10-05-2014, 17:46 | #16 (permalink) | |
No Life Poster Join Date: Jul 2005 Location: zunZun Team Age: 43
Member: 166270 Status: Offline Sonork: 100.1579747 Thanks Meter: 12,673 | Best Regards zZ-Team Quote:
The Following User Says Thank You to elcapitel For This Useful Post: |
10-05-2014, 17:48 | #17 (permalink) | |
Member: 166270 Status: Offline Sonork: 100.1579747 Thanks Meter: 12,673 | Select "Autodetection" in model and unlock your G6-L33 succesfully. Post the done here. Best Regards zZ-Team Quote:
10-05-2014, 19:01 | #18 (permalink) |
Freak Poster Join Date: Jun 2007 Location: Minsk
Member: 536992 Status: Offline Thanks Meter: 88 | Connecting... Phone Detected. Reading Phone Info... Manufacturer: HUAWEI Model: HUAWEI G6-U10 Build ID: G6-U10V100R001C149B121 Flash Memory: EMMC ------------------------------------------------------------------------------------------ Linux version 3.4.0+ (android@localhost) (gcc version 4.7 (GCC) ) #1 SMP PREEMPT Wed May 14 18:02:16 IST 2014 ------------------------------------------------------------------------------------------ Hacking phone, please wait... Checking root... FAILED! (-9) Failed, Phone is not rooted. root phone first. Operation Done. |
10-05-2014, 19:49 | #19 (permalink) | |
Member: 166270 Status: Offline Sonork: 100.1579747 Thanks Meter: 12,673 | Strange, in this case please try to root with any 3th party software then try unlock again with zZKey. Post the log here. Best Regards zZ-Team Quote:
10-06-2014, 00:00 | #20 (permalink) | |
Freak Poster Join Date: Aug 2011 Location: California, LA,USA
Member: 1639385 Status: Offline Sonork: 100.1594605 Thanks Meter: 212 | Please try doing it again. Restart your phone before in order to perfom the operation and when you click it for read info you must be sure your phone completely start. If not success mean that huawei close overflow xploit after restarting on those firmw, so I need to code it the another one. Please let me know. P.D:A fast solution if you need unlock it hurry, You should try flash it with another firmw version and try. Regards. Quote:
10-06-2014, 16:32 | #21 (permalink) |
No Life Poster Join Date: Oct 2005 Location: georgia tbilisi
Member: 194939 Status: Offline Sonork: 100.168.25.6 Thanks Meter: 623 | g630 unlocked ok Connecting... Phone Detected. Reading Phone Info... Manufacturer: HUAWEI Model: G630-U20 Build ID: G630-U20V100R001C00B117 Flash Memory: EMMC ------------------------------------------------------------------------------------------ Linux version 3.4.0+ (android@localhost) (gcc version 4.7 (GCC) ) #1 SMP PREEMPT Tue May 6 05:00:11 CST 2014 ------------------------------------------------------------------------------------------ Checking root... OK! Initializing... ------------------------------------------------------------------------------------------ Imei: 86xxxxxxxxxxxxxx Serial: DU2NQA145R007342 ------------------------------------------------------------------------------------------ Reading Simlock Status... Simlock Status: Phone Unlocked. Operation Done. |
10-06-2014, 16:33 | #22 (permalink) | |
Crazy Poster Join Date: May 2011
Member: 1577091 Status: Offline Sonork: 991259299 Thanks Meter: 6 | Quote:
Connecting... Phone Detected. Reading Phone Info... Manufacturer: HUAWEI Model: HUAWEI G6-L33 Build ID: G6-L33V100R001C25B118 Flash Memory: EMMC ------------------------------------------------------------------------------------------ Linux version 3.4.0-g77ef605 (@pekeaulxd0013) (gcc version 4.7 (GCC) ) #1 SMP PREEMPT Wed May 14 19:47:51 CST 2014 ------------------------------------------------------------------------------------------ Checking root... OK! Initializing... ------------------------------------------------------------------------------------------ Serial: 4C2QNC1466027220 ------------------------------------------------------------------------------------------ Reading Simlock Status... Simlock Status: Phone Unlocked. Operation Done. thank your support team ZZKEY | |
10-07-2014, 12:34 | #23 (permalink) |
Member: 536992 Status: Offline Thanks Meter: 88 | Manual root: Connecting... Phone Detected. Reading Phone Info... Manufacturer: HUAWEI Model: HUAWEI G6-U10 Build ID: G6-U10V100R001C149B121 Flash Memory: EMMC ------------------------------------------------------------------------------------------ Linux version 3.4.0+ (android@localhost) (gcc version 4.7 (GCC) ) #1 SMP PREEMPT Wed May 14 18:02:16 IST 2014 ------------------------------------------------------------------------------------------ Checking root... OK! Initializing... ------------------------------------------------------------------------------------------ Imei: 8639640xxxxxxxxxx Serial: DU2MUJ145X0xxxxx ------------------------------------------------------------------------------------------ Reading Simlock Status... Simlock Status: Phone Locked. Creating Simlock Backup... Unlocking Phone... Unlock Done. Restarting Phone... Operation Done. |
The Following User Says Thank You to Serg5555 For This Useful Post: |
10-07-2014, 13:04 | #24 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Gsm World Age: 37
Member: 1157693 Status: Offline Thanks Meter: 122 | Connecting... Phone Detected. Reading Phone Info... Manufacturer: HUAWEI Model: HUAWEI Y530-U00 Build ID: Y530-U00V100R001C900B512 Flash Memory: EMMC ------------------------------------------------------------------------------------------ Linux version 3.4.0+ (android@localhost) (gcc version 4.7 (GCC) ) #1 SMP PREEMPT Mon Aug 11 18:52:35 IST 2014 ------------------------------------------------------------------------------------------ Hacking phone, please wait... Checking root... FAILED! (-202) Failed, Phone is not rooted. root phone first. Operation Done. |
10-07-2014, 13:47 | #25 (permalink) | |
Member: 166270 Status: Offline Sonork: 100.1579747 Thanks Meter: 12,673 | Hello bro, try with manual root, after unlock with zZKey. Best Regards zZ-Team Quote:
10-14-2014, 15:51 | #28 (permalink) |
Insane Poster Join Date: Feb 2009 Location: IR :(
Member: 973775 Status: Offline Thanks Meter: 7 | hi to zz after unlock but stil lockeed my phone say unlock sim block Connecting... Phone Detected. Reading Phone Info... Manufacturer: HUAWEI Model: G630-U20 Build ID: G630-U20V100R001C00B115 Flash Memory: EMMC ------------------------------------------------------------------------------------------ Linux version 3.4.0+ (android@localhost) (gcc version 4.7 (GCC) ) #1 SMP PREEMPT Fri May 16 11:08:42 CST 2014 ------------------------------------------------------------------------------------------ Checking root... OK! Initializing... ------------------------------------------------------------------------------------------ Serial: DU2NQA145W017806 ------------------------------------------------------------------------------------------ Reading Simlock Status... Simlock Status: Phone Locked. Creating Simlock Backup... Unlocking Phone... Unlock Done. Restarting Phone... Operation Done. |
10-14-2014, 15:54 | #29 (permalink) | |
Member: 166270 Status: Offline Sonork: 100.1579747 Thanks Meter: 12,673 | Select autodetection, and try again. Best Regards zZ-Team Quote:
