HUA GOLD Old BY HUA TEAM |
05-03-2014, 18:48 | #1 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Egypt Age: 41
Member: 153397 Status: Offline Sonork: 113032 Thanks Meter: 372 | s7562 remove account google successfully with asansam box[REPORT OK] Turn-on the Phone Goto 'Settings > Application > Development' And Check 'Usb Debugging' Then Connect Usb Cable To Phone And Install Needed Driver. ----------------------------------------------------------------------------------------------- Prepairing ...OK Device Found! Model : GT-S7562 Android Version : 4.0.4 Note: This Command Only Work On Samsung Phone's With Android 4.0.X or Above. Backing Up Full Data ... OK Now in Your Phone New Window Appeared just tap on Backup My Data and Wait till Procedure Complete in Phone This Procedure may take long time so dont unplug cable from phone during phone process After Completing Update Procedure That window dissapeared itself and you have complete Full data Backup in: "C:\ASANSAM2\BACKUP\FULLBACKUP40X\_FULL_DATA_BACKU P_2014-05-03__19-36-49.bin" ----------------------------------------------------------------------------------------------- Operation Completed Operation Time: 00:01:06 ----------------------------------------------------------------------------------------------- ----------------------------------------------------------------------------------------------- Turn-on the Phone Goto 'Settings > Application > Development' And Check 'Usb Debugging' Then Connect Usb Cable To Phone And Install Needed Driver. ----------------------------------------------------------------------------------------------- Prepairing ...OK Device Found! Searching for Account .... OK Account Found,Disabling Security... OK Removing Account ...OK Now Revove Batter then Reinster That and Turn On Device. ----------------------------------------------------------------------------------------------- Operation Completed Operation Time: 00:00:09 ----------------------------------------------------------------------------------------------- ----------------------------------------------------------------------------------------------- Turn-on the Phone Goto 'Settings > Application > Development' And Check 'Usb Debugging' Then Connect Usb Cable To Phone And Install Needed Driver. ----------------------------------------------------------------------------------------------- Prepairing ...OK Device Found! Removing PIN Code (Method 1) ... OK PIN Code Removing Done. ----------------------------------------------------------------------------------------------- Operation Completed Operation Time: 00:00:33 ---------------------------- but same what can i do Last edited by dr_moosavi; 06-06-2014 at 21:08. |
05-03-2014, 18:56 | #2 (permalink) |
Product Manager Join Date: Apr 2013 Location: IRAN Age: 38
Member: 1911891 Status: Offline Thanks Meter: 6,241 | Why use remove pin when ask google acc??!!!!! Read all in one 1.0.5 carefully and step to step Android service tab/misc job/remove google acc w/o ud |
05-03-2014, 18:59 | #3 (permalink) |
Member: 153397 Status: Offline Sonork: 113032 Thanks Meter: 372 | now work in pin code Searching For Phone [SAMSUNG USB PORT]... OK Phone Found on COM64 Waiting For Phone ... Phone Respond Ok, Continue... Synchronizing... OK Reading Phone Infromation... OK Model : GT-S7562 AP Version : S7562XXALJ4 CP Version : S7562XXLJ3 CSC Version : S7562OJVALJ1 IMEI : 355355052734380 Prepairing Phone... OK OK OK Changing Protocol... OK Initializing Phase... OK Prepairing Phone... OK OK OK OK OK OK OK OK Removing PIN Code... OK OK OK Finalizing... OK Now Enter Any PIN Code to enter Menu Operation Completed Operation Time: 00:00:16 |
06-06-2014, 08:54 | #5 (permalink) |
Freak Poster Join Date: Nov 2008 Location: INDIA THE HEAVEN Age: 43
Member: 890328 Status: Offline Thanks Meter: 50 | s7562 pin lock Searching For Phone [SAMSUNG USB PORT]... OK Phone Found on COM246 Waiting For Phone ... Phone Respond Ok, Continue... Synchronizing... OK Reading Phone Infromation... OK Model : GT-S7562 AP Version : S7562XXBMG2 CP Version : S7562DDBMG1 CSC Version : S7562ODDBMG1 IMEI : xxxxxxxxxxxxxxx Prepairing Phone... OK OK OK Changing Protocol... OK Initializing Phase... OK Prepairing Phone... OK OK OK OK OK OK OK OK Removing PIN Code... OK OK OK Finalizing... OK Now Enter Any PIN Code to enter Menu Operation Completed Operation Time: 00:00:14 |
