Samsung galasy Note 2 N7100 unknown baseband and Imei null[REPORT OK] PDA:N7100XXALIE Phone:Unknown CSC:N7100LBALI9 H/W:Not active RF Cal Date: Unknown --------------- --------------- Band:Unknown --------------- Memory:16G ( Prepairing ...OK Device Found! Reading Phone Informations ... Model : GT-N7100 Android Version : 4.1.2 PDA Version : N7100XXDMC3 CS Version : N7100OJVDMC1 Phone Version : NULL IMEI : NULL Checking Root ...OK Phone Root OK. Continue.. Incorrect Parameter Operation Completed Operation Time: 00:00:10) |
You must repair baseband first and then use imei repair Asansam not supported this model(repair baseband via ubtool) |
Prepairing ...OK Device Found! Reading Phone Informations ... Model : GT-N7100 Android Version : 4.1.2 PDA Version : N7100XXDMC3 CS Version : N7100OXFDMC1 Phone Version : NULL IMEI : NULL Baseband Version : NULL GSM Baseband Version : NULL Checking Root ...OK Phone Root OK. Continue.. Prepairing... Fail Busybox Not Installed! Operation Completed Operation Time: 00:00:10 Model : GT-N7100 Android Version : 4.1.2 PDA Version : N7100XXDMC3 CS Version : N7100OXFDMC1 Phone Version : NULL IMEI : NULL Baseband Version : NULL GSM Baseband Version : NULL Checking Root ...OK Phone Root OK. Continue.. Prepairing... OK Restoring... OK PB Restore Done! Operation Completed Operation Time: 00:00:10 ater used ubtool seam problem not repaer bassband ok aney other sulation ? |
Prepairing ...OK Device Found! Reading Phone Informations ... Model : GT-N7100 Android Version : 4.1.2 PDA Version : N7100XXDMC3 CS Version : N7100OXFDMC1 Phone Version : NULL IMEI : NULL Checking Root ...OK Phone Root OK. Continue.. Reading Data From Phone ...OK OK Prepairing Phone ...OK Disabling Security ...Done! Rebooting... OK! Now Remove USB Cable then Insert Micro UART Cable to Phone to Continue.. Delay 40 Seconds... Searching for phone on COM62 ...Fail! Phone not found! Operation Completed Operation Time: 00:03:27 plz supporter help me |
your modem is null, how can you repair this by asansam if the problem is EMMC IC? You have options: -Try to flash only the modem (only 5% of chance to fix it.) -Change emmc iC then do the software part to fix the IMEI. (99% of chance to fix, 1% base on your hardware capability.) |
To dildil-pakistan: You need sleep or buy glasses for eyes Why use any button when asansam not supported !!!!!!!!! To haydernaz: I think you are sleep too You and all other useres cannot use imei repair and rj45 connection when phone or modem is null/damaged via asansam or all other boxes |
Asansam Box, Hello. I have 2 N7100 locked. I tryed to unlock with asansam and both phones lost IMEIs. Code: Prepairing ...OK |
Please, I urgently need help with this phones. |
you need backup efs and restore on phone only |
But I haven't EFS backup, can I repair my phone without it? |
After flashing N7100XXDME6 firmware one of them IMEI is back, but on another IMEI is 00499...., can Asansam repair this phone damaged by it? Can Asansam work with Phone Version : N7100XXDMF1? |
you can use imei repair now |
who can help me on this N7100 Basebanad Version and IMEI all damage i try to repair it phone modem not found..... |
Not supported this model(ubtool) Please check free solution only http://forum.gsmhosting.com/vbb/f716...-tool-1601748/ |
I got a Samsung Note II GT-N7100. The sim card do not read. The IMEI: NULL/NULL. when type *#06#. When type a number and send it says Mobile network not available. What can I do to rectified this problem. |
