-   zZKey (http://forum.gsmhosting.com/vbb/f717/)
-   -   zZKey Huawei Advanced Tool 2.7.1.1 G6-Uxx, G630-Uxx (http://forum.gsmhosting.com/vbb/f717/zzkey-huawei-advanced-tool-2-7-1-1-g6-uxx-g630-uxx-1865172/)
elcapitel 10-03-2014 21:08
http://consumer.huawei.com/ucmf/grou...E/256664-3.jpg
Choose zZKey = Build Confidence + Increase Expertise
What's New:
* Fixed minor detail in Huawei G6-U** , G630-U** models with newest 2014 firmwares.
zZ Huawei Advanced Tool v2.7.1.1
Previous zZ Huawei Advanced Tool Updates:
zZKey Huawei Advanced Tool 2.7.1.0
What's New:
Huawei G6-U10 [Direct Unlock, Read Bootloader Code, Repair Simlock] All One Click , NOT ROOT NEEDED, WORLD FIRST
Huawei G6-U34 [Direct Unlock, Read Bootloader Code, Repair Simlock] All One Click , NOT ROOT NEEDED, WORLD FIRST
Huawei G6-U251 [Direct Unlock, Read Bootloader Code, Repair Simlock] All One Click , NOT ROOT NEEDED, WORLD FIRST
Huawei G6-L11 [Direct Unlock, Read Bootloader Code, Repair Simlock] All One Click , NOT ROOT NEEDED, WORLD FIRST
Huawei G6-L22 [Direct Unlock, Read Bootloader Code, Repair Simlock] All One Click , NOT ROOT NEEDED, WORLD FIRST
Huawei G6-L33 [Direct Unlock, Read Bootloader Code, Repair Simlock] All One Click , NOT ROOT NEEDED, WORLD FIRST
Huawei G630-U10 [Direct Unlock, Read Bootloader Code, Repair Simlock] All One Click , NOT ROOT NEEDED, WORLD FIRST
Huawei G630-U20 [Direct Unlock, Read Bootloader Code, Repair Simlock] All One Click , NOT ROOT NEEDED, WORLD FIRST
Huawei G630-U251 [Direct Unlock, Read Bootloader Code, Repair Simlock] All One Click , NOT ROOT NEEDED, WORLD FIRST
zZKey Huawei Advanced Tool 2.7.0.9
What's New:
Huawei G615-U10 [Direct Unlock, Read Bootloader Code, Repair Simlock] All One Click , NOT ROOT NEEDED, WORLD FIRST
Huawei Y336-A1 [Direct Unlock, Read Bootloader Code, Repair Simlock] All One Click , NOT ROOT NEEDED, WORLD FIRST
Huawei Y340-U081 [Direct Unlock, Read Bootloader Code, Repair Simlock] Beta Test
Huawei Y530-U00 [Direct Unlock, Read Bootloader Code, Repair Simlock] All One Click , NOT ROOT NEEDED, WORLD FIRST
Huawei Y530-U051 [Direct Unlock, Read Bootloader Code, Repair Simlock] All One Click , NOT ROOT NEEDED, WORLD FIRST
Huawei Y536-A1 [Direct Unlock, Read Bootloader Code, Repair Simlock] All One Click , NOT ROOT NEEDED, WORLD FIRST
Connecting...
Phone Detected.
Reading Phone Info...
Manufacturer: HUAWEI
Model: G630-U20
Build ID: G630-U20V100R001C00B117
Flash Memory: EMMC
Linux version 3.4.0+ ([email protected]) (gcc version 4.7 (GCC) ) #1 SMP PREEMPT Tue May 6 05:00:11 CST 2014
Checking root... OK!
Initializing...
Imei: 8642950xxxxxxxx
Serial: DU2NQA146C033xxx
Reading Simlock Status...
Simlock Status: Phone Locked.
Creating Simlock Backup...
Unlocking Phone...
Unlock Done.
Restarting Phone...
Operation Done.
Thanks to @Serg5555 for test report.
Best Regards
zZ-Team
brihan_05 10-04-2014 00:47
Connecting...
Phone Detected.
Model: HUAWEI G6-L33
Build ID: G6-L33V100R001C25B118
Flash Memory: EMMC
Linux version 3.4.0-g77ef605 (@pekeaulxd0013) (gcc version 4.7 (GCC) ) #1 SMP PREEMPT Wed May 14 19:47:51 CST 2014
Initializing...
Incorrect DE Phone Data.
Operation Done.
help please with this HUAWEI G6- L33
elcapitel 10-04-2014 01:09
Incorrect DE Phone Data. Means your phone was touched by some software.
Send us the backup please. We will check and try to help you.
Best Regards
zZ-Team
Originally Posted by brihan_05 (Post 10594540)
Connecting...
Phone Detected.
Flash Memory: EMMC
Initializing...
Operation Done.
Iron Eagle 10-04-2014 01:48
Wow...zZKey is really a reliable tool for the new generation.
brihan_05 10-04-2014 01:54
Best Regards
zZ-Team
Backup was sent via PM await your prompt response
thank you
Greetings
zz_coder 10-04-2014 03:20
Check that you have selected the right model on TAB (G6-L33). If was the case and dont luck it.
You should try selecting Autodetection.
If anyway dont luck show us both verbose logs and send us a backup maybe your phone was damaged by another tool.
Connecting...
Phone Detected.
Flash Memory: EMMC
Initializing...
Operation Done.
miguelshiro 10-04-2014 17:59
Please help
Connecting...
Phone Detected.
Flash Memory: EMMC
Initializing...
Operation Done.
elcapitel 10-04-2014 18:53
Read here @zz_coder post and my answer about G6-L33
Best Regards
zZ-Team
Originally Posted by miguelshiro (Post 10595775)
Connecting...
Phone Detected.
Flash Memory: EMMC
Initializing...
Operation Done.
miguelshiro 10-04-2014 19:07
Please help
Best Regards
zZ-Team
Backus
NOIMEI_android_fullback_04_10_2014_10_48_27 - Download - 4shared
elcapitel 10-04-2014 19:23
Thanks for backup, past us here the 2 operations logs,
1 in autodetection and 1 selecting Huawei Ascend G6-L33 (correct model)
Best Regards
zZ-Team
Originally Posted by miguelshiro (Post 10595852)
kakaomar 10-04-2014 21:59
cecsufly unlock g630-20
Connecting...
Phone Detected.
Model: G630-U20
Build ID: G630-U20V100R001C00B112
Flash Memory: EMMC
Linux version 3.4.0+ ([email protected]) (gcc version 4.7 (GCC) ) #1 SMP PREEMPT Mon Mar 31 03:31:07 CST 2014
Initializing...
Imei: 864295020287****
Serial: DU2NQA144N019582
Unlocking Phone...
Unlock Done.
Restarting Phone...
Operation Done.
omar
miguelshiro 10-05-2014 17:05
help please
Best Regards
zZ-Team
and is there any solution for my mistake
elcapitel 10-05-2014 17:14
Hermanito acabe de enviarnos 2 log de operaciones,
1 en autodetection y otro correctamente seleccionando el modelo. Sin esa info que le solicite desde ayer no podemos seguirle ayudando
Best Regards
zZ-Team
miguelshiro 10-05-2014 18:27
help please
Best Regards
zZ-Team
1-Autodetection
Connecting...
Phone Detected.
Flash Memory: EMMC
Initializing...
Serial: 4C2QNC1464037538
Unlocking Phone...
Unlock Done.
Restarting Phone...
Operation Done.
2-Seleccionando modelo exacto G6-L33
Connecting...
Phone Detected.
Flash Memory: EMMC
Initializing...
Operation Done.
Disculpa la demora es que el cliente avia llevado su equipo..
espero pronta respuesta
Saludos
miguelshiro 10-05-2014 18:41
Ya quedo full Liberado yaciel..muchas gracias.en el primer paso.
1-autodetection y unlock full 101% probado
Connecting...
Phone Detected.
Flash Memory: EMMC
Initializing...
Unlocking Phone...
Unlock Done.
Restarting Phone...
Operation Done
gracias
Page generated in 0.35355 seconds with 5 queries
