12-08-2013, 16:41 | #1 (permalink) |
No Life Poster Join Date: Sep 2001 Location: Hungary, Pécs Age: 48
Member: 6142 Status: Offline Sonork: i dont use it Thanks Meter: 47 | Cant detect motorolaXT320 [Solved detection, XT320 not supported yet for imei repair] I cant detect xt320 with zzkey smart soft! Driver installed from support, no other soft run , usb debugging on but always failed not phone detect. I try to connect phone in flash mode , normal mode but no success. If i check it in device manager, phone detected as a Mot composite ADB interface. What can be wrong? |
12-08-2013, 17:45 | #2 (permalink) |
Freak Poster Join Date: Dec 2011 Location: In The New World With it/Colom Age: 44
Member: 1709174 Status: Offline Sonork: gokuu2011 Thanks Meter: 431 | º install correctly drivers click here http://d1tsx1og7dz7v4.cloudfront.net...ager_2.4.3.exe º phone connected in normal mode º what version SmarZ used you? º check post # 36 onwards, maybe this can help to you. http://forum.gsmhosting.com/vbb/f717...46/index3.html Last edited by zZKeyHelp; 12-09-2013 at 18:38. |
12-08-2013, 17:56 | #3 (permalink) |
No Life Poster Join Date: Jul 2005 Location: zunZun Team Age: 43
Member: 166270 Status: Offline Sonork: 100.1579747 Thanks Meter: 12,673 | By other way, phone need to connected normally without usb debugging ON. Also you can try to detect first with rsdlite, maybe some thing wrong in phone. After detected by rsdlite, close it, and try again with smartZ. Luck Best Regards zZ-Team |
The Following User Says Thank You to elcapitel For This Useful Post: |
12-08-2013, 21:22 | #4 (permalink) |
Member: 6142 Status: Offline Sonork: i dont use it Thanks Meter: 47 | First need to run rsdlite and close it after this zzkey software cant detect phone. Unlock operation is working , if i try to imei change i got: unsupported firmware! Thanks for help! |
