12-17-2013, 23:11 | #1 (permalink) |
Freak Poster Join Date: Sep 2011 Location: venezuela Age: 37
Member: 1656305 Status: Offline Sonork: 100.1624503 Thanks Meter: 48 | dead vtelca 8200?? |
12-17-2013, 23:39 | #2 (permalink) |
No Life Poster Join Date: Aug 2010 Location: Inside Logic Age: 37
Member: 1377783 Status: Offline Sonork: 100.1611724 Thanks Meter: 3,336 | Hi, bro, what was the reason of that problem??? Could you turn on the phone??? try to charge full your battery, then try to turn on the phone into recovery mode, if you have CWM recovery on your cell, you can reinstall original soft on the device by a previous backup, just get into recovery mode, select install from zip from external SD, just wait and that's it, this is just a clean backup of the cellphone without modifications, there is not yet official firmware release of this device.... Try and put results please.... |
12-17-2013, 23:49 | #3 (permalink) |
Member: 1656305 Status: Offline Sonork: 100.1624503 Thanks Meter: 48 | The owner killed it The owner was trying to get a new custom rom with no luck of course.. I will try to fix it tomorrow, ill post results.. |
12-17-2013, 23:56 | #4 (permalink) |
Member: 1377783 Status: Offline Sonork: 100.1611724 Thanks Meter: 3,336 | ok maybe he stop the process, and for this, he installed CWM before, so, just reinstall backup from that recovery wait and that's it! I'll be waiting bro!!! Remember press THX button!!! |
12-18-2013, 03:07 | #5 (permalink) |
Freak Poster Join Date: Aug 2011 Location: California, LA,USA
Member: 1639385 Status: Offline Sonork: 100.1594605 Thanks Meter: 212 | Probably only a factory rom can help u, we dont have any and it's not available too in zte vip server. So at this time you only can read a working phone via jtag and write the full dump in the dead one. |
12-18-2013, 03:49 | #7 (permalink) |
Member: 1639385 Status: Offline Sonork: 100.1594605 Thanks Meter: 212 | I think that some cheap chinesse jtag box (openocd ....) with support qcom emmc will work, but i don't have any chinnesse jtag box in hand,. I use professional one, so you can try to catch and find rigth pinout first. After try with any that you have. |
12-18-2013, 04:07 | #8 (permalink) |
No Life Poster Join Date: Jul 2005 Location: zunZun Team Age: 43
Member: 166270 Status: Offline Sonork: 100.1579747 Thanks Meter: 12,673 | Search some jtag tool supported MSM8225 qualcomm cpu. In internet sites talking about MSM8225, but maybe is MSM7627, anyway you can see exact cpu model when open it the phone. The pinout also you need search with "jtag finder". Maybe emmc is damaged. Luck... First you try @Shensohau suggestion. Best Regards zZ-Team |
12-18-2013, 18:03 | #10 (permalink) |
Member: 1656305 Status: Offline Sonork: 100.1624503 Thanks Meter: 48 | well.. phone cant get into recovery mode... it just keeps vibrating hard... nothing else! i dont have any jtag finder... phone stills dead.. thanks for your support.. |
12-18-2013, 18:15 | #11 (permalink) |
Member: 166270 Status: Offline Sonork: 100.1579747 Thanks Meter: 12,673 | You can try to find the jtag pinout by other method. Start posting here photos with good quality of phone pcb with the shields removed. --------------- Puedes usar otro metodo. Empieza por postear aca fotos de la placa de tu V8200 en buena calidad, con el blindaje removido. de ambos lados. Si tienes suerte el pinout no es de los muy dificiles. En ese caso si lo logras, como sugiere @zz_coder, leer el dump de uno bueno, y escribirselo a ese malo que tienes. Por desgracia ese emmc de tu telefono es de la peor calidad, puede haberse danado tambien porque la bateria se descargo totalmente u otro motivo. Suerte Best Regards zZ-Team |
12-18-2013, 18:29 | #12 (permalink) |
Member: 1377783 Status: Offline Sonork: 100.1611724 Thanks Meter: 3,336 | Bro maybe your battery is drainned out, please dissambling the cellphone, put the battery on a external charger for full charge, then put it on the phone again and try to get into recovery mode, remember, recovery mode is press on/off power button until the phone start vibrating then release the button and press quickly Volume UP until the phone get into recovery mode, try and post resuts please |
