05-28-2013, 13:39 | #2 (permalink) |
No Life Poster Join Date: Jul 2005 Location: zunZun Team Age: 43
Member: 166270 Status: Offline Sonork: 100.1579747 Thanks Meter: 12,673 | We not have yet C8600 firmware from movilnet . Please not try to repair meid yet, otherwise the proccess is not finished. I will inform here when i will get this flash. Also not try to flash with C8600 from China, you phone will result not power On. Need wait for the flash. We have original but is an recovery, you can try for yourself Best Regards zZ-Team |
05-28-2013, 14:48 | #4 (permalink) | |
Freak Poster Join Date: Sep 2007
Member: 593061 Status: Offline Thanks Meter: 19 | Quote:
05-28-2013, 19:21 | #6 (permalink) |
Member: 166270 Status: Offline Sonork: 100.1579747 Thanks Meter: 12,673 | Entren a las opciones con el telefono encendido, y estando el .zip puesto en la microsd, le dan update from sdcard, y ahi testean a ver y nos reportan aca. No hemos podido testear si dicho flash funciona bien. Esperemos por ustedes. Best Regards zZ-Team |
05-28-2013, 21:54 | #7 (permalink) |
Crazy Poster Join Date: May 2013
Member: 1948999 Status: Offline Sonork: 100.1657419 Thanks Meter: 3 | flash C8600 good afternoon engineer and tests were made with copy and backup as you indicated and still no solution is needed is the original flash movilnet C8600 (orinoquia) greetings |
05-29-2013, 19:30 | #12 (permalink) |
Registered User Join Date: Oct 2006 Location: Casanay
Member: 362751 Status: Offline Thanks Meter: 5 | Si porque la flash es esencial para flashear el tlf despues de reparar el mxxx, ya que si se hace asi, creo que el mxxx no cambia y se pierden los creditos. |
05-29-2013, 19:38 | #13 (permalink) |
Member: 166270 Status: Offline Sonork: 100.1579747 Thanks Meter: 12,673 | Asi es amigo tal cual he explicado en varias ocasiones, si no tienen la flash, no hacer el repair meid, pq los creditos se consumen y el proceso no finaliza. Best Regards zZ-Team |
