HUA GOLD Old BY HUA TEAM |
10-14-2014, 19:37 | #1 (permalink) |
No Life Poster Join Date: Aug 2013 Location: CHENNAI, TAMILNADU,INDIA
Member: 2001848 Status: Offline Sonork: 100.1658212 Thanks Meter: 581 | Samsung B3210 corby dead boot repair done with asansam box + optiflasher..... now i cannot able to put the phone into download mode...... b3210 download mode : press * and insert usb download mode cable..... when i connect my device to system it show as "unrecognized device" Solution : need battery with full charge Run Samsung B3210 CorbyTXT optiflash.exe Downloader. Select Customer T: Rodeo (Intel Sibley 1024/256, USB). In Flash Option section check: Code Binary and CSC Binary(Default). Also check this Option: Erase all Unused Regions. Select the code(s3) Flash file and CSC file.... select port of asansam box...... baudrate 921600 Click on Flash button and type YES in the message box then click OK to Start the process. now it shows power on phone........ connect phone to asansam box with z3x uart auto ignition cable( c3303k),,,,,, remove battery and again insert battery........ now it will start flashing and shows error at the end of flashing s3 file.......remove phone from cable... thats it,,, now reinsert battery and press power on ...... now u can see ur phone stops on boot loop now full flash the mobile using usb with optiflasher..... |
