03-03-2015, 18:46 | #1 (permalink) |
Insane Poster Join Date: May 2008 Location: DUBAI Age: 34
Member: 775826 Status: Offline Sonork: 100.1592041 Thanks Meter: 59 | Huawei P6-U06 - baseband and imei repair hello every body i have P6-U6 baseband and imei i need repair i trying to repair But same problem after repair Code: How to repair IMEI like 004999010640000 or unknown/Damage baseband with Hisilicon with the help of ZZ Key? You have to follow these manual to repair IMEI like 0044xxxxxxx and unknown/damage baseband of an android mobile: 1. Root your huawei device first 2. Go to where zZKey software is located: ZZ_Huawei_Advace_tool 'Utilities'P6-U06_Utility_script 3. Go to "Utilities" folder 4. Go to P6-U06_Utility_script folder. 5. Run "hisi_backup_nv.bat" script 6. Wait few seconds. 7. Now, run "hisi_fix_call_data.bat" 8. Wait few seconds . 9. Now, reboot your phone.(keeping press power up button for more than 15 seconds) 10. Now open "Huawei_Advanced_Tool" 11. Choose the Platform as "Huawei Hisilicon Phone" 12. You don't need to choose special port. Software itself connects to this special port. *#*#2846579#*#* ProjectMenu->background setting->USBPORTs setting->USbPorts Setting->Manufacturer Mode 13. Click on: "Repair Secure Area" button 14. Click "IMEI repair" button 15. Wait until the operation is completed. Code: BUT i still imei blank it's log for CMD tool for Donlge Code: Microsoft Windows [Version 6.1.7600] Copyright (c) 2009 Microsoft Corporation. All rights reserved. C:\Users\Candans-Software>CD C:\Windows\System32 C:\Windows\System32>hisi_backup_nv.bat 'hisi_backup_nv.bat' is not recognized as an internal or external command, operable program or batch file. C:\Windows\System32>hisi_backup_nv.bat C:\Windows\System32>adb shell su -c "dd if=/dev/block/platform/hi_mci.1/by-name/ modemnvm1 of=/data/local/tmp/nvm1.bin" error: device not found C:\Windows\System32>adb shell su -c "dd if=/dev/block/platform/hi_mci.1/by-name/ modemnvm2 of=/data/local/tmp/nvm2.bin" error: device not found C:\Windows\System32>adb shell su -c "chmod 777 /data/local/tmp/nvm1.bin" error: device not found C:\Windows\System32>adb shell su -c "chmod 777 /data/local/tmp/nvm2.bin" error: device not found C:\Windows\System32>adb pull /data/local/tmp/nvm1.bin error: device not found C:\Windows\System32>adb pull /data/local/tmp/nvm2.bin error: device not found C:\Windows\System32>hisi_backup_nv.bat C:\Windows\System32>adb shell su -c "dd if=/dev/block/platform/hi_mci.1/by-name/ modemnvm1 of=/data/local/tmp/nvm1.bin" 16384+0 records in 16384+0 records out 8388608 bytes transferred in 0.589 secs (14242118 bytes/sec) C:\Windows\System32>adb shell su -c "dd if=/dev/block/platform/hi_mci.1/by-name/ modemnvm2 of=/data/local/tmp/nvm2.bin" 16384+0 records in 16384+0 records out 8388608 bytes transferred in 0.505 secs (16611104 bytes/sec) C:\Windows\System32>adb shell su -c "chmod 777 /data/local/tmp/nvm1.bin" C:\Windows\System32>adb shell su -c "chmod 777 /data/local/tmp/nvm2.bin" C:\Windows\System32>adb pull /data/local/tmp/nvm1.bin 5084 KB/s (8388608 bytes in 1.611s) C:\Windows\System32>adb pull /data/local/tmp/nvm2.bin 5396 KB/s (8388608 bytes in 1.518s) C:\Windows\System32>hisi_fix_call_data.bat C:\Windows\System32>adb push nvm.bin /data/local/tmp/ 4347 KB/s (8388608 bytes in 1.884s) C:\Windows\System32>adb shell su -c "dd if=/data/local/tmp/nvm.bin of=/dev/block /platform/hi_mci.1/by-name/modemnvm1" 16384+0 records in 16384+0 records out 8388608 bytes transferred in 0.214 secs (39199102 bytes/sec) C:\Windows\System32>adb shell su -c "dd if=/data/local/tmp/nvm.bin of=/dev/block /platform/hi_mci.1/by-name/modemnvm2" 16384+0 records in 16384+0 records out 8388608 bytes transferred in 0.217 secs (38657179 bytes/sec) C:\Windows\System32>hisi_backup_nv.bat C:\Windows\System32>adb shell su -c "dd if=/dev/block/platform/hi_mci.1/by-name/ modemnvm1 of=/data/local/tmp/nvm1.bin" 16384+0 records in 16384+0 records out 8388608 bytes transferred in 0.438 secs (19152073 bytes/sec) C:\Windows\System32>adb shell su -c "dd if=/dev/block/platform/hi_mci.1/by-name/ modemnvm2 of=/data/local/tmp/nvm2.bin" 16384+0 records in 16384+0 records out 8388608 bytes transferred in 0.455 secs (18436501 bytes/sec) C:\Windows\System32>adb shell su -c "chmod 777 /data/local/tmp/nvm1.bin" C:\Windows\System32>adb shell su -c "chmod 777 /data/local/tmp/nvm2.bin" C:\Windows\System32>adb pull /data/local/tmp/nvm1.bin 5298 KB/s (8388608 bytes in 1.546s) C:\Windows\System32>adb pull /data/local/tmp/nvm2.bin 4902 KB/s (8388608 bytes in 1.671s) C:\Windows\System32>hisi_fix_call_data.bat C:\Windows\System32>adb push nvm.bin /data/local/tmp/ 2640 KB/s (8388608 bytes in 3.102s) C:\Windows\System32>adb shell su -c "dd if=/data/local/tmp/nvm.bin of=/dev/block /platform/hi_mci.1/by-name/modemnvm1" 16384+0 records in 16384+0 records out 8388608 bytes transferred in 0.757 secs (11081384 bytes/sec) C:\Windows\System32>adb shell su -c "dd if=/data/local/tmp/nvm.bin of=/dev/block /platform/hi_mci.1/by-name/modemnvm2" 16384+0 records in 16384+0 records out 8388608 bytes transferred in 0.676 secs (12409183 bytes/sec) C:\Windows\System32> and also log ! for Dongle Connecting... Phone Detected. Reading Phone Info... Failed setting CP:-2 Operation Done. |
The Following User Says Thank You to abkareino For This Useful Post: |
03-03-2015, 19:23 | #2 (permalink) | |
No Life Poster Join Date: Jul 2005 Location: zunZun Team Age: 43
Member: 166270 Status: Offline Sonork: 100.1579747 Thanks Meter: 12,673 | Of course, script is not running correctly, contact me at skype: elcapitel Best Regards zZKey Team Quote:
The Following User Says Thank You to elcapitel For This Useful Post: |
05-07-2016, 00:57 | #5 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Cuba
Member: 346150 Status: Offline Sonork: 100.1661091 Thanks Meter: 429 | Please Read the complete post http://forum.gsmhosting.com/vbb/f717...eport-1910877/ Remember the path for runing the script C:\zZ_Huawei_Advanced_Tool_v2.7.2.8\utilities\P6-U06_utility_script |
05-07-2016, 01:02 | #6 (permalink) |
Member: 346150 Status: Offline Sonork: 100.1661091 Thanks Meter: 429 | Please Read the complete post Full http://forum.gsmhosting.com/vbb/f717...eport-1910877/ Remember the path for runing the script C:\zZ_Huawei_Advanced_Tool_v2.7.2.8\utilities\P6-U06_utility_script Last edited by windowshu; 05-07-2016 at 01:09. |
