-   zZKey (http://forum.gsmhosting.com/vbb/f717/)
-   -   How To Solve Some Huawei Phone EMMC Read Only and Update Fails (http://forum.gsmhosting.com/vbb/f717/how-solve-some-huawei-phone-emmc-read-only-update-fails-1936289/)
Shensohau 04-09-2015 10:06
http://i61.tinypic.com/2645nyf.jpg
Hi, here again with some useful guide for zzkey users in order to solve common problems of flashing with some Huawei Devices like Y300 and G510...
Requeriments:
-Huawei Device with EMMC Read Only or Constantly Update Fails Message
-BootLoader Unlock Code. Request it (Here)
-Device Drivers (Here)
-ADB Toolkit (Here)
-Device Firmware (Here)
1.Step
Be sure that your can access to your device by fastboot mode, some cases if you can't acess, your Device EMMC is Broken(only fixeable by replacing it)
To connect turn off the phone. Press and hold Vol- and Power buttons to enter fastboot mode(hold it by 4 seconds) and connect USB cable to your PC. To Avoid issues with your O.S download the drivers given.
https://www.dc-unlocker.com/images/t...images/428.png
2.Step
Extract the content of the folder "ADB Toolkit" into C:/ (Recomended), also if you extract it anywhere in your pc you need open a CMD command prompt inside it, Just Press RightShift+RightMouseButton and you will see the option like this:
http://i59.tinypic.com/wbrybk.jpg
3.Step
Check that the device is connected to computer properly. To do so, please write: fastboot devices, and press Enter, if a message such as you will see in the picture is displayed, the connection is set up properly.
http://i58.tinypic.com/2lue4p1.jpg
4.Step
Type the fasboot unlocking command, fastboot oem unlock XXXXXX, for example, fastboot oem unlock 2506322222068147
http://i62.tinypic.com/29bref.jpg
After unlock, your device will restarts and get into recovery mode, performing some operations related to bootloader and wiping your device data (Be Sure that you previously Backup it)
5.Step
To check bootloader's lock status simply enter “fastboot oem get-bootinfo” in command window as a follow and you will see the following:
http://i62.tinypic.com/1552g7r.jpg
6.Step
In order to solve some EMMC or Update Failed problem related to Y300 or G510 contact us or request us about that after follow this guide!!!
Best Regards
zZKey-Team
Shensohau 04-12-2015 16:20
Hi, please check our section about firmware request(here) I will send you correct firmware version in order to solve your issue, if EMMC memory is not damage(hardware)
roberth780 05-06-2015 15:57
this problem continue in y300-0151 device, last to guide... help!!!
elcapitel 05-06-2015 16:03
The Guide is perfectly ok in first post. So, please read carefully.
Best Regards
zZKey Team
crazygenius3 05-07-2015 11:05
I have Huawei G510-0200 when i try to Flash Via SD Card it always Update Failed then i got Exact firmware from zZkey Team then i Unlock Bootloader
I have Done All Process
But Problem is same
kindly help me in this matter
how can i solve this
here is LOG:
C:\Users\CrAzYgEnIuS3\Desktop\Huawei Phone EMMC Read Only and Update Fails\adb-t
oolkit>fastboot devices
f0ab4e5b fastboot
oolkit>fastboot oem unlock 7717320512982161
... INFO Unlocking ...
OKAY
oolkit>fastboot oem get-bootinfo
... INFO
INFO Bootloader Lock State: UNLOCKED
INFO System State: Bootloader in UNLOCKED state
INFO Bootloader Version: 001.001.000
INFO
OKAY
oolkit>
elcapitel 05-07-2015 15:10
If the problem persist the the emmc is damaged. Anyway try to flash with others sotck firmware high version. luck
Best Regards
zZKey Team
But Problem is same
here is LOG:
f0ab4e5b fastboot
OKAY
... INFO
INFO
OKAY
oolkit>
gjalvarez 07-29-2015 22:59
I am trying to get fastboot on huawei ascend y300, I can see the purple screen and inmediately it goes to the readonly screen, is it neccesary to replace emmc?
victorgutierrez 12-14-2015 19:26
Y300 my greetings when updating it says failed as I can read EMMC solve this mistake?
elcapitel 12-14-2015 19:50
Read and do carefully all explained here. Luck
Best Regards
zZKey Team
metalgold23 02-08-2016 12:45
hi
what about g610 models!!?
MYUNLOCKING 03-14-2016 15:30
g610-u20
866343022124231
866343022174244
iffipower 05-20-2016 09:37
how to open CMD command on xp
anombase 05-20-2016 12:02
i solved one with emmc tool
you need emmc tool to remove write protection on the emmc before you can update
fast solution 05-22-2016 12:06
Y300-100 still bootloader locked after unlock process
I have a y300-0100 hanguing on logo when i try update with sd i got "emmc read only" i got bootloader code from proper section i make the unlock process but when i check for bootloader lock status its always LOCKED .
http://i.imgur.com/mHZoK6J.png?1
NKhan_Gsm 06-05-2016 17:24
I have a G510-0200 Read MMC Only problem I unlocked its bootloader what else I should do to fix it ?
WBR
Page generated in 0.28322 seconds with 5 queries
