01-16-2016, 21:45 | #1 (permalink) |
No Life Poster Join Date: Apr 2015
Member: 2385655 Status: Offline Thanks Meter: 99 | huawei p6-u06 hang lago EDGE-U00_V100R001C00B520_Board_Software_Middle_East_And roid_4.4_EMUI_2.3_05011SNE P6_firmware(P6-U06_Android_4.2.2_EMUI_1.6_V100R001C00B130_Middle_ East_Channel_05011SNE).zip P6_firmware(P6-U06,Android_4.2,Emtion_UI,V100R001C00B111,Nornal,0 5011RJP).zip P6-U06_EMUI3.0_Android4.4_V100R001C17B708.zip this all firmware not warking |
01-16-2016, 21:51 | #2 (permalink) |
Member: 2385655 Status: Offline Thanks Meter: 99 | huawei p6-u06 hang lago A MICRO SD card of 2GB or more should be available. The MICRO SD card made by Sandisk, Kingstone, or Kingmax is recommended. Format the MICRO SD card (This operation is optional). Make sure that there is an UPDATE.APP under the dload. Copy the Main package of dload in PC to dload of SD card. Make sure your handset is power off. Insert the MICRO SD card into the handset. Pressing the VOLUME UP key and VOLUME DOWN key, then press the POWER key to power on the phone, and VOLUME UP key and VOLUME DOWN key should be pressed more than 3 seconds, then enter the Software Upgrade Mode. but no warking how to solved this problem |
01-16-2016, 22:21 | #3 (permalink) | |
No Life Poster Join Date: Sep 2006 Location: Cuba
Member: 346150 Status: Offline Sonork: 100.1661091 Thanks Meter: 427 | Quote:
Check to request firmware http://forum.gsmhosting.com/vbb/f717...users-1802275/ or use zzUPCENTER.v0.308 and select Download Center | |
