04-03-2014, 14:50 | #1 (permalink) |
Major Poster Join Date: Jan 2005 Age: 53
Member: 106527 Status: Offline Thanks Meter: 0 | huawei modem e173 Ports 3 and 4. After modem has been detected and initialized, I an getting a message of nv memory fail to read and then modem gets diconected. How can I read it please? Regards, |
04-03-2014, 15:16 | #2 (permalink) |
No Life Poster Join Date: Jul 2005 Location: zunZun Team Age: 43
Member: 166270 Status: Offline Sonork: 100.1579747 Thanks Meter: 12,673 | Just close all the others software and try again, if not ok then send me Teamviewer access via pm. Also you can try in other usb port, always ports under 16. Best Regards zZ-Team |
04-08-2014, 08:40 | #3 (permalink) |
Member: 106527 Status: Offline Thanks Meter: 0 | Hi, I have had modem recognized and unlocked by zzkey. After it says process unlocked I tested the modem and still locked but now it says Imei needs to be repaired. And it is not allowing me to continue although modem is recognized again by software. How can I solve this please? Bregards |
04-08-2014, 15:09 | #4 (permalink) | |
Member: 166270 Status: Offline Sonork: 100.1579747 Thanks Meter: 12,673 | If modem is still locked then have customized firmware. But in this case... also imei repair is supported, just try again in other usb port or other PC. Luck Best Regards zZ-Team Quote:
