Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > zZKey
Old 01-28-2014, 17:52   #286 (permalink)
Member: 1677266
Thanks Meter: 90
otro g740 unlocked
Connecting...
Check if your phone is connected power on and USB Debug is enabled.
Phone Detected.
Reading Phone Info...
Manufacturer: HUAWEI
Model: Orange Yumo
Build ID: G740-L00V100R001C109B140
Flash Memory: EMMC
Checking root... OK!
Initializing...
Imei: 86xxxxxxxxxxxxx09
Serial: 022HBC213B023366
Reading Simlock Status...
Simlock Status: Phone Unlocked.
Operation Done.
The Following User Says Thank You to Movileuropa For This Useful Post:
Old 01-29-2014, 13:17   #287 (permalink)
Member: 387154
Thanks Meter: 70
G300 after unlock with other tool no network!
ZZ key repair this!!!
Connecting...
Phone Detected.
Hard Version: 76XXU-109808-USNSKRL
Sending Loader(s) wait...
Reconnecting Phone...
Initializing...
Imei: 86122xxxxxxxxxx
Serial: 021MGJ5T29010858
Creating Simlock Backup...
Operation Done.
Reading Full Backup...
Read Backup Done.
Operation Done.
Reparing Simlock...
Repair Done.
Operation Done.
Unlocking Phone...
Unlock Done.
Operation Done.
Disconnecting...
Please Remove/Connect Baterry.
Operation Done.
The Following User Says Thank You to bojadzic For This Useful Post:
Old 01-29-2014, 20:47   #288 (permalink)
Member: 1929852
Thanks Meter: 3
huawei g600 u8950-51 IMXX done!
1.presionar vol- y vol+ al mismo tiempo y conectar el cable usb a la pc.. esperar que salga la pantalla rosada
2. click en conectar
3. cuando este conectado darle a repair imei y colocar el imei
4. al finalizar se debe flashear, colocando el archivo UPDATE.app dentro de una carpeta llamada dload y colocarla en la raiz de la micro sd.
5.vol- vol+ y power al mismo tiempo el telefono inicia proceso de flasheo
6.el telefono enciende y ya tiene el IMXX reparado
Old 01-30-2014, 18:58   #289 (permalink)
Member: 1677266
Thanks Meter: 90
yumo unlock done
Connecting...
Phone Detected.
Model: Orange Yumo
Flash Memory: EMMC
Initializing...
Imei: 862zzzzzzzzzzzzz882
Serial: 022HBC213A010600
Simlock Status: Phone Locked.
Unlocking Phone...
Unlock Done.
Restarting Phone...
Operation Done.
Old 02-02-2014, 00:38   #290 (permalink)
J3soft's Avatar
Member: 448639
Thanks Meter: 165
huawei u7520 full repair with zz dongle
Connecting...
Phone Detected.
Changing Phone Mode, please wait...
Hard Version: Q62xx-FSBL
Initializing...
Imei: 354640040007903
Operation Done.
Unlocking Phone...
Unlock Done.
Operation Done.
Repairing Imei...
New Imei: 3348480023-----
Repair Imei Done.
Repair Imei/Meid is Done, NOW YOU NEED FLASH YOUR PHONE BEFORE CONTINUE.
If you need Help Please click on Help TAB to HINTS.
Operation Done.
Old 02-02-2014, 18:53   #291 (permalink)
Member: 731820
Sonork: lerouxito
Thanks Meter: 236
Unlock huawei y301a correct process
1: go to settings
Developer Options
chose ON
USB Debugging
Conect Huawei to Computer
3: Install Al Drivers usb_driver_u8810-u8815 - Download - 4shared
3: root Huawei is very easy used http://www.androidxda.com/data/Impactor_0.9.14.zip
Extract folder in C: chose Impactor and execute
4: Open zZ_Huawei_Advanced_Tool_v2.6.0.7
Phone ON and whait.
The Following User Says Thank You to lerouxito For This Useful Post:
Old 02-11-2014, 02:07   #292 (permalink)
elcapitel's Avatar
Member: 166270
Sonork: 100.1579747
Thanks Meter: 12,673
Thumbs up Huawei U8220 repaired imei perfectly with zZKey
Operation Log
Connecting...
Phone Detected.
Hard Version: msm7201a_surf - 0.5
Initializing...
Imei: 357258030038xxx
Serial: 020JFW7N05001997
Operation Done.
Repairing Imei...
New Imei: 3572580392488xx
Repair Imei Done.
Operation Done.
Best Regards
zZ-Team
Old 02-20-2014, 15:02   #293 (permalink)
Member: 387154
Thanks Meter: 70
Huawei Y300-0100 unlock done
Connecting...
Phone Detected.
Hard Version: 8X25-2030-SSNSKOLYM
Initializing...
Imei: 863522027290096
Serial: 021XKH213C096441
Operation Done.
Unlocking Phone...
Unlock Done.
Operation Done.
Disconnecting...
Operation Done.
Old 02-21-2014, 10:53   #294 (permalink)
Member: 387154
Thanks Meter: 70
Huawei Y210-0100 unlock done
Connecting...
Phone Detected.
Hard Version: 76XXU-109808-USNEKQL
Initializing...
Imei: 868096014889942
Serial: 021XXEBY38022406
Operation Done.
Unlocking Phone...
Unlock Done.
Operation Done.
Disconnecting...
Operation Done.
Old 02-24-2014, 14:41   #295 (permalink)
laduka's Avatar
Member: 194939
Sonork: 100.168.25.6
Thanks Meter: 623
huawei y301-a1 unlock done
via adb mode
first need root
after press connect
unlock done after 5 sec
Old 02-25-2014, 19:16   #296 (permalink)
Diamond Gsm's Avatar
Member: 2064519
Thanks Meter: 83
motorola MB855 Sprint unlock perfectly with zZKey
Thanks zZkey
The Following User Says Thank You to Diamond Gsm For This Useful Post:
Old 03-08-2014, 03:00   #297 (permalink)
Member: 2081285
Thanks Meter: 38
HUAWEI 8350 UNLOCK SUCCESS!
thanks Zzkey Team!
Old 03-08-2014, 03:03   #298 (permalink)
Member: 2081285
Thanks Meter: 38
HUAWEI U9120 SUCCESS!
thaks Zzkey Team!
Old 03-08-2014, 03:06   #299 (permalink)
Member: 2081285
Thanks Meter: 38
HUAWEI y201 pro UNLOCK SUCCESS!
Thanks Zzkey team!
Old 03-08-2014, 03:09   #300 (permalink)
Member: 2081285
Thanks Meter: 38
HUAWEI y210-u8665d unlock sucess!
thanks Zzkey team!
Page generated in 0.23550 seconds with 9 queries
