HUA GOLD Old BY HUA TEAM |
09-20-2013, 08:48 | #1 (permalink) |
No Life Poster Join Date: Nov 2010 Location: PAKISTAN
Member: 1435528 Status: Offline Sonork: 100.1603713 Thanks Meter: 217 | Samsung galasy Note 2 N7100 unknown baseband and Imei null[REPORT OK] Phone:Unknown CSC:N7100LBALI9 H/W:Not active RF Cal Date: Unknown --------------- --------------- Band:Unknown --------------- Memory:16G ( Prepairing ...OK Device Found! Reading Phone Informations ... Model : GT-N7100 Android Version : 4.1.2 PDA Version : N7100XXDMC3 CS Version : N7100OJVDMC1 Phone Version : NULL IMEI : NULL Checking Root ...OK Phone Root OK. Continue.. Incorrect Parameter Operation Completed Operation Time: 00:00:10) Last edited by dr_moosavi; 09-28-2013 at 15:27. |
09-20-2013, 09:23 | #2 (permalink) |
Product Manager Join Date: Apr 2013 Location: IRAN Age: 38
Member: 1911891 Status: Offline Thanks Meter: 6,241 | You must repair baseband first and then use imei repair Asansam not supported this model(repair baseband via ubtool) |
The Following User Says Thank You to Asansam Box For This Useful Post: |
09-21-2013, 06:17 | #3 (permalink) |
Member: 1435528 Status: Offline Sonork: 100.1603713 Thanks Meter: 217 | Prepairing ...OK Device Found! Reading Phone Informations ... Model : GT-N7100 Android Version : 4.1.2 PDA Version : N7100XXDMC3 CS Version : N7100OXFDMC1 Phone Version : NULL IMEI : NULL Baseband Version : NULL GSM Baseband Version : NULL Checking Root ...OK Phone Root OK. Continue.. Prepairing... Fail Busybox Not Installed! Operation Completed Operation Time: 00:00:10 Model : GT-N7100 Android Version : 4.1.2 PDA Version : N7100XXDMC3 CS Version : N7100OXFDMC1 Phone Version : NULL IMEI : NULL Baseband Version : NULL GSM Baseband Version : NULL Checking Root ...OK Phone Root OK. Continue.. Prepairing... OK Restoring... OK PB Restore Done! Operation Completed Operation Time: 00:00:10 ater used ubtool seam problem not repaer bassband ok aney other sulation ? Last edited by DILDIL-PAKISTAN; 09-21-2013 at 06:22. |
09-21-2013, 06:33 | #4 (permalink) |
Freak Poster Join Date: Jan 2007 Location: karor lal-esan pakistan
Member: 427028 Status: Offline Sonork: 100.1639042 Thanks Meter: 63 | Prepairing ...OK Device Found! Reading Phone Informations ... Model : GT-N7100 Android Version : 4.1.2 PDA Version : N7100XXDMC3 CS Version : N7100OXFDMC1 Phone Version : NULL IMEI : NULL Checking Root ...OK Phone Root OK. Continue.. Reading Data From Phone ...OK OK Prepairing Phone ...OK Disabling Security ...Done! Rebooting... OK! Now Remove USB Cable then Insert Micro UART Cable to Phone to Continue.. Delay 40 Seconds... Searching for phone on COM62 ...Fail! Phone not found! Operation Completed Operation Time: 00:03:27 plz supporter help me |
09-21-2013, 06:46 | #5 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Caribbean
Member: 237911 Status: Offline Thanks Meter: 632 | your modem is null, how can you repair this by asansam if the problem is EMMC IC? You have options: -Try to flash only the modem (only 5% of chance to fix it.) -Change emmc iC then do the software part to fix the IMEI. (99% of chance to fix, 1% base on your hardware capability.) |
09-21-2013, 07:15 | #6 (permalink) |
Member: 1911891 Status: Offline Thanks Meter: 6,241 | To dildil-pakistan: You need sleep or buy glasses for eyes Why use any button when asansam not supported !!!!!!!!! To haydernaz: I think you are sleep too You and all other useres cannot use imei repair and rj45 connection when phone or modem is null/damaged via asansam or all other boxes |
09-25-2013, 13:48 | #7 (permalink) |
Freak Poster Join Date: May 2005 Age: 37
Member: 148631 Status: Offline Thanks Meter: 9 | Asansam Box, Hello. I have 2 N7100 locked. I tryed to unlock with asansam and both phones lost IMEIs. Code: Prepairing ...OK Device Found! Reading Phone Informations ... Model : GT-N7100 Android Version : 4.1.2 PDA Version : N7100XXDME6 CS Version : N7100DBTDME2 Phone Version : N7100XXDMF1 IMEI : NULL (BUT IMEI IS STILL OK NOW) Checking Root ...OK Phone Root OK. Continue.. Disabling Security ...Done! Rebooting... OK! Last edited by DrManila; 09-25-2013 at 13:54. |
09-25-2013, 15:39 | #11 (permalink) |
Member: 148631 Status: Offline Thanks Meter: 9 | After flashing N7100XXDME6 firmware one of them IMEI is back, but on another IMEI is 00499...., can Asansam repair this phone damaged by it? Can Asansam work with Phone Version : N7100XXDMF1? |
09-25-2013, 16:08 | #12 (permalink) | |
Member: 1911891 Status: Offline Thanks Meter: 6,241 | Quote:
you can use imei repair now | |
12-22-2013, 11:26 | #14 (permalink) | |
No Life Poster Join Date: Jan 2011 Age: 29
Member: 1500648 Status: Offline Thanks Meter: 279 | Quote:
Not supported this model(ubtool) Please check free solution only http://forum.gsmhosting.com/vbb/f716...-tool-1601748/ | |
02-19-2014, 21:04 | #15 (permalink) |
Junior Member Join Date: Feb 2014
Member: 2132001 Status: Offline Sonork: samsung Thanks Meter: 1 | I got a Samsung Note II GT-N7100. The sim card do not read. The IMEI: NULL/NULL. when type *#06#. When type a number and send it says Mobile network not available. What can I do to rectified this problem. |
The Following User Says Thank You to Robert Hurd For This Useful Post: |
