Unlock Server
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > zZKey
Old 07-30-2012, 17:45   #1 (permalink)
Crazy Poster
Member: 461187
need flash zzkey 8520
device error 371
nuke
wipe
Device Info:
PIN: 26c5f34c
Bootrom Version: 5.6.0.20
HW ID Override: None
Supported Bands: 0x000F
Metrics Version: 6.9
Build Date: May 13 2009
Build Time: 13:25:04
Build User: rdagg
Security: Enabled
Supported Options: 0x00000003
Drivers: 0x00000004
Processor: 0x00000001
LDR Blocks: 0x87FEB474
Bootrom Size: 0x00020000
External MCT/HWV: Enabled
Boot Mode: N/A
Boot OS Count: N/A
HWV:
Board Revision 0001 - 0x07
CPU Version 0002 - 0x32
SW Compatibility 0003 - 0x01
POP Revision 0004 - 0x1A
Power Mgt Hardware 0007 - 0x27
POP Security 000B - 0x01
Mem Config Table (ver 1.24):
Flash Chip: blocks 0-2000, Chip 0, Sub 0
Bootrom: blocks 0-0
OS Dynamic: blocks 2-????
FS Dynamic: blocks ????-1983
OS NV: blocks 1984-2000, total 17
CRC: 0x523997A7
Flash:
Number of chips: 1
Flash ID: NAND blocks 0-2020
Device ID: 68
Vendor ID: 236
Version ID: 0
Total Size: 252.6 MB
Memory Map:
NAND Blocks: 2021 * 128 Kb
RAM Base: 0x80000000
IRAM Base: no IRAM!
OS Range: 2 - 85
File System:
Memory Map:
86 - 1983
Sectors: 1898
Branding:
VendorID: 142
OS Version: 4.2.0.9
Supported Bands: 0x0000FFFF
Metrics Version: 3.16
FS Code Version: 10.0.0.0
FAT Code Version: 2.18
Package Version: ""
Build Date: Jul 28 2009
Build Time: 01:43:14
Build User: SCM
SV Number: 1
OS Address: 0x80000000-0x80A6249F
App Start: * No Application Linked *
Companion Binary: 0.0.0.0
RAM usage: 0x874FFFFC-0x87FFFFFC
IRAM End: 0x4009E378
DSP ROM2 Address: *not present*
OS Extended Addr: 0x809450F8
LDR Blocks: 0x80A2C960
API Checksum: 0x00000000
JumpTable (<3): 0x80000310
JumpTable (>2): 0x80001F78
Radio Code: Orpheus radio code linked
OS API Version: 109.40
STP Protocol Ver: 5.147.1 (factory OS)
HWV:
Board Revision 0001 - 0x01 - 0xFF, 0x01
POP Revision 0004 - 0x00 - 0xFF, 0x01
CPU Version 0002 - 0x00 - 0xFF, 0x01
SW Compatibility 0003 - 0x00 - 0x01, 0x01
Power Mgt Hardware 0007 - 0x24 - 0xFF, 0x01
Version Table:
STP protocol version: 5.147.1
BlockFS API Version: 10.0.0.0
USB driver version: 02.01
Bugdisp RTAS key: 1.0
STP RTAS key: 1.0
NVSIG RTAS key: 1.0
FAT FS Version: 2.18
Block map version: 2.6
WLAN radio version: 2.5.0.73
Kernel Version: 1.11.0.241
Metrics Version: 1.1
Build Time: 00:59:28
Build User: SCM
Done.
Operation Finished.
Old 07-30-2012, 17:52   #2 (permalink)
elcapitel's Avatar
Member: 166270
Sonork: 100.1579747
Check inside battery, ur PRD-XXXXX-XXX in sticker.
Open zzBB soft , got to last tab, enter your PRD and click in "Find Proper FlashFile"
After download from here
If you also want to write last OS and put in spanish, then use 8520_49.zFLASH OS 5.0.0.1096 (ES-EN)
Best Regards
zZ-Team
Originally Posted by celudiego View Post
device error 371
nuke
wipe
Device Info:
PIN: 26c5f34c
Build User: rdagg
Security: Enabled
Drivers: 0x00000004
Boot Mode: N/A
Boot OS Count: N/A
HWV:
Bootrom: blocks 0-0
CRC: 0x523997A7
Flash:
Number of chips: 1
Device ID: 68
Vendor ID: 236
Version ID: 0
Memory Map:
IRAM Base: no IRAM!
OS Range: 2 - 85
File System:
Memory Map:
86 - 1983
Sectors: 1898
Branding:
VendorID: 142
OS Version: 4.2.0.9
Package Version: ""
Build User: SCM
SV Number: 1
HWV:
Version Table:
STP RTAS key: 1.0
NVSIG RTAS key: 1.0
Build User: SCM
Done.
Operation Finished.
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 26 09-25-2012 02:41
needed pinout for carkit(N61xx) mobileinfo Nokia Hardware & Hardware-Repair Area 1 12-27-2006 10:20
need ericsson 88 cable migdamas Old Ericsson Phones & Sony Phones 1 06-02-1999 16:23
need eeprom photo???? mobileinfo Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 05-26-1999 11:35
Page generated in 0.52492 seconds with 11 queries
