05-11-2014, 20:24 | #1 (permalink) |
Freak Poster Join Date: Aug 2008
Member: 837836 Status: Offline Thanks Meter: 7 | can flash huawei y210 by zzkey? this phone after flashing whit update.app by sd card dead no recovery o menu update but detect in pc can direct flashing zzkey this phone and other model huawei ? |
05-11-2014, 23:48 | #2 (permalink) |
No Life Poster Join Date: Jul 2005 Location: zunZun Team Age: 43
Member: 166270 Status: Offline Sonork: 100.1579747 Thanks Meter: 12,673 | Yes, is supported perfectly flashing with our zZKey, module: Huawei Advanced Tool, in pink screen. Best Regards zZ-Team |
The Following User Says Thank You to elcapitel For This Useful Post: |
05-13-2014, 10:17 | #3 (permalink) |
Member: 837836 Status: Offline Thanks Meter: 7 | My phone is completely dead. When connected to a computer known DBAdapter Reserved Interface But fastboot does not work Only 3 lights are off and down keys Is this a problem with zz-key solutions that do? |
05-13-2014, 14:19 | #4 (permalink) |
Member: 166270 Status: Offline Sonork: 100.1579747 Thanks Meter: 12,673 | If you can put in pink screen.. and is detected by your PC, then can flash perfectly with zZKey Try Vol- + Vol+ and connect usb cable w/o press power button. Best Regards zZ-Team |
05-14-2014, 16:17 | #6 (permalink) |
Member: 166270 Status: Offline Sonork: 100.1579747 Thanks Meter: 12,673 | If you cannt put in pink screen then need repair via jtag box, after repaired the you can repair imei with our zzkey. luck Best Regards zZ-Team |
05-15-2014, 07:59 | #9 (permalink) | |
Member: 837836 Status: Offline Thanks Meter: 7 | Quote:
05-15-2014, 14:41 | #10 (permalink) | ||
Member: 166270 Status: Offline Sonork: 100.1579747 Thanks Meter: 12,673 | Correct Firmware according to your region already sent to your pm. Try in force mode from sdcard: Quote:
Best Regards zZ-Team Quote: | ||
