HUA GOLD Old BY HUA TEAM |
02-19-2014, 10:12 | #3 (permalink) | |
Product Manager Join Date: Apr 2013 Location: IRAN Age: 38
Member: 1911891 Status: Offline Thanks Meter: 6,241 | Quote:
The Following 2 Users Say Thank You to Asansam Box For This Useful Post: |
02-19-2014, 16:25 | #4 (permalink) |
Freak Poster Join Date: Sep 2011 Location: venezuela Age: 37
Member: 1656305 Status: Offline Sonork: 100.1624503 Thanks Meter: 48 | Say it.. spt box.. Ive done that before.. even a wifi error too.. and i asked asansam support for help and they said "i think this is asansam support" they didnt help me.. and now just read my signature.. sent from my sm-n900 using tapatalk |
The Following User Says Thank You to vickcar13 For This Useful Post: |
02-19-2014, 16:41 | #5 (permalink) | ||
Asansam manager asansam not upported note3 models Quote:
The Following User Says Thank You to Asansam Box For This Useful Post: |
02-21-2014, 15:57 | #7 (permalink) | ||
02-21-2014, 17:40 | #8 (permalink) |
Freak Poster Join Date: Feb 2011 Location: mumbai Age: 31
Member: 1526620 Status: Offline Sonork: 100.1646327 Thanks Meter: 69 | Prepairing ...OK Device Found! Reading Phone Informations ... Model : SM-N900 Android Version : 4.4.2 PDA Version : N900XXUDNA6 CS Version : N900ODDDNA3 Phone Version : N900DDUDNA1 IMEI : NULL Checking Root ...OK Phone Root OK. Continue.. Disabling Security ...Done! Rebooting... OK! Now Remove USB Cable and Wait Phone Powering Up Completely (Media Scanners Passed) Then insert UART cable to Phone to Continue Delay 60 Seconds... Searching for phone on COM25 ...Fail! Phone not found! Operation Completed Operation Time: 00:03:05 |
02-21-2014, 17:49 | #9 (permalink) |
Member: 1911891 Status: Offline Thanks Meter: 6,241 | need use this cable GSMSP | Z3X BOX UART auto ignition Cable powered by GPGIndustries |
02-21-2014, 17:59 | #10 (permalink) |
Member: 1526620 Status: Offline Sonork: 100.1646327 Thanks Meter: 69 | com port setting in mobile mtp+adb any other setting or any other code for setting com port ?? *#7284# only blank screen *#08085# upper side ad & lower side mtp+adb *#9090# log via usb selected ...!! any other modification or any other codes settings???? |
02-21-2014, 18:02 | #11 (permalink) | |
Member: 1526620 Status: Offline Sonork: 100.1646327 Thanks Meter: 69 | Quote:
i use c3303 uart cable even i have 1 uart cable i got with asansam..!!! | |
02-21-2014, 18:06 | #12 (permalink) |
Member: 1911891 Status: Offline Thanks Meter: 6,241 | select model Type *#9090# and choose DM\DUM over HS-USB phone will reboot Type *#0808# and choose DM+MODEM+ADB* set phone modem in port setting or use interface port and rj45 cable(s7070 red only) enable use uart in asansam setting enter imei and press repair button |
02-21-2014, 18:40 | #13 (permalink) | |
Member: 1656305 Status: Offline Sonork: 100.1624503 Thanks Meter: 48 | Quote:
sent from my sm-n900 using tapatalk | |
02-21-2014, 19:01 | #14 (permalink) | ||
02-22-2014, 08:02 | #15 (permalink) |
Member: 1526620 Status: Offline Sonork: 100.1646327 Thanks Meter: 69 | after imei repair is there any chance for network ??? have u tested this??? i have tried but not getting on comport Prepairing ...OK Device Found! Reading Phone Informations ... Model : SM-N900 Android Version : 4.4.2 PDA Version : N900XXUDNA6 CS Version : N900ODDDNA3 Phone Version : N900DDUDNA1 IMEI : NULL Checking Root ...OK Phone Root OK. Continue.. Disabling Security ...Done! Rebooting... OK! Now Remove USB Cable and Wait Phone Powering Up Completely (Media Scanners Passed) Then insert UART cable to Phone to Continue Delay 60 Seconds... Searching for phone on COM25 ...Fail! Phone not found! Operation Completed Operation Time: 00:03:05 |
