11-02-2014, 19:30 | #1 (permalink) |
Crazy Poster Join Date: Oct 2013
Member: 2047426 Status: Offline Thanks Meter: 1 | Y530-U051, Unlock succesful, but can update firmware after? [SOLVED] But when I go to system update, the phone sees there is a newer build version out (it is on B185, phone prompts to download and install B188) But when i go to download and install, an error keeps popping up stating download failed. This has happened on all of the phones I unlocked with zzkey (all same model from same provider) The other phones that I unlocked via unlock code have no issue downloading and installing update (again, all same model from same provider) If i use this key to unlock these phones, you can't install the updates? |
The Following User Says Thank You to mactruck For This Useful Post: |
11-02-2014, 20:29 | #4 (permalink) |
No Life Poster Join Date: Aug 2013 Location: Somewhere on earth
Member: 2014742 Status: Offline Thanks Meter: 167 | Yea the tool autoroots it. Download and run Kingo. USB debugging must be on and make sure the phone screen is on to allow access to commands. It's pretty easy to root and unroot most phones with either Kingo or Vroot. |
The Following User Says Thank You to A4L For This Useful Post: |
11-03-2014, 21:15 | #10 (permalink) |
Member: 2047426 Status: Offline Thanks Meter: 1 | thanks guys i can confirm after unrooting with kingo i can update firmware and phone stays unlocked it would be great if the tool auto-unrooted the phone after as well (as it auto-roots to unlock) |
