05-08-2014, 05:55 | #1 (permalink) |
Freak Poster Join Date: Feb 2005 Location: World Wide Age: 54
Member: 120932 Status: Offline Thanks Meter: 58 | Samrt Z module does not work, please help [Solved] Samrt Z module does not work, please help |
05-08-2014, 21:59 | #4 (permalink) |
No Life Poster Join Date: Aug 2010 Location: Inside Logic Age: 37
Member: 1377783 Status: Offline Sonork: 100.1611724 Thanks Meter: 3,336 | Hi your dongle is ok just delete old folder of module and redownload it again with the new version delete do not overwrite it please!!! Best Regards zZ-Team |
05-10-2014, 09:44 | #7 (permalink) |
Freak Poster Join Date: Nov 2006
Member: 387154 Status: Offline Thanks Meter: 70 | I think you have windows problem, change usb port for zzkey,not use usb hub, disable antivirus... or last solution change PC- You can use zzkey in more PC (I use on XP, WIN7), only must update dongle Try |
05-10-2014, 09:55 | #8 (permalink) |
No Life Poster Join Date: Apr 2008 Location: PhP Age: 42
Member: 757799 Status: Offline Thanks Meter: 782 | off/disable your antivirus, then extract the rar file zz smartz, run program again. or go to the setting of your antivirus and add exception the zzsmartz folder |
05-10-2014, 15:46 | #9 (permalink) |
No Life Poster Join Date: Jul 2005 Location: zunZun Team Age: 43
Member: 166270 Status: Offline Sonork: 100.1579747 Thanks Meter: 12,673 | paisano aca te va en espannol, porque veo que no estas entendiendo para nada lo que te explicamos. Tu zZKey no esta corrupta para nada. Por favor elimina la carpeta vieja que tienes del SmartZ_1.7.23, entonces descarga solamente desde aqui: SmartZ_1.7.23 y tendras tu asunto resuelto bro, tienes una version 1.7.23 pero vieja, justo descargala de nuevo. Te hemos explicado arriba en ingles perfectamente que hacer. Best Regards zZ-Team |
The Following User Says Thank You to elcapitel For This Useful Post: |
05-10-2014, 16:56 | #10 (permalink) | |
Member: 120932 Status: Offline Thanks Meter: 58 | Quote:
