07-21-2013, 20:30 | #1 (permalink) |
Freak Poster Join Date: Jan 2003 Location: Belarus Age: 52
Member: 19585 Status: Offline Thanks Meter: 19 | Problem with MediaPad S7-105 [Solved] Phone Detected. Hard Version: 4076 Sending Loader(s) wait... Reconnecting Phone... Initializing... ReadFile function failed (Error: 997) Operation Done. OS: W7, drivers - Ok |
07-21-2013, 21:12 | #2 (permalink) |
No Life Poster Join Date: Jul 2005 Location: zunZun Team Age: 43
Member: 166270 Status: Offline Sonork: 100.1579747 Thanks Meter: 12,673 | I am write you to ur sonork, please try with v2.0, is already full tested, here test report Or try normally with last huawei module v2.5, to close all software in ur PC... depending of comports... Also need do click above image for check correct procedure. Luck Best Regards zZ-Team |
07-21-2013, 21:34 | #4 (permalink) | ||
Member: 166270 Status: Offline Sonork: 100.1579747 Thanks Meter: 12,673 | After flashed with russian firmwares phone is detected ok: Quote:
Best Regards zZ-Team | ||
The Following User Says Thank You to elcapitel For This Useful Post: |
