01-16-2014, 15:12 | #1 (permalink) |
No Life Poster Join Date: Aug 2010 Location: Inside Logic Age: 37
Member: 1377783 Status: Offline Sonork: 100.1611724 Thanks Meter: 3,335 | How to ROOT Huawei Android Devices Supported by ZZkey 1-Click Root Method and More VRoot 1.7.2 - 1-Click Root Method Mostly All Android Phone not matter Which Brand and Which Model Supported devices:Lot of devices up to Android 4.x (4.0~4.3) Download This: VRoot This Software is totally made in chinese language, I will explain you Installation procedure Step by Step Next. Don't create start menu. (or as you wish) Create desktop icon. Finish. Uncheck if you dont want to start the rooting app inmediately. Finally, Open Software and Connect Phone (please, phone must be in USB Debug Mode, Remember Enable USB Debug in Options Menu in your Device) After that, click on Root Button, during root process phone will be restarted **Note: After ROOT superuser will be display in English language not in chinese, If you don't like the SU app, download or install your own app from Store and uninstall the previous one, remember guaranted root access in order to install or uninstall a SU app** **There are some Huawei devices that require Unlock Bootloader Before ROOT, so if you are the owner of one of this models please posted it.(only supported models)** If you have alternative methods for root please posted it and thread will be edited in order to put suggested methods by Users |
The Following 4 Users Say Thank You to Shensohau For This Useful Post: |
01-16-2014, 15:42 | #2 (permalink) |
No Life Poster Join Date: Jul 2005 Location: zunZun Team Age: 43
Member: 166270 Status: Offline Sonork: 100.1579747 Thanks Meter: 12,673 | Cydia Impactor Tested in Huawei U8686 (Prism II) It can work perfectly in other Huawei models Best Regards zZ-Team |
The Following User Says Thank You to elcapitel For This Useful Post: |
01-19-2014, 01:11 | #5 (permalink) |
Member: 1377783 Status: Offline Sonork: 100.1611724 Thanks Meter: 3,335 | Hi, again with new root mehod this time for Huawei P1 LTE version uawei Ascend P1 LTE - U9202L, tested on Huawei P1 LTE DiGITEL VE First, Download this: MOTOCHOPPER **Please Before continue Disable Antivirus Software first** Remember activate USB Debug Mode on Device Menu before plug the phone into usb port (the phone contain preloaded Hisetup software for Huawei device in a phone small partition) Once the phone is detected and installed correctly, the phone will be recognized as ADB Interface Device in Device Manager Menu of PC Now, Unzip the content in a carpet, and just execute the file "Run.Bat" [IMG] Just press ENTER key in your Keyboard, wait until phone restart and that's it! Yeah! So easy, right? Now you are done for operations with Zzkey Huawei Module!!! |
02-16-2014, 19:03 | #6 (permalink) |
Member: 1377783 Status: Offline Sonork: 100.1611724 Thanks Meter: 3,335 | How to Root Huawei CM990 Evolucion 3 1. Download the software "KINGO ROOT" to your PC. KinGO Root (Press or Push on the name to download the software) 2.- Once it has been donwloaded and installed on your PC, you will see a Icon on your desktop to Run the Software (start it as administrator): 3.- Select "Options" in your phone Huawei CM990 Evolución 3 and into the system menu push on "Developer Menu" and activate. Then select "USB Debug Mode" 4.- Run the software "Kingo Android ROOT" and connect your Huawei CM990 Evolución 3 with your USB cable to your PC USB port. The software will Start to make a series of rutines in order to install the correct drivers. 5.- After Install the drivers, you will see a screen with a message showing that tha the software recognized your Huawei CM990 correctly and it will be waiting for your answer in order to "ROOT" your phone, push on the button "ROOT". http://www.elconesvida.net/images/st...ararootear.png 6.- The software will start to root your phone, please be pacient, it will show you a message after finish. 7.- Push on the button "Finish" and your phone will be "rooted". the phone will restart ad will be done to start the "SuperSU" app. Yeah! So easy, Right? Now you are done again for operations with Zzkey Huawei Module!!! |
02-24-2014, 03:54 | #7 (permalink) |
Member: 1377783 Status: Offline Sonork: 100.1611724 Thanks Meter: 3,335 | Root Huawei C8860V "Honor" Step #1. We must download the following file from here: Poot.apk Put the file into your SD memory, go to your file explorer and install the APK file. Please Be Sure that Unknow Sources is checked or activated. Follow the tabs on your Huawei: Options > Applications > Check the box "Unknow Sources" Step #2. Onced installed, start the app POOT. It ask us for a file called "Ministro II" from Play Store, accept and download the file. Then go "Back" and into the app POOT we will see the following (Pic1). Please choose the option “Press here to poot“. It will drive us to PlayStore for download the app Superuser. When Superuser finish to download and install, start it and go to the tab “info”. There you will see the green color codes that confirm superuser access. and if your curious you will see uninstall it temporally (in case of warranty). Now you are officially ROOT. Yeah! So easy, Right? Now you are done again for operations with Zzkey Huawei Module!!! |
The Following User Says Thank You to Shensohau For This Useful Post: |
