08-15-2012, 21:43 | #16 (permalink) |
No Life Poster Join Date: Jul 2005 Location: zunZun Team Age: 43
Member: 166270 Status: Offline Sonork: 100.1579747 Thanks Meter: 12,673 | How Unlock ZTE Z990 with zZKey Open zZ_Android module Click in Connect and after in Unlock. Very easy, you can unlock ur ZTE android in less than 3 seconds. thanks to @Lerouxito for image Best Regards zZ-Team |
The Following User Says Thank You to elcapitel For This Useful Post: |
09-08-2012, 22:03 | #17 (permalink) |
No Life Poster Join Date: Mar 2009 Location: Ecuador/Android
Member: 1001831 Status: Offline Sonork: 100.1594557 Thanks Meter: 1,405 | Solution: "err:[]: Failed Running flash in phone." When you have this problem, the simple solution would be to copy the files to the partition on which you installed the ZZKEY for example if the files on the disc D and the C program will have to copy the files to the C drive to work and so and will solve your problem Br MichaGSM |
The Following User Says Thank You to MiChAGSM For This Useful Post: |
09-11-2012, 20:52 | #18 (permalink) |
Member: 1001831 Status: Offline Sonork: 100.1594557 Thanks Meter: 1,405 | Error: Code: Hardware ID Mismatch. OS Hardware ID: 0x15001507, Bootrom Hardware ID: 0x04001507 --> Error during check of OS against bootrom. Done. Error: This OS does not match this device! Operation Finished. Here I show that the error: 0x15001507 = 9780 Correct: 0x04001507 = 9700 100% Flashing by ZZKEY Hardware ID ... Blackberry models 0x04000B06 6210 0x80000503 6220 0x90000503 6230 0x90000503 6280 0x94000503 7230 0x94000503 7280 0x86000D03 8105 0X8D000D03 8120 0x04000D04 8130 0x04000F04 8330 0x84000B03 8705 0x0E000F03 9220 0x14000F04 9310 0x05000F07 9320 0x0C000F04 9370 0x04002207 9380 0x17001404 9570 0x17001507 9788 0x26001507 9790 0x0C001804 9810 0x16001404 9850 0x1D001404 9860 0x07001204 9900 0x05001204 9930 0x94000903 7100 GSM Charm 0x04000905 7100i iDEN Charm 0x84000903 7130c EDGE Charm 0x04000904 7130e CDMA Charm 0x1C000504 7250 CDMA Photon 0x9C000503 7290 GSM Photon 0x04000505 7510 iDEN Baryon 0x1C000505 7520 iDEN Baryon 0x84000D03 8100 GSM Positron 0x8F000D03 8110 GSM Lancer 0x06000D04 8130m 0x04000D04 8130v 0x8D001103 8220 GSM KickStart 0x04001104 8230 CDMA Apex 0x06001104 8230m CDMA Apex 0x96000F03 8300 GSM BabyBear 0x8D000F03 8310 GSM PapaBear 0x84000F03 8320 GSM MamaBear 0x04000F04 8330 CDMA Jupiter 0x06000F04 8330m CDMA Jupiter 0x84000F05 8350 iDEN Orion 0x85000F03 8500 GSM Gemini 0x87000F03 8510 GSM Gemini 0x8C000F03 8520 GSM Gemini 0x05000F04 8530 CDMA Aries 0x07000F04 8530m 0x84000B03 8700 Electron 0x04000B04 8703e CDMA Electron 0x84000B07 8707 UMTS Electron 0x84000E03 8800 GSM GammaRay 0x8D000E03 8820 GSM DeltaRay 0x04000E04 8830 GSM/CDMA Saturn 0x06000E04 8830m GSM/CDMA Saturn 0x84001503 8900 GSM Javelin 0x86001503 8910 GSM Harpoon 0x85001503 8980W AtlasW 0x84000E07 9000 UMTS Meteor 0x05000D07 9100 Stratus 0x04000F07 9300 R011 0x0E000F04 9330 CDMA R014 0x0C000F04 9350 Sedona 512 0x0E001507 9360 Apollo 0x06001404 9500 GSM Thunder 0x0E001404 9520 (No DRM) 0x0D001404 9520 GSM Odin 0x04001404 9530 CDMA Thunder 0x0C001404 9550 CDMA Odin 0x0D000D04 9630 World Niagara 0x16000D04 9630m World Niagara 0x05001504 9650 World Essex 0x07001504 9650 World Essex 512 0x05001904 9670 CDMA R004 0x04001507 9700 UMTS Onyx 0x15001507 9780 Bold R020 0x05001807 9800 Talladega 512 0x0F001404 Monaco 0x04001204 Montan 0x07001807 Noble 0x0C001204 P9981 0x05001A06 PlayBook R031 0x1E001507 R016 0x1C001404 R028_512 0x05002204 R033_512 0x0C001503 R034 0x01002106 R035 0x07001804 R040_512 0X04001A0B R041 0x02002106 R042_8GB 0X04002307 R061 0x0f000f04 R064_512N 0x05001507 REDWOOD 0x84001203 REVELSTOKE 0x24001507 Rutherford A 0x25001507 Rutherford B 0x0D000F04 Sedona256 0x14001507 Sprucewood 0x1D001507 STERLING 0x04001807 TALLADEGA 0x0D001507 TEAKWOOD 0x0C001807 Tedeschi 0x97001404 WILLOW 0x06001A06 Winchester Wifi R036 0X04001A0B Winchester2 HSPA R053 0X04001A0B Winchester2 LTE CDMA R051 0X04001A0B Winchester2 LTE HSPA R052 Br MichaGSM Last edited by elcapitel; 11-10-2012 at 20:06. |
The Following 10 Users Say Thank You to elcapitel For This Useful Post: |
10-09-2012, 01:11 | #20 (permalink) | |||||
Member: 166270 Status: Offline Sonork: 100.1579747 Thanks Meter: 12,673 | Nokia C2-02.1 Infineon Xgold213 full repaired with zZKey and notepad Here Operation Log: This C2 was damaged with free software, trying to reset counter... Here step by step how to repair with zZKey & Notepad Read Info with damaged simlock: Quote:
pm120,0 damaged: Quote:
If you have any Infineon with contact service, by failed attempt counter resets, and you can not fix it with this guide. Contact us, we will gladly help you. Best Regards zZ-Team | |||||
10-10-2012, 14:33 | #21 (permalink) |
Member: 166270 Status: Offline Sonork: 100.1579747 Thanks Meter: 12,673 | How Unlock ZTE Blade (ZTE San Francisco) with zZKey FTM mode (Field Test Mode) With the phone turned off, press VOLUME DOWN + End Call + Power key, You will see: Open zZ_qZcom module. Click in Connect and after in Unlock. Best Regards zZ-Team |
The Following 2 Users Say Thank You to elcapitel For This Useful Post: |
11-09-2012, 15:29 | #22 (permalink) |
Member: 166270 Status: Offline Sonork: 100.1579747 Thanks Meter: 12,673 | Install any language in your Mobile Android Just Open Google Play Store and to search MoreLocale 2 and install for free. This post is with the intention the small guide, for install any language that you want, after flashed your Huawei with our flashes. Tested by me in Huawei U8650, U8150 and others. Also can use in any Android mobile like Samsung, HTC, etc Best Regards zZ-Team |
The Following 7 Users Say Thank You to elcapitel For This Useful Post: |
12-25-2012, 02:59 | #23 (permalink) |
Freak Poster Join Date: Dec 2011 Location: In The New World With it/Colom Age: 44
Member: 1709174 Status: Offline Sonork: gokuu2011 Thanks Meter: 431 | Flash Huawei u7520 U7520 - Download - 4shared Please follow this steps. 1. Flash u7520 2. Connect phone with zz android 1.01 3. Replug cable usb. special thanks to Mr COVVA Last edited by zZKeyHelp; 12-25-2012 at 03:07. |
The Following User Says Thank You to zZKeyHelp For This Useful Post: |
01-18-2013, 02:10 | #24 (permalink) |
Member: 166270 Status: Offline Sonork: 100.1579747 Thanks Meter: 12,673 | zZKey IMEI repair .::Credits consuption::. zZKey Huawei Phones IMEI repair credits consuption: -------------------------------------- FREE Ascend G300 - U8815 - U8818 Ascend G301 - U8816 - MTC VIVA Ascend G330 - U8825 Ascend G330D - U8825D Ascend G506 Ascend G510 - Orange Daytona - U8951 Ascend G600 - U8950-51 - U8950D - Glory+ Ascend P1 TD - T9200 Ascend Y100 - U8185 Ascend Y101 - U8186 Ascend Y200 - U8655 - SFR StarTrail 2 Ascend Y201 - U8666 Ascend Y201 Pro - U8666E - U8666N Ascend Y210 - U8685D Ascend Y300 - U8833 U8100 - U8100-5 - U8100-7 - U8100-9 - IVY U8110 - T-Mobile Pulse Mini - Pulse Mini - Selina - MTC Android - MegaFon spoofcard U8110 U8120 - Vodafone 845 - V845 - Joy U8150 - Ideos - T-Mobile Comet U8160 - Vodafone 858 Smart - MTC Mini - MTC 950 U8180 - Orange Stockholm - T-Mobile Rapport - Ideos X1 - Gaga - Smart Netphone 501 - Kyivstar Terra U8220 - T-mobile Pulse - CHT8000 U8230 - TMN A1 - MegaFon U8230 U8300 - Ideos Chat U8350 - Boulder - Orange Barcelona - MTC Pro U8500 - Ideos X2 - Beeline E300 - HiQQ - MTC Evo U8510 - Ideos X3 - Blaze U8600 - T-Mobile Move Balance - Telekom Move U8650 - Sonic - Turkcell T20 - MTC 955 - Kyivstar Aqua U8651S - Summit U8651T - T-Mobile Prism - Astro - Talon U8652 - ATT Fusion U8665 - ATT Fusion 2 U8660 U8661 - Sonic Plus U8687 - Cronos UM840 2 Credits: U1250 - MTC 733 U1251 U1259 U1270, MegaFon U1270 U1280 U1280E U1285 U1290, INQ B1, INQ B1-200H U1860 U3100, Stone+, Le Classique U3100-d U3200 U3200-9 U3200-S U3205 U3300 U3305 U3307 U3310 U3311 U3315 U6100 U7300 U7315 U7510, i-Mobile 6530 U7510-o U7510-s U7515 U7517 U7519, T-Mobile Tap U7520 U7520-D U9100 U9105 U9120 U9130 V735 V736 V835 V840 4 Credits: CDMA Ascend M860 CDMA C8150 CDMA C8511 CDMA C8512 CDMA C8600 - Orinoquia C8600 6 Credits: Ascend G312 - U8680 - T-Mobile myTouch - Phoenix Ascend G312 Q - Unite Q - T-Mobile myTouch Q - U8730 - Buddy CDMA Ascend G300C - C8810 CDMA Ascend II - M865 - M865C CDMA Ascend Y210C - C8685D CDMA CM980 - Evolution2 Mediapad S7-101 Mediapad S7-103 Mediapad S7-104 - Telstra T-Touch Tab Mediapad S7-105 - Orange Tablet Mediapad S7-106 Mediapad S7 Slim - S7-201u Mediapad S7 Slim - S7-201w U8667 - Ares U8681 U8800 - Ideos X5 - Impulse 4G U8800_Pro - Ideos_X5_Pro U8820 - Titan U8860 - Honor - Koko U8860-R U8867z Via Plataform: Huawei Android Adb Phones (4 Credits IMEI Repair) Ascend G300 - U8815 - U8818 Ascend G301 - U8816 Ascend G312 - U8680 Ascend G312 Q - U8730 Ascend G330 - U8825 Ascend G330D - U8825D Ascend G350 Ascend G506 Ascend G510 - Orange Daytona - U8951 Ascend G520 Ascend G525 Ascend G526 Ascend G527-U081 Ascend G600 - U8950 - U8950D Ascend Y300 - U8833 Ascend Y301-A1 - Valiant U8665 - ATT Fusion 2 U8667 - Ares U8681 U8686 - Prism II U8687 - Cronos U8800 - Ideos X5 U8800_Pro - Ideos_X5_Pro U8820 - Titan U8860 - Honor - Koko U8860-R U8867z Via Plataform: Huawei Android Adb Phones (8 Credits IMEI Repair) CM990 - Evolution 3 Honor CDMA - C8860v ---------------------------------------------- zZKey Huawei Modems IMEI repair credits consuption: * All models actually supported are for FREE IMEI repair (1 second, No flash required) ---------------------------------------------- zZKey Alcatel Phones IMEI repair credits consuption: * All models actually supported need 4 credits IMEI repair (3 seconds, No flash required) Alcatel OT-908 Alcatel OT-908F Alcatel OT-909 (One Touch MAX) Alcatel OT-910 Alcatel OT-980 Alcatel OT-981 Alcatel OT-A909 Alcatel OT-A990 Alcatel OT-C908 Alcatel OT-C990 Alcatel OT-MOVE Alcatel OT-V958 ---------------------------------------------- zZKey Motorola Phones IMEI repair credits consuption: * All models actually supported need 4 credits IMEI repair (1 second, No flash required) Motorola A956 (Droid 2) Motorola MB200 (Cliq) Motorola MB220 (Dext) Motorola MB300 (Backflip, Motus, Enzo) Motorola MB501 (Cliq XT, Quench) Motorola MB612 (XPRT) Motorola MB853 (Electrify) Motorola MB855 (Photon 4G) Motorola MB860 (Atrix 4G, Olympus) Motorola MB861 Motorola ME501 (Moto Mix, Quench) Motorola ME600 (Motus) Motorola MT870 Motorola MZ601 (XOOM 3G) Motorola MZ603 (XOOM 3G) Motorola MZ605 (XOOM 3G) Motorola XT300 Motorola XT609 (Milestone Plus) Motorola XT610 (Pro, Elway) Motorola XT882 (Moto) ------------------------------------------------ zZKey ZTE Phones IMEI repair credits consuption: * All models actually supported are for FREE IMEI repair (1 second, No flash required) ---------------------------------------------- zZKey ZTE Modem IMEI repair credits consuption: * All models actually supported need 2 credits for IMEI repair (1 second, No flash required) ---------------------------------------------- 20 zZKey credits = 20 usd (paypal masspay) or (21 usd paypal +5%) paypal id: [email protected] .... also our Distributors/Resellers with zZKey Credits in stock. Best Regards zZ-Team Last edited by elcapitel; 05-24-2014 at 03:03. Reason: added new models (23-04-2014) |
02-01-2013, 23:39 | #25 (permalink) |
Member: 166270 Status: Offline Sonork: 100.1579747 Thanks Meter: 12,673 | Here relation PRD<>MEP of some PRD not found in zZBBFactory.v0.7 Here relation PRD<>MEP of some PRD not found in last zZBBFactory.v0.7 PRD-07109-002 -> MEP-04598-004 PRD-09291-001 -> MEP-04104-006, MEP-04104-005 PRD-09855-009 -> MEP-06813-001 (8700v Vodafone/Spain) PRD-11300-012 -> MEP-06814-004 PRD-11929-001 -> MEP-04104-006, MEP-04104-007 PRD-11929-019 -> MEP-06423-001, MEP-06424-002 PRD-11929-037 -> MEP-10073-001 PRD-11929-043 -> MEP-06041-005, MEP-06041-008 PRD-11929-046 -> MEP-08918-001 PRD-12528-031 -> MEP-07723-005, MEP-07723-003 PRD-12528-169 -> MEP-24124-001, MEP-24124-007 PRD-14399-047 -> MEP-06041-006, MEP-06041-008 PRD-17116-013 -> MEP-07723-005, MEP-07723-004 PRD-17116-014 -> MEP-07723-004, MEP-07723-003 PRD-17116-028 -> MEP-09292-001, MEP-09292-004 PRD-17116-123 -> MEP-11534-008, MEP-04103-001 PRD-17491-002 -> MEP-06814-004, MEP-04103-001 PRD-18777-031 -> MEP-12209-003, MEP-12209-008 PRD-19502-002 -> MEP-15326-001, MEP-04103-001 PRD-20973-088 -> MEP-06041-010, MEP-04103-001 PRD-21009-002 -> MEP-15326-001, MEP-04103-001 PRD-22578-072 -> MEP-11534-008, MEP-30669-001 PRD-25578-072 -> MEP-30669-001 PRD-27486-036 -> MEP-09292-004, MEP-04103-001 PRD-27603-064 -> MEP-11534-008, MEP-12209-008 PRD-30001-081 -> MEP-06041-008, MEP-06041-017 PRD-30001-213 -> MEP-06041-012, MEP-06041-017 PRD-30137-057 -> MEP-42517-001 PRD-30380-015 -> MEP-06041-012, MEP-06041-017 PRD-30609-020 -> MEP-09292-004, MEP-04103-001 PRD-31024-001 -> MEP-15326-002, MEP-04103-001 PRD-31523-001 -> MEP-30638-001 PRD-31523-002 -> MEP-09938-001 PRD-31523-003 -> MEP-04103-001 PRD-34746-001 -> MEP-04103-002 PRD-38860-045 -> MEP-29080-002, MEP-29080-003 PRD-39091-019 -> MEP-07723-007 (Orange BB9380) PRD-39473-101 -> MEP-04598-007, MEP-04598-005 PRD-41625-016 -> MEP-04598-005 (ATT BB9380) PRD-41629-004 -> MEP-04626-002 PRD-44208-002 -> MEP-12209-010 (Claro BB9790) PRD-44242-097 -> MEP-11016-001 (Personal BB9790) PRD-44242-125 -> MEP-24409-002 (Movilnet Venezuela BB9790) PRD-44243-043 -> MEP-04103-001 (BB9790) PRD-44244-091 -> MEP-29080-003 PRD-44518-003 -> MEP-10129-005 PRD-44518-004 -> MEP-14896-005, MEP-14896-006 PRD-44518-047 -> MEP-06041-017 (BB9320) PRD-44518-051 -> MEP-34870-002 (Telus BB9320) PRD-44518-059 -> MEP-09625-003, MEP-04103-001 PRD-44518-075 -> MEP-12209-010 PRD-44518-089 -> MEP-11534-010 PRD-44519-030 -> MEP-11534-010 PRD-44519-081 -> MEP-11534-010 PRD-44519-093 -> MEP-34723-001 PRD-44748-065 -> MEP-20669-001 PRD-46871-019 -> MEP-12209-010 (Claro BB9320) PRD-46871-020 -> MEP-06041-017 (Movistar BB9320) PRD-46871-046 -> MEP-09625-003 (BB9320) PRD-46872-045 -> MEP-07723-007 PRD-46872-049 -> MEP-42517-001 PRD-49028-017 -> MEP-12209-010 PRD-49557-001 -> MEP-04104-008, MEP-04104-009 (T-Mobile BB9315) If you have another PRD that is not in our latest version of zzBB or here, please let us know, we will help you Best Regards zZ-Team Last edited by elcapitel; 04-11-2014 at 00:22. Reason: add more PRD (10-04-2014) |
The Following 11 Users Say Thank You to elcapitel For This Useful Post: |
04-28-2013, 03:00 | #27 (permalink) |
Member: 166270 Status: Offline Sonork: 100.1579747 Thanks Meter: 12,673 | Huawei U8220 "Failed Initializing Loader" solved (steps here) Huawei U8220 "Failed Initializing Loader" solved (steps here) - If you trying to connect any U8220 and see an error in our zZ_Huawei_Module: "Failed Initializing Loader" This mean you have old Android_1.5. Solution is easy, only need install any U8220 stock rom android 2.*, This for example is Ok: U8220_V100R001C125B222(Android_2.1)(General) - If phone not accept the flash, just install TimeMachine(OK)... after try install flash again After flashed, you can connect with our zZ-Huawei module for any operation, like unlock, repair simlock, repair imei, etc. Best Regards zZ-Team Last edited by elcapitel; 04-28-2013 at 03:05. |
05-15-2013, 22:30 | #28 (permalink) |
No Life Poster Join Date: Nov 2008
Member: 904826 Status: Offline Sonork: 100.1603284 GeorgeEcuador Thanks Meter: 580 | Engineering mode 9860, 9380 touch.. To get the Help mode and engineering mode such as 9860, 9380 is this: hold down the BACK arrow and tap the screen in these areas: Corner TOP LEFT, Corner TOP RIGHT, Corner TOP LEFT, Corner TOP RIGHT. Have the help mode. Regards.. |
The Following User Says Thank You to GeorgeEcuador For This Useful Post: |
08-16-2013, 02:26 | #29 (permalink) |
Freak Poster Join Date: Jan 2007 Location: DUBAI/UAE
Member: 430770 Status: Offline Sonork: 100.1611576 Thanks Meter: 238 | Exclusive Firmware for Arabic Countries HUAWEI U8860 HONOR Android2.3 Exclusive Original Firmware for Arabic Countries HUAWEI U8860 HONOR Android v2.3 U8860_Firmware_Android_2.3_V100R001C250B863(United _Arab_Emirates_IMS) Thanks goes to my friend : elcapitel Regards, Tamer SiLver |
09-20-2013, 00:12 | #30 (permalink) |
Freak Poster Join Date: Mar 2007 Location: ARGENTINA
Member: 472354 Status: Offline Sonork: 1580747 Thanks Meter: 67 | See your MEP without cable! 1 - In the phone hold the following keys : ALT CAPS H (at the same time) 2 - Type the PIN, App Version and Uptime in the form below: Blackberry eScreen keygen And press GET MY KEY 3 - Now simply type the KEY directly on to that screen. 4 - Go to "OS ENGINEERING screens" -> "Device Info" & scroll down until you see the MEP =) After that you can unlock all blackberry only with the phone and ZZ-KEY without cable!!! |
Questions about Dejan's flasher interface | SashaM | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 9 | 01-15-2001 09:31 |
8890 questions | spongebob | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 01-10-2001 01:04 |
I have that soft if smb need ask for testing.. | Nec | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 04-01-2000 23:47 |
Silly question!! Why is it impossible to read out the mastercode of Nokia phones???? | MyKe | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-26-1999 14:31 |
Question about 51xx/61xx | Comic | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-06-1999 23:47 |
