Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > zZKey
Old 09-10-2013, 18:56   #1 (permalink)
Shensohau's Avatar
Member: 1377783
Sonork: 100.1611724
Thanks Meter: 3,336
Problem With Huawei CM980 [Solved]
Hi I was testing new Version and I found this "little" issue, Please My intention if try to help the community and Fix Bugs, after this error the Software Can't recognize the cellphone again....
Old 09-13-2013, 02:38   #2 (permalink)
elcapitel's Avatar
Member: 166270
Sonork: 100.1579747
Thanks Meter: 12,673
Solved, check here last Huawei Advanced Tool 2.6.0.3 update...
Best Regards
zZ-Team
The Following User Says Thank You to elcapitel For This Useful Post:
Old 09-16-2013, 16:53   #3 (permalink)
Member: 80324
error after update new version 2.6.0.3
everything is ok till update new version 2.6.0.3
doing evolution 2 show this error
Failed Creating Interface: 1 - 1
See every post about this error and do it like it say, this error persist. Can help me to solve this error
Thanks a lot
Old 09-16-2013, 18:00   #4 (permalink)
elcapitel's Avatar
Member: 166270
Sonork: 100.1579747
Because you are trying in download mode (pink screen) is wrong for CM980
Please connect in fastboot mode (phone freezed in logo) and keep the button pressed until process finish. Sure your pb will be fixed.
Best Regards
zZ-Team
Thanks a lot
Old 09-17-2013, 07:34   #5 (permalink)
Member: 80324
Best Regards
zZ-Team
I connect in fastboot, with pink screen connect good. the problem is in fastboot.
Old 09-17-2013, 14:57   #6 (permalink)
elcapitel's Avatar
Member: 166270
Sonork: 100.1579747
Try installing good drivers, or try in other usb port or other PC. luck
Remember in Fastboot(phone freezed in logo)
Best Regards
zZ-Team
Old 09-19-2013, 15:49   #7 (permalink)
Member: 80324
problem solved. driver conflicts
Page generated in 0.19489 seconds with 9 queries
