01-28-2014, 17:52 | #286 (permalink) |
Freak Poster Join Date: Oct 2011 Location: Almoradi (ALICANTE) . SPAIN
Member: 1677266 Status: Offline Thanks Meter: 90 | Connecting... Check if your phone is connected power on and USB Debug is enabled. Phone Detected. Reading Phone Info... Manufacturer: HUAWEI Model: Orange Yumo Build ID: G740-L00V100R001C109B140 Flash Memory: EMMC Checking root... OK! Initializing... ------------------------------------------------------------------------------------------ Imei: 86xxxxxxxxxxxxx09 Serial: 022HBC213B023366 ------------------------------------------------------------------------------------------ Reading Simlock Status... Simlock Status: Phone Unlocked. Operation Done. |
The Following User Says Thank You to Movileuropa For This Useful Post: |
01-29-2014, 13:17 | #287 (permalink) |
Freak Poster Join Date: Nov 2006
Member: 387154 Status: Offline Thanks Meter: 70 | G300 after unlock with other tool no network! ZZ key repair this!!! Connecting... Phone Detected. Hard Version: 76XXU-109808-USNSKRL Sending Loader(s) wait... Reconnecting Phone... Initializing... Reading Phone Info... ------------------------------------------------------------------------------------------ Imei: 86122xxxxxxxxxx Serial: 021MGJ5T29010858 Creating Simlock Backup... Reading Simlock Status... Simlock Status: Phone Unlocked. ------------------------------------------------------------------------------------------ Operation Done. Reading Full Backup... Read Backup Done. Operation Done. Reparing Simlock... Repair Done. Operation Done. Unlocking Phone... Unlock Done. Operation Done. Disconnecting... Please Remove/Connect Baterry. Operation Done. |
The Following User Says Thank You to bojadzic For This Useful Post: |
01-29-2014, 20:47 | #288 (permalink) |
Insane Poster Join Date: May 2013
Member: 1929852 Status: Offline Thanks Meter: 3 | huawei g600 u8950-51 IMXX done! 1.presionar vol- y vol+ al mismo tiempo y conectar el cable usb a la pc.. esperar que salga la pantalla rosada 2. click en conectar 3. cuando este conectado darle a repair imei y colocar el imei 4. al finalizar se debe flashear, colocando el archivo UPDATE.app dentro de una carpeta llamada dload y colocarla en la raiz de la micro sd. 5.vol- vol+ y power al mismo tiempo el telefono inicia proceso de flasheo 6.el telefono enciende y ya tiene el IMXX reparado |
01-30-2014, 18:58 | #289 (permalink) |
Member: 1677266 Status: Offline Thanks Meter: 90 | yumo unlock done Connecting... Phone Detected. Reading Phone Info... Manufacturer: HUAWEI Model: Orange Yumo Build ID: G740-L00V100R001C109B140 Flash Memory: EMMC Checking root... OK! Initializing... ------------------------------------------------------------------------------------------ Imei: 862zzzzzzzzzzzzz882 Serial: 022HBC213A010600 ------------------------------------------------------------------------------------------ Reading Simlock Status... Simlock Status: Phone Locked. Creating Simlock Backup... Unlocking Phone... Unlock Done. Restarting Phone... Operation Done. |
02-02-2014, 00:38 | #290 (permalink) | |
Freak Poster Join Date: Feb 2007 Location: Colombia
Member: 448639 Status: Offline Thanks Meter: 165 | huawei u7520 full repair with zz dongle Quote:
02-02-2014, 18:53 | #291 (permalink) |
Insane Poster Join Date: Mar 2008 Location: Ecuator QUito
Member: 731820 Status: Offline Sonork: lerouxito Thanks Meter: 236 | Unlock huawei y301a correct process 1: go to settings Developer Options chose ON USB Debugging Conect Huawei to Computer 3: Install Al Drivers usb_driver_u8810-u8815 - Download - 4shared 3: root Huawei is very easy used http://www.androidxda.com/data/Impactor_0.9.14.zip Extract folder in C: chose Impactor and execute 4: Open zZ_Huawei_Advanced_Tool_v2.6.0.7 Phone ON and whait. |
The Following User Says Thank You to lerouxito For This Useful Post: |
02-11-2014, 02:07 | #292 (permalink) | |
No Life Poster Join Date: Jul 2005 Location: zunZun Team Age: 43
Member: 166270 Status: Offline Sonork: 100.1579747 Thanks Meter: 12,673 | Huawei U8220 repaired imei perfectly with zZKey Operation Log Quote:
zZ-Team | |
02-20-2014, 15:02 | #293 (permalink) |
Member: 387154 Status: Offline Thanks Meter: 70 | Huawei Y300-0100 unlock done Connecting... Phone Detected. Hard Version: 8X25-2030-SSNSKOLYM Sending Loader(s) wait... Reconnecting Phone... Initializing... Reading Phone Info... ------------------------------------------------------------------------------------------ Imei: 863522027290096 Serial: 021XKH213C096441 Creating Simlock Backup... Reading Simlock Status... Simlock Status: Phone Locked. ------------------------------------------------------------------------------------------ Operation Done. Unlocking Phone... Unlock Done. Operation Done. Disconnecting... Please Remove/Connect Baterry. Operation Done. |
02-21-2014, 10:53 | #294 (permalink) |
Member: 387154 Status: Offline Thanks Meter: 70 | Huawei Y210-0100 unlock done Connecting... Phone Detected. Hard Version: 76XXU-109808-USNEKQL Sending Loader(s) wait... Reconnecting Phone... Initializing... Reading Phone Info... ------------------------------------------------------------------------------------------ Imei: 868096014889942 Serial: 021XXEBY38022406 Creating Simlock Backup... Reading Simlock Status... Simlock Status: Phone Locked. ------------------------------------------------------------------------------------------ Operation Done. Unlocking Phone... Unlock Done. Operation Done. Disconnecting... Please Remove/Connect Baterry. Operation Done. |
