samsung n7000 repair unknown baseband succefully[REPORT OK] hi all, i want to buy asansam but first i want know can this donlge repair null imei of note n7000 failed from z3x if yes then plz tel me reseller from Pakistan |
yes supported imie reapair http://forum.gsmhosting.com/vbb/f716...world-1464925/ reseller : http://forum.gsmhosting.com/vbb/f716...eller-1406422/ |
ok now i have asansam dongle soo plz guide me step by step to repair imei of note n7000 thanx an advance |
Check this brother http://forum.gsmhosting.com/vbb/f716...world-1464925/ |
helooooooooo is there anybody |
please root phone and check all method in ubtool |
basband repaired but imei remain wrong starts from 004999010640000 now what to do z3x not repairing it here is ubtool log UBTool Rev1.0.3 By ASAN-GSM TEAM --------------------------------------------- Important Note: Before Using This Tool Check and Be Sure : 1) Your Phone Has Complete ROOT Access 2) Your Phone Must be in AirPlane Mode ------------------------------------------------------------------------------- Turn-on the Phone Goto ' Settings > Application > Development' And Check 'Usb Debugging' Then Connect Usb Cable To Phone And Install Needed Driver. ------------------------------------------------------------------------------- Prepairing ...OK Device Found! Prepairing Green Method ...OK Repairing EFS ... OK Finalizing EFS ... OK Rebooting ... OK Phone Reset Done! -------------------------------------------- Operation Completed Operation Time: 00:00:22 ------------------------------------------------------------------------------- Turn-on the Phone Goto ' Settings > Application > Development' And Check 'Usb Debugging' Then Connect Usb Cable To Phone And Install Needed Driver. ------------------------------------------------------------------------------- Prepairing ...OK Device Found! Prepairing NV DATA ... OK Cleaning NV DATA ... OK Rebooting ... OK Device Found! Initializing NVM ... OK Downloading NVM ... OK Rebooting ... OK Phone Reset Done! -------------------------------------------- Operation Completed Operation Time: 00:00:40 and here is z3x Failure log -------------------------- 22.5.2012_15-35-8 -------------------------- Count supported models - 290 Starting ADB Server... OK Checking ROOT... FALSE Reading Phone Info... OK Android Version: 2.3.5 Model: GT-N7000 Product Code: Not Active Phone Version: N7000XXLA4 PDA Version: N7000XXKJ1 IMEI: 004999010640000 Rooting Phones... OK Checking EFS... Present Rebooting... OK Waiting For Reboot Finish... OK Rooting Phones... OK Checking NV Data... OK Searching Samsung USB Modem... Not Found Done with Samsung Tool ver 11.9 |
unknow baseband and dont show imei problem repair successfully (by ubtool first in world and very easy):-) you must try change imei by other tools asansam not supported |
thanx asansam my problem solved this is pending from last two month finally i got dongle and after two hrs i successfully repaired thanx again asansam dongle here is log from z3x after repairing basband change imei Starting ADB Server... OK Checking ROOT... FALSE Reading Phone Info... OK Android Version: 2.3.5 Model: GT-N7000 Product Code: Not Active Phone Version: N7000XXLA4 PDA Version: N7000XXKJ1 IMEI: 004999010640000 Rooting Phones... OK Reading Data From Phone... OK Writing Data To Phone... OK Searching Samsung USB Modem... Detected COM10 Bypass MSL... Error (1) Done with Samsung Tool ver 11.9 Starting ADB Server... OK Checking ROOT... TRUE Reading Data From Phone... OK Writing Data To Phone... OK Searching Samsung USB Modem... Detected COM10 Bypass MSL... OK Repairing IMEI... OK New IMEI: 359616041627779 Rebooting... OK Done with Samsung Tool ver 11.9 |
ok done basband repaired but imei remain wrong starts from 004999010640000 now what to do z3x not repairing it here is ubtool log UBTool Rev1.0.3 By ASAN-GSM TEAM --------------------------------------------- Important Note: Before Using This Tool Check and Be Sure : 1) Your Phone Has Complete ROOT Access 2) Your Phone Must be in AirPlane Mode ------------------------------------------------------------------------------- Turn-on the Phone Goto ' Settings > Application > Development' And Check 'Usb Debugging' Then Connect Usb Cable To Phone And Install Needed Driver. ------------------------------------------------------------------------------- Prepairing ...OK Device Found! Prepairing Blue Method ...OK Repairing EFS ... OK Finalizing EFS ... OK Rebooting ... OK Phone Reset Done! -------------------------------------------- Operation Completed Operation Time: 00:00:22 ------------------------------------------------------------------------------- Turn-on the Phone Goto ' Settings > Application > Development' And Check 'Usb Debugging' Then Connect Usb Cable To Phone And Install Needed Driver. ------------------------------------------------------------------------------- Prepairing ...OK Device Found! Prepairing NV DATA ... OK Cleaning NV DATA ... OK Rebooting ... OK Device Found! Initializing NVM ... OK Downloading NVM ... OK Rebooting ... OK Phone Reset Done! -------------------------------------------- Operation Completed Operation Time: 00:00:40 Starting ADB Server... OK Checking ROOT... FALSE Reading Phone Info... OK Android Version: 2.3.5 Model: GT-N7000 Product Code: Not Active Phone Version: N7000XXLA4 PDA Version: N7000XXKJ1 IMEI: 004999010640000 Rooting Phones... OK Reading Data From Phone... OK Writing Data To Phone... OK Searching Samsung USB Modem... Detected COM10 Bypass MSL... Error (1) Done with Samsung Tool ver 11.9 Starting ADB Server... OK Checking ROOT... TRUE Reading Data From Phone... OK Writing Data To Phone... OK Searching Samsung USB Modem... Detected COM10 Bypass MSL... OK Repairing IMEI... OK New IMEI: 35xxxxxxxxxxxxx Rebooting... OK Done with Samsung Tool ver 11.9 |
Before Using This Section Check and Be Sure : 1) Your Phone Has Complete ROOT Access 2) Your Phone Must be in AirPlane Mode 3) BusyBox Must be Installed in Your Phone ----------------------------------------------------------------------------------------------- Turn-on the Phone Goto 'Settings > Application > Development' And Check 'Usb Debugging' Then Connect Usb Cable To Phone And Install Needed Driver. Note: Phone Must be Rooted and be in AirPlane Mode For Restore PB Operation You Must Install Busybox in additional of all this ----------------------------------------------------------------------------------------------- Prepairing ...OK Device Found! Reading Phone Informations ... Model : GT-N7000 Android Version : 4.0.4 PDA Version : N7000DDLR9 CS Version : N7000ODDLR3 Phone Version : NULL IMEI : NULL Baseband Version : NULL GSM Baseband Version : NULL Checking Root ...OK Phone Root OK. Continue.. STEP1 ... OK STEP2 ... OK Phone Reset Done! Operation Completed Operation Time: 00:00:12 after this remain same unknown baseband and imei blank anyone has proper step i m using asansam 2.5.7 beta ver |
How u solve unkonwn baseband through asansam I have same problem in my n7100 |
