HUA GOLD Old BY HUA TEAM |
01-16-2014, 19:35 | #1 (permalink) |
Freak Poster Join Date: Nov 2008 Location: Jakarta Indonesia
Member: 896483 Status: Offline Thanks Meter: 95 | samsung s3 i9300 imei repair problem already solved now thanks Turn-on the Phone Goto 'Settings > Application > Development' And Check 'Usb Debugging' Then Connect Usb Cable To Phone And Install Needed Driver. ----------------------------------------------------------------------------------------------- Prepairing ...OK Device Found! Reading Phone Informations ... Model : GT-I9300 Android Version : 4.0.4 PDA Version : I9300XXBLH1 CS Version : I9300OLBBLH1 Phone Version : I9300DXLH1 IMEI : NULL Checking Root ...OK Phone Root OK. Continue.. Disabling Security ...Done! Rebooting... OK! Now Remove USB Cable then Insert Micro UART Cable to Phone to Continue.. Delay 40 Seconds... Searching for phone on COM5 ... Phone Found Reading Data from phone... Model : GT-I9300 S/W Version : I9300XXBLH1 Unique ID : CVTF1CBA40C349F Memory ID : - IMEI : corrupted!! MSL Addr : Õ²XÐÔsGÅUÓïLç Verifying MSL ... how to repair this thanks |
The Following User Says Thank You to gitamilana For This Useful Post: |
01-16-2014, 20:03 | #4 (permalink) |
Product Manager Join Date: Apr 2013 Location: IRAN Age: 38
Member: 1911891 Status: Offline Thanks Meter: 6,241 | You cannot repair imei when msl is damaged(write good efs and check again) |
The Following User Says Thank You to Asansam Box For This Useful Post: |
