HUA GOLD Old BY HUA TEAM |
01-18-2014, 08:30 | #1 (permalink) |
Junior Member Join Date: Jan 2014
Member: 2107430 Status: Offline Thanks Meter: 0 | usb asansam box[ANSWERED] I need some driver? Last edited by dr_moosavi; 01-21-2014 at 22:18. |
01-18-2014, 09:31 | #2 (permalink) |
Product Manager Join Date: Apr 2013 Location: IRAN Age: 38
Member: 1911891 Status: Offline Thanks Meter: 6,241 | Uart cable : buy this cable GSMSP | Z3X BOX UART auto ignition Cable powered by GPGIndustries usb cable:connected to pc and no need box |
01-18-2014, 10:01 | #3 (permalink) |
Member: 2107430 Status: Offline Thanks Meter: 0 | El problema no lo tengo con el cable UART. Me funciona correcto el problema esta con la conexion de USB al telefono, cuando conecto esta, es cuando no entiende la conexion y se pone a conectarse y desconectarse |
01-18-2014, 10:11 | #4 (permalink) |
Member: 2107430 Status: Offline Thanks Meter: 0 | I have no problem with UART cable. I work right the problem is with the USB connection on the phone, when I connect this is when one does not understand the connection and begins to connect and disconnect |
