Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > HUA Team Products > HUA GOLD Old
HUA GOLD Old BY HUA TEAM
Old 10-23-2013, 17:49   #1 (permalink)
Member: 904809
Sonork: 100.1615464
Thanks Meter: 738
Need help i9000(Sloved now)
I NEED REMOVE GOOGLE ACCOUNT..I TRIED WITH ALL METHOD,,BUT SAME,,ASKING FOR GMAIL,
ALSO PHONE IS IN DEBUG MODE,,BUT ,CAN NOT REMOVE,ANY SOLUTION WITH OUT LOOSING DATA
Operation Time: 00:00:04
Turn-on the Phone Goto 'Settings > Application > Development'
And Check 'Usb Debugging' Then Connect Usb Cable To Phone And Install Needed Driver.
Prepairing ...OK
Device Found!
Removing PIN Code (Method 1) ... [Err:0] Permission denied!
Operation Completed
Operation Time: 00:00:05
Searching For Phone [SAMSUNG USB PORT]... OK
Phone Found on COM11
Waiting For Phone ...
Phone Respond Ok, Continue...
Synchronizing... OK
Reading Phone Infromation... OK
Model : GT-I9000
AP Version : I9000JPJV6
CP Version : I9000ZSJV5
CSC Version : I9000OJPJV6
IMEI : 353327040205312
Prepairing Phone... OK OK OK
Changing Protocol... OK
Initializing Phase... OK
Prepairing Phone... OK OK OK OK OK OK OK OK
Removing PIN Code... Finalizing... OK
Now Enter Any PIN Code to enter Menu
Operation Completed
Operation Time: 00:00:07
Synchronizing... OK
Model : GT-I9000
Removing Pattern Lock... Finalizing... OK
Now Draw Any pattern you Want to Enter Phone Menu
Operation Completed
Synchronizing... OK
Model : GT-I9000
Removing Password... Finalizing... OK
Operation Completed
Synchronizing... OK
Model : GT-I9000
Prepairing Phone... OK Fail 4!
Phone Reject Command!
Operation Completed
Old 10-23-2013, 19:49   #2 (permalink)
Asansam Box's Avatar
Member: 1911891
Thanks Meter: 6,241
Use unblock pattern and dont forget most android supported
or
use hard reset
read here carefully :
read about button before use or send log report :-) remove pin??? -
why use all asansam and asf and all other tools buttons :-)))
Old 10-23-2013, 20:21   #3 (permalink)
Member: 904809
Sonork: 100.1615464
Thanks Meter: 738
or
use hard reset
problem solved,,thx...according yr advice
Page generated in 0.13485 seconds with 8 queries
