Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Asangsm Dongle
Old 07-02-2012, 15:51   #16 (permalink)
Member: 1175029
Sony Ericsson Flash File Download Image...........
1.St Login.............
2. Model Slect.......
3. Click Download...
The Following User Says Thank You to om telcom For This Useful Post:
Old 07-10-2012, 08:09   #17 (permalink)
dr_moosavi's Avatar
Member: 814775
Sonork: 100.1587334
Sony xperia S root successfully
in 8 sec and very easy
SELECT FILE IMG TO OPEN
PRESS ROOT/UNROOT
ROOT SUCCESS WOWWWWWW
Old 07-10-2012, 08:12   #18 (permalink)
dr_moosavi's Avatar
Member: 814775
Sonork: 100.1587334
Xperia NEO battery 0% fix by one click
my phone is unlock bootloader
install this file and fix to 100%
The Following User Says Thank You to dr_moosavi For This Useful Post:
Old 07-10-2012, 08:14   #19 (permalink)
dr_moosavi's Avatar
Member: 814775
Sonork: 100.1587334
Sony Xperia S remove security question success
Select model
press reset sec ques..(need root)
Old 07-10-2012, 08:16   #20 (permalink)
dr_moosavi's Avatar
Member: 814775
Sonork: 100.1587334
Select model
Now Turn-on the Phone Goto 'Settings > Application > Development'
And Check 'Usb Debugging' Then Connect Usb Cable To Phone And Install Needed Driver.
Prepairing ...OK
Device Found!
Removing Security Question ... OK
Security Question Removed.
Operation Completed
Operation Time: 00:00:08
Old 07-10-2012, 08:17   #21 (permalink)
dr_moosavi's Avatar
Member: 814775
Sonork: 100.1587334
Operation : Reset Gesture Lock
Model : MT15_Xperia Neo
Comunication Pipeline Created ... OK
S1-MSM8x55 BasePhone Detected. Continue...
Downloading Applicable Loader...OK
Phone info:
IMEI : 01270300241740
EROM Version : R9A021
AID Info|
| ____ Loader : "0001"
| ____ EROM : "0001"
| ____ Software : "0001"
| ____ Custom : "0001"
| ____ SimLock : "0001"
AID State : "NOT_TAMPERED"
Rooting State : "ROOTED"
Loader Version : R4A069
Flash Chip1 : Toshiba[Numonyx 8 Gbit Large Page NAND]
Memory card status : Not Present
ANDROID GESTURE LOCK RESET
Phone Detached
Operation Completed
Operation Time: 00:00:04
  • Power off the phone
  • remove battery
  • press button
  • insert usb to phone
  • press back button on phone
  • insert battery
  • install driver
  • reset successfully
Old 07-10-2012, 08:18   #22 (permalink)
dr_moosavi's Avatar
Member: 814775
Sonork: 100.1587334
Xperia neo 2.3.4 root success with asf tools
With Turned Off Phone Please Connect Phone in Fastboot Mode
Device Connected...
Sending Image ...
OK
Writing ... OK
Operation Completed
Operation Time: 00:00:00
Old 07-10-2012, 08:18   #23 (permalink)
dr_moosavi's Avatar
Member: 814775
Sonork: 100.1587334
Xperia neo reset pattern with asf tools
Prepairing ...OK
Device Found!
Removing Pattern Lock ... OK
Android Pattern Lock Removed.
Operation Completed
Old 07-11-2012, 06:58   #24 (permalink)
saif@cellplus's Avatar
Member: 26488
Sonork: 100.1581233
E10 Flash ssuccess
here is log
 Operation : Flash
 Model     : E10_X10 mini
 S1-MSM7227 BasePhone Detected. Continue...
Phone info:
 IMEI                    : xxxxxxxxxxxx249
 EROM Version            : R8A027
 AID Info|
         | ____ EROM     : "0001"
 SimLock State           : "TAMPERED"
 Loader Version          : R4A038
 Flash Chip1             : Samsung[Numonyx 4096 Mbit NAND (large page)]
 Downloading "fota0_S1-SW-LIVE-3EDC-0001-S1-PARTITION.sin"... OK
 Downloading "fota1_S1-SW-LIVE-3EDC-0001-S1-PARTITION.sin"... OK
 Downloading "kernel_S1-SW-LIVE-3EDC-0001-S1-PARTITION.sin"... OK
 Downloading "amss_S1-SW-LIVE-3EDC-0001-S1-PARTITION.sin"... OK
 Downloading "cache_S1-SW-LIVE-3EDC-0001-S1-PARTITION-WITH-SPARE.sin"... OK
 Downloading "amss_fs_robyn_BC18_S1-SW-LIVE-3EDC-0001-S1-PARTITION.sin"... OK
 Downloading "userdata_S1-SW-LIVE-3EDC-0001-S1-PARTITION-WITH-SPARE.sin"... OK
 Downloading "system_S1-SW-LIVE-3EDC-0001-S1-PARTITION-WITH-SPARE.sin"... OK
 Processing "simlock.ta" ... OK
 SimLock Data Detected. SKIPPED...
 Phone Detached
 Operation Completed
 Operation Time: 00:06:45
Regards,
Saif.
The Following User Says Thank You to saif@cellplus For This Useful Post:
Old 07-13-2012, 11:10   #25 (permalink)
dr_moosavi's Avatar
Member: 814775
Sonork: 100.1587334
I got a 2 phones xperia 10.Problem is vibration then blackscreen.
I try many file with setool & flashtool But it still same.
After i try to it with asansam box then phone is alive.
Thanks asansam team.
Here is Flash log:
 Operation : Flash
 Model     : X10_Xperia
 S1-MSM8x50 BasePhone Detected. Continue...
Phone info:
 IMEI                    : 35941903162594
 EROM Version            : R8A013
 AID Info|
         | ____ EROM     : "0001"
 SimLock State           : ""
 Loader Version          : R4A024
 Flash Chip1             : Micron[Numonyx 8 Gbit Large Page NAND]
 Downloading "amss_fs.sin"... OK
 Downloading "cache.sin"... OK
 Downloading "apps_log.sin"... OK
 Downloading "amss.sin"... OK
 Downloading "fota0.sin"... OK
 Downloading "fota1.sin"... OK
 Downloading "recovery.sin"... OK
 Downloading "dsp1.sin"... OK
 Downloading "boot.sin"... OK
 Processing "preset.ta" ... OK
 Sending TA var Block: 0002 Unit: 0008FD Size: 0x10
 Sending TA var Block: 0002 Unit: 000961 Size: 0x4
 Downloading "system_S1-SW-LIVE-AC12-0001-S1-PARTITION-WITH-SPARE.sin"... OK
 Downloading "userdata_S1-SW-LIVE-AC12-0001-S1-PARTITION-WITH-SPARE.sin"... OK
 Phone Detached
 Operation Completed
 Operation Time: 00:18:13
The Following 3 Users Say Thank You to dr_moosavi For This Useful Post:
Old 07-14-2012, 05:47   #26 (permalink)
mobile_hotman's Avatar
Member: 214340
X10i Security Question removed in just 1 click button n all done in 3 seconds.
Model : X10_Xperia
Phone info:
IMEI : 01259000473683
EROM Version : R8A031
AID Info|
| ____ EROM : "0001"
SimLock State : ""
Phone Detached
Operation Completed
Operation Time: 00:00:03
The Following User Says Thank You to mobile_hotman For This Useful Post:
Old 07-23-2012, 11:54   #27 (permalink)
mobail.saba's Avatar
Member: 1712884
Sonork: 100,1625146
Exclamation U5i (vivaz) info and flash full and very easy
U5i(vivaz)
The Following User Says Thank You to mobail.saba For This Useful Post:
Old 07-25-2012, 13:49   #28 (permalink)
Member: 1712884
Sonork: 100,1625146
Exclamation st15 vibre and tuch problem full repair by android4.04 and Asansam box!!!!
see by Asansam box very easy.............
ST15
Old 08-02-2012, 22:09   #29 (permalink)
Member: 203352
Sonork: 100.1609650
Model : ST17_Xperia active
Phone info:
IMEI : 35851004017158
EROM Version : R9A029
AID Info|
| ____ EROM : "0001"
Rooting State : "ROOTABLE"
Flash Chip1 : Samsung[Numonyx 8 Gbit Large Page NAND]
Memory card status : Present [2GB]
Phone Detached
Operation Completed
The Following User Says Thank You to sazr For This Useful Post:
Old 09-08-2012, 11:19   #30 (permalink)
Temporary banned !!
Member: 921094
Sonork: 100.1603246
XPERIA E10 REMOVED GOOGLE ACCOUNT DONE
Phone info:
IMEI : 01231200225821
EROM Version : R8A026
AID Info|
| ____ EROM : "0001"
Flash Chip1 : ST[Numonyx 4096 Mbit NAND (large page)]
Phone Detached
Operation Completed
Sim card sleep mode problem with 6130 ratzfatz Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 4 05-22-2012 11:13
Help with 6110 paulomt1 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 05-25-2009 16:29
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 07-07-1999 12:27
Netmonitor with FBus???? ratzfatz Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 4 06-09-1999 17:04
Page generated in 0.24182 seconds with 12 queries
