09-30-2016, 12:25 | #1 (permalink) |
Junior Member Join Date: Feb 2011
Member: 1506907 Status: Offline Thanks Meter: 4 | help htc imei repair [SOLVED] Executing operation Writing new imei: 354711051252306 ... SecuritySDInit: counter = 3 eyeul_init_sd, SD card already power on [SPEW] GPIO 0 status is 0 sdhci_open: id=0 Initializing MMC host data structure and clock! mmc slot#2 clock enabled sdhci_set_clock: slot 2, freq 192000000 GPLL0 is enabled clock_update_cfg_sd is done sd clock set done sdhci_set_bus_width: bus width 0 sdhci_clk_supply: freq 400000 Decoded CID fields: Manufacturer ID: 0 OEM ID: 0x0 Product Name: 00000 Product revision: 0.0 Product serial number: 10A5 Manufacturing date: 5 2016 sdhci_clk_supply: freq 50000000 sdhci_set_bus_width: bus width 1 Done initialization of the card erase_grpsize: -16777216 erase_grpmult: 261078256 wp_grpsize: 0 wp_grpen: 0 perm_wp: 0 temp_wp: 0 [Tuxera][Error] No exFAT partition found [JAVACARD_ERR] Javacard reset response timeout C= 1000. writeimei: Permission denied, value 2 OKAY [ 3.649s] finished. total time: 3.649s |
09-30-2016, 17:07 | #2 (permalink) | |
No Life Poster Join Date: Jul 2005 Location: zunZun Team Age: 43
Member: 166270 Status: Offline Sonork: 100.1579747 Thanks Meter: 12,673 | You need do S-OFF first.. phone power ON, correctly rooted. Select the correct model from list, and do click in SET SOFF from SmartZPRO module. Best Regards zZKey Team Quote:
The Following User Says Thank You to elcapitel For This Useful Post: |
