HUA GOLD Old BY HUA TEAM |
09-16-2013, 22:58 | #1 (permalink) |
Freak Poster Join Date: Aug 2008 Location: Santiago de Cuba, CUBA
Member: 836938 Status: Offline Thanks Meter: 18 | Samsung i9300 IMEI and Baseband UNKNOWN[ANSWERED] Root_SuperSU.1.02-Busybox.1.21.0.zip CMV-based Recovery v5.5.0.4 :: CF-v1.5 I9300XXDLJ1_I9300XECDLJ2_I9300BGDLJ1_HOME.tar.md5 (Android Version : 4.1.1) PB Restore OK EFS REPAIR OK IMEI REPAIR ERROR Incorrect Parameter I need any complete and tested solution Thanks ----------------------------------------------------------------------------------------------- Before Using This Section Check and Be Sure : 1) Your Phone Has Complete ROOT Access 2) Your Phone Must be in AirPlane Mode 3) BusyBox Must be Installed in Your Phone ----------------------------------------------------------------------------------------------- Turn-on the Phone Goto 'Settings > Application > Development' And Check 'Usb Debugging' Then Connect Usb Cable To Phone And Install Needed Driver. Note: Phone Must be Rooted and be in AirPlane Mode For Restore PB Operation You Must Install Busybox in additional of all this ----------------------------------------------------------------------------------------------- ----------------------------------------------------------------------------------------------- PB Restore ----------------------------------------------------------------------------------------------- Prepairing ...OK Device Found! Reading Phone Informations ... Model : GT-I9300 Android Version : 4.1.1 PDA Version : I9300XXDLJ1 CS Version : I9300XECDLJ2 Phone Version : NULL IMEI : NULL Baseband Version : NULL GSM Baseband Version : NULL Checking Root ...OK Phone Root OK. Continue.. Prepairing... OK Restoring... OK PB Restore Done! Operation Completed Operation Time: 00:00:24 ----------------------------------------------------------------------------------------------- EFS REPAIR ----------------------------------------------------------------------------------------------- Prepairing ...OK Device Found! Reading Phone Informations ... Model : GT-I9300 Android Version : 4.1.1 PDA Version : I9300XXDLJ1 CS Version : I9300XECDLJ2 Phone Version : NULL IMEI : NULL Baseband Version : NULL GSM Baseband Version : NULL Checking Root ...OK Phone Root OK. Continue.. Repairing EFS ... OK EFS Repair Done Phone Reset Done! Operation Completed Operation Time: 00:00:19 ----------------------------------------------------------------------------------------------- IMEI REPAIR ----------------------------------------------------------------------------------------------- Prepairing ...OK Device Found! Reading Phone Informations ... Model : GT-I9300 Android Version : 4.1.1 PDA Version : I9300XXDLJ1 CS Version : I9300XECDLJ2 Phone Version : NULL IMEI : NULL Checking Root ...OK Phone Root OK. Continue.. Incorrect Parameter Operation Completed Operation Time: 00:00:41 Last edited by dr_moosavi; 10-15-2013 at 07:36. |
09-17-2013, 07:49 | #2 (permalink) |
Product Manager Join Date: Apr 2013 Location: IRAN Age: 38
Member: 1911891 Status: Offline Thanks Meter: 6,241 | Why use restore pb button before read about? your block is damaged now and need hardware check only http://forum.gsmhosting.com/vbb/f716...rning-1661676/ you cannot use repair imei when phone/baseband is damaged or null |
The Following User Says Thank You to Asansam Box For This Useful Post: |
10-14-2013, 21:47 | #5 (permalink) |
Product Supporter Join Date: Dec 2010 Location: Brazil Fortaleza Ceará
Member: 1474113 Status: Offline Sonork: 100.1604217 Thanks Meter: 472 | I have I9300 baseband error the error happened after I tried to do the imei in z3x seen as various moods of Asan, repairing the baseband bought my now done the procedure as shown in the picture however lowers the error will still continue what can be? Last edited by Asansam Box; 10-14-2013 at 22:08. |
10-14-2013, 22:10 | #6 (permalink) | |
Member: 1911891 Status: Offline Thanks Meter: 6,241 | Quote:
why cannot read manual before use box? why cannot read about button before use? http://forum.gsmhosting.com/vbb/f716...rning-1661676/ solution: check hardware solution now :-) | |
10-15-2013, 01:03 | #7 (permalink) | |
Member: 1474113 Status: Offline Sonork: 100.1604217 Thanks Meter: 472 | Quote:
10-15-2013, 09:46 | #8 (permalink) | ||
http://forum.gsmhosting.com/vbb/f716...33/index2.html http://forum.gsmhosting.com/vbb/f716...33/index3.html Restore PB = when go to recovery mode show u E: failed to mount /efs (Invalid argument) or Not show EFS block in mount command Quote:
10-15-2013, 13:03 | #9 (permalink) | |
Complicated Baseband shows the error, now my IC is damaged the damage I did to him? then see that image that has not done anything S5830c tell me if it is possible to solve the Asan just this model? | |
10-15-2013, 13:09 | #10 (permalink) | |
