HUA GOLD Old BY HUA TEAM |
01-08-2014, 10:43 | #1 (permalink) |
Freak Poster Join Date: Sep 2007
Member: 592531 Status: Offline Sonork: 100.1641625 Thanks Meter: 17 | samsung s3 GT-I9300 no network repair successfully with ASANSAM BOX Turn-on the Phone Goto 'Settings > Application > Development' And Check 'Usb Debugging' Then Connect Usb Cable To Phone And Install Needed Driver. ----------------------------------------------------------------------------------------------- Prepairing ...OK Device Found! Model : GT-I9300 Manufacturer : samsung Brand : samsung CPU info1 : armeabi-v7a CPU info2 : armeabi Serial No. : 00000000000 Baseband Version : NULL GSM Baseband Version : I9300BUUGMJ3 Bootloader Version : I9300XXUGMJ9 Build Version : 4.3 Country : GB Language : en CID : NULL Build ID : JSS15J Time-Zone : Asia/Karachi IMEI : NULL IMSI : NULL Root User : se.infra Sales Code : VD2 Country Code : VD2 Built Date : Sat Oct 26 12:29:22 KST 2013 ----------------------------------------------------------------------------------------------- Operation Completed Operation Time: 00:00:09 ----------------------------------------------------------------------------------------------- ----------------------------------------------------------------------------------------------- Turn-on the Phone Goto 'Settings > Application > Development' And Check 'Usb Debugging' Then Connect Usb Cable To Phone And Install Needed Driver. ----------------------------------------------------------------------------------------------- Prepairing ...OK Device Found! Checking Root ...OK Phone Root OK. Continue.. Prepairing Phone ...Done! Rebooting... OK! Now Remove USB Cable and Wait Phone Powering Up Completely (Media Scanners Passed) Then insert UART cable to Phone to Continue Waiting for Phone... Searching for phone on COM6 ... Phone Found Reading Data from phone... Verifying ... OK Prepairing ... OK Repairing Network... OK OK Reset Done! But my phone still same no network 4.3 help me ASANSAM TEAM Last edited by dr_moosavi; 01-08-2014 at 16:36. |
The Following User Says Thank You to zahidpm786 For This Useful Post: |
01-08-2014, 12:55 | #3 (permalink) | ||
Product Manager Join Date: Apr 2013 Location: IRAN Age: 38
Member: 1911891 Status: Offline Thanks Meter: 6,241 | Quote:
or find not registered imei and write on phone | ||
01-08-2014, 16:33 | #4 (permalink) |
Member: 592531 Status: Offline Sonork: 100.1641625 Thanks Meter: 17 | ----------------------------------------------------------------------------------------------- Turn-on the Phone Goto 'Settings > Application > Development' And Check 'Usb Debugging' Then Connect Usb Cable To Phone And Install Needed Driver. ----------------------------------------------------------------------------------------------- Prepairing ...OK Device Found! Model : GT-I9300 Manufacturer : samsung Brand : samsung CPU info1 : armeabi-v7a CPU info2 : armeabi Serial No. : RV1C73SJ0GW Baseband Version : NULL GSM Baseband Version : I9300BUUGMJ3 Bootloader Version : I9300XXUGMJ9 Build Version : 4.3 Country : GB Language : en CID : NULL Build ID : JSS15J Time-Zone : Asia/Karachi IMEI : NULL IMSI : NULL Root User : se.infra Sales Code : VD2 Country Code : VD2 Built Date : Sat Oct 26 12:29:22 KST 2013 ----------------------------------------------------------------------------------------------- Operation Completed Operation Time: 00:00:09 ----------------------------------------------------------------------------------------------- ----------------------------------------------------------------------------------------------- Turn-on the Phone Goto 'Settings > Application > Development' And Check 'Usb Debugging' Then Connect Usb Cable To Phone And Install Needed Driver. ----------------------------------------------------------------------------------------------- Prepairing ...OK Device Found! Checking Root ...OK Phone Root OK. Continue.. Prepairing Phone ...Done! Rebooting... OK! Now Remove USB Cable and Wait Phone Powering Up Completely (Media Scanners Passed) Then insert UART cable to Phone to Continue Waiting for Phone... Searching for phone on COM6 ... Phone Found Reading Data from phone... Verifying ... OK Prepairing ... OK Repairing Network... OK OK Reset Done! THANKS FOR HELP |
