01-26-2014, 00:47 | #2 (permalink) |
No Life Poster Join Date: Aug 2010 Location: Inside Logic Age: 37
Member: 1377783 Status: Offline Sonork: 100.1611724 Thanks Meter: 3,336 | Hi, just open the module again, and wait a moment until models load correctly, use PC proper USB ports and no hubs and try again!!! |
01-26-2014, 00:50 | #3 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Cuba-Holguin
Member: 256260 Status: Offline Thanks Meter: 726 | ok i will try and post result thanks BR Yaio... and the counter is grow alway and only see the error i see the problem when try select the model autodetect work fine Last edited by zZKeyHelp; 01-27-2014 at 21:38. Reason: please 1 message for descript your problem not need 3 post |
01-29-2014, 04:17 | #9 (permalink) |
Member: 256260 Status: Offline Thanks Meter: 726 | ok funciona ya no presenta el error pero el contador del donlge sin realizar inguna operacion sigue aumentandome usando este programa si uso otro nada se mantiene igual pero nada mas de abrirlo aumenta dime que puedo hacer para solucionar esto saludos BR Yaio.. |
01-29-2014, 04:23 | #10 (permalink) |
No Life Poster Join Date: Jul 2005 Location: zunZun Team Age: 43
Member: 166270 Status: Offline Sonork: 100.1579747 Thanks Meter: 12,673 | Brother, not need worry about counter dongle... just open UpdateCenter302 module and do click in reset counter, when counter is near 100%... That is all. Best Regards zZ-Team |
The Following User Says Thank You to elcapitel For This Useful Post: |
01-29-2014, 14:29 | #11 (permalink) |
Member: 256260 Status: Offline Thanks Meter: 726 | ok hermano recuerda que no hay problema con eso pero si el dongle se llena ahy que usar internet y eso es un lujo que los cubanos casi no podermos darnos solve este problemita para la proxima actualizacion gracias BR Yaio... |
