05-14-2015, 12:55 | #1 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Arizona Age: 38
Member: 630795 Status: Offline Thanks Meter: 177 | Huawei P6 - U06 Baseband unknown just got a phone with no imei and Baseband unknown tried to upgrade to latest official update B510 put new sd card with dload folder extracted the 5 files in dload folder local upgrade but always FAIL any suggestion how to solve this problem |
05-14-2015, 13:10 | #2 (permalink) |
No Life Poster Join Date: Aug 2010 Location: Inside Logic Age: 37
Member: 1377783 Status: Offline Sonork: 100.1611724 Thanks Meter: 3,335 | Hi, first to all, you need update it if you want, with app file into microsd card inside dload folder after that use script inside Huawei Advance tool folder for repair Unknow baseband if not hardware damage, then restart your phone and connect it with Huawei Advance Tool module for repair IMEI and you will be ok... As a way of guidance please follow this steps: |
The Following 2 Users Say Thank You to Shensohau For This Useful Post: |
05-14-2015, 14:53 | #4 (permalink) |
Member: 1377783 Status: Offline Sonork: 100.1611724 Thanks Meter: 3,335 | Hi, Connect correctly your phone, please check drivers, install hisuite lastest version for drivers and please close all ADB services software on your pc, including hisuite auto start, and connect it according to the instructions given on video, restart your phone and repeat process until it detect it and perform the operation required... Best Regards zZKey-Team |
The Following User Says Thank You to Shensohau For This Useful Post: |
05-14-2015, 16:13 | #5 (permalink) |
Member: 630795 Status: Offline Thanks Meter: 177 | Hello sir, now i am getting a new message Code: Connecting... Phone Detected. Reading Phone Info... Failed setting CP:-2 Operation Done. My original imei is 864875020009528 |
05-14-2015, 17:54 | #6 (permalink) |
No Life Poster Join Date: Jul 2005 Location: zunZun Team Age: 43
Member: 166270 Status: Offline Sonork: 100.1579747 Thanks Meter: 12,673 | EDGE-U00_V100R001C00B520_Board_Software_Western_Europe_ Android_4.4_EMUI_2.3_05011SRP Check your pm. Best Regards zZKey Team |
The Following User Says Thank You to elcapitel For This Useful Post: |
05-15-2015, 15:47 | #7 (permalink) |
Member: 630795 Status: Offline Thanks Meter: 177 | hello sir, i updated through the firmware u sent to me but no luck . still unknown baseband also i tried the hisi_fix_call_data script but also no luck on zzkey i get Code: Connecting... Phone Detected. Reading Phone Info... Failed setting CP:-2 Operation Done. |
05-15-2015, 21:25 | #8 (permalink) |
Member: 166270 Status: Offline Sonork: 100.1579747 Thanks Meter: 12,673 | If all possibilities are already taken in account, then, think in possible hardware issue. Best Regards zZKey Team |
05-15-2015, 23:35 | #9 (permalink) |
Member: 630795 Status: Offline Thanks Meter: 177 | I tried to pull nvm.bin manually Also in vain Code: D:\Stuff\ADB Drivers\ADB Drivers\ADB Drivers\ADB Drivers>adb push nvm.bin /data/ local/tmp/ 2520 KB/s (8388608 bytes in 3.250s) If yes it should be a hardware problem?!! Thank you |
