Checking Root ...Fail NO REPAIR NETWORK OR PLEASE TEL ME N7100 4.4.2 NOT REGESTER ON NETWORK |
