HUA GOLD Old BY HUA TEAM |
11-08-2013, 16:56 | #1 (permalink) |
Freak Poster Join Date: Mar 2009 Location: Bangladesh
Member: 998309 Status: Offline Thanks Meter: 54 | Repair Imei Of I9500 But with Connect In UART Cable(success reports) Turn-on the Phone Goto 'Settings > Application > Development' And Check 'Usb Debugging' Then Connect Usb Cable To Phone And Install Needed Driver. ----------------------------------------------------------------------------------------------- Prepairing ...OK Device Found! Reading Phone Informations ... Model : GT-I9500 Android Version : 4.2.2 PDA Version : I9500XXUAMDK CS Version : I9500SERAMDK Phone Version : I9500XXUAMDK IMEI : NULL Checking Root ...OK Phone Root OK. Continue.. Disabling Security ...Done! Rebooting... OK! Now Remove USB Cable and Wait Phone Powering Up Completely (Media Scanners Passed) Then insert UART cable to Phone to Continue Delay 60 Seconds... Searching for phone on COM110 ...Fail! Phone not found! Operation Completed Operation Time: 00:04:02 New User Of.. Asansam Box..Try To Repair Imei Of I9500 But Can't Connect In UART Cable !! But I Can't Find This..... If I Press *#9090# It Show Me Like This.. Please Give Me Any Solution. Best Regard |
11-08-2013, 17:55 | #2 (permalink) |
No Life Poster Join Date: Jan 2011 Age: 29
Member: 1500648 Status: Offline Thanks Meter: 279 | Step :1 Factory reset Step :2 Select com port box in software Press *#7284# and select "Modem" (Only show one option interface "UART") *default setting: "PDA" Press *#9090# and select "4 - DM over UART" *default setting: "DM/DUN over HS-USB" 1-Select interface port in select port part(check enable 1,2 option in setting) 2-Goto general service 3-Insert imei in IMEI1 4-Press repair imei button |
The Following 2 Users Say Thank You to Gsm-Rocky For This Useful Post: |
11-08-2013, 18:15 | #5 (permalink) | |
Member: 998309 Status: Offline Thanks Meter: 54 | Quote:
Sir, Press *#9090# In Number 4 No Have ''DM Over Uart '' It Show Me ''RAMDUMP Off'' !! Phone Was Locked Before, For Unlock, I Flash With Old Russian 4.2.2 Firmware. After Flash Imei 004999010640000/01 And One More Think, I Do EFS Clear With Z3x | |
11-08-2013, 18:20 | #6 (permalink) | |
Member: 1500648 Status: Offline Thanks Meter: 279 | Quote:
1-Select interface port in select port part(check enable 1,2 option in setting) 2-Goto general service 3-Insert imei in IMEI1 4-Press repair imei button | |
11-08-2013, 19:33 | #7 (permalink) |
Member: 998309 Status: Offline Thanks Meter: 54 | Now Remove USB Cable and Wait Phone Powering Up Completely (Media Scanners Passed) Then insert UART cable to Phone to Continue Delay 60 Seconds... Searching for phone on COM3 ... Phone Found Reading Data from phone... Waiting Long Time But Nothing !! |
11-08-2013, 20:24 | #10 (permalink) | |
Thank You Sir. But I Already Use S7070 Cable. With This Cable Don't Have Anything I Min Not Even Charge But C3300k Cable For UFS Show Charging !! What Can I Do Now. Please Give Some Suggestion.I Am In Big Problem. Because Customer Come For Unlock But After Downgrade Fake Imei He Can't Accept That. He Well Kill Me | |
11-08-2013, 20:37 | #11 (permalink) | |||||
Product Manager Join Date: Apr 2013 Location: IRAN Age: 38
Member: 1911891 Status: Offline Thanks Meter: 6,241 | Quote:
http://forum.gsmhosting.com/vbb/9715527-post1.html http://forum.gsmhosting.com/vbb/9707600-post1.html | |||||
11-08-2013, 20:51 | #12 (permalink) | |
11-08-2013, 21:50 | #15 (permalink) |
No Life Poster Join Date: Apr 2004 Location: Lagos Nigeria
Member: 61176 Status: Online Sonork: 100.86572 Thanks Meter: 368 | This is your solution Look at image for solution 100% solution |
The Following User Says Thank You to magixian For This Useful Post: |
