Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > zZKey
Old 10-03-2014, 21:08   #1 (permalink)
elcapitel's Avatar
Member: 166270
Sonork: 100.1579747
Thanks Meter: 12,669
Thumbs up zZKey Huawei Advanced Tool 2.7.1.1 G6-Uxx, G630-Uxx
Choose zZKey = Build Confidence + Increase Expertise
What's New:
* Fixed minor detail in Huawei G6-U** , G630-U** models with newest 2014 firmwares.
zZ Huawei Advanced Tool v2.7.1.1
Previous zZ Huawei Advanced Tool Updates:
zZKey Huawei Advanced Tool 2.7.1.0
What's New:
Huawei G6-U10 [Direct Unlock, Read Bootloader Code, Repair Simlock] All One Click , NOT ROOT NEEDED, WORLD FIRST
Huawei G6-U34 [Direct Unlock, Read Bootloader Code, Repair Simlock] All One Click , NOT ROOT NEEDED, WORLD FIRST
Huawei G6-U251 [Direct Unlock, Read Bootloader Code, Repair Simlock] All One Click , NOT ROOT NEEDED, WORLD FIRST
Huawei G6-L11 [Direct Unlock, Read Bootloader Code, Repair Simlock] All One Click , NOT ROOT NEEDED, WORLD FIRST
Huawei G6-L22 [Direct Unlock, Read Bootloader Code, Repair Simlock] All One Click , NOT ROOT NEEDED, WORLD FIRST
Huawei G6-L33 [Direct Unlock, Read Bootloader Code, Repair Simlock] All One Click , NOT ROOT NEEDED, WORLD FIRST
Huawei G630-U10 [Direct Unlock, Read Bootloader Code, Repair Simlock] All One Click , NOT ROOT NEEDED, WORLD FIRST
Huawei G630-U20 [Direct Unlock, Read Bootloader Code, Repair Simlock] All One Click , NOT ROOT NEEDED, WORLD FIRST
Huawei G630-U251 [Direct Unlock, Read Bootloader Code, Repair Simlock] All One Click , NOT ROOT NEEDED, WORLD FIRST
zZKey Huawei Advanced Tool 2.7.0.9
What's New:
Huawei G615-U10 [Direct Unlock, Read Bootloader Code, Repair Simlock] All One Click , NOT ROOT NEEDED, WORLD FIRST
Huawei Y336-A1 [Direct Unlock, Read Bootloader Code, Repair Simlock] All One Click , NOT ROOT NEEDED, WORLD FIRST
Huawei Y340-U081 [Direct Unlock, Read Bootloader Code, Repair Simlock] Beta Test
Huawei Y530-U00 [Direct Unlock, Read Bootloader Code, Repair Simlock] All One Click , NOT ROOT NEEDED, WORLD FIRST
Huawei Y530-U051 [Direct Unlock, Read Bootloader Code, Repair Simlock] All One Click , NOT ROOT NEEDED, WORLD FIRST
Huawei Y536-A1 [Direct Unlock, Read Bootloader Code, Repair Simlock] All One Click , NOT ROOT NEEDED, WORLD FIRST
Connecting...
Phone Detected.
Reading Phone Info...
Manufacturer: HUAWEI
Model: G630-U20
Build ID: G630-U20V100R001C00B117
Flash Memory: EMMC
Linux version 3.4.0+ ([email protected]) (gcc version 4.7 (GCC) ) #1 SMP PREEMPT Tue May 6 05:00:11 CST 2014
Checking root... OK!
Initializing...
Imei: 8642950xxxxxxxx
Serial: DU2NQA146C033xxx
Reading Simlock Status...
Simlock Status: Phone Locked.
Creating Simlock Backup...
Unlocking Phone...
Unlock Done.
Restarting Phone...
Operation Done.
Thanks to @Serg5555 for test report.
Best Regards
zZ-Team
The Following 40 Users Say Thank You to elcapitel For This Useful Post:
Old 10-04-2014, 00:47   #2 (permalink)
Crazy Poster
Member: 1577091
Sonork: 991259299
Thanks Meter: 6
Connecting...
Phone Detected.
Model: HUAWEI G6-L33
Build ID: G6-L33V100R001C25B118
Flash Memory: EMMC
Linux version 3.4.0-g77ef605 (@pekeaulxd0013) (gcc version 4.7 (GCC) ) #1 SMP PREEMPT Wed May 14 19:47:51 CST 2014
Initializing...
Incorrect DE Phone Data.
Operation Done.
help please with this HUAWEI G6- L33
Old 10-04-2014, 01:09   #3 (permalink)
elcapitel's Avatar
Member: 166270
Sonork: 100.1579747
Incorrect DE Phone Data. Means your phone was touched by some software.
Send us the backup please. We will check and try to help you.
Best Regards
zZ-Team
Originally Posted by brihan_05 View Post
Connecting...
Phone Detected.
Flash Memory: EMMC
Initializing...
Operation Done.
Old 10-04-2014, 01:48   #4 (permalink)
Member: 477490
Thanks Meter: 74
Wow...zZKey is really a reliable tool for the new generation.
Old 10-04-2014, 01:54   #5 (permalink)
Crazy Poster
Member: 1577091
Sonork: 991259299
Thanks Meter: 6
Best Regards
zZ-Team
Backup was sent via PM await your prompt response
thank you
Greetings
Old 10-04-2014, 03:20   #6 (permalink)
zz_coder's Avatar
Member: 1639385
Sonork: 100.1594605
Thanks Meter: 212
Check that you have selected the right model on TAB (G6-L33). If was the case and dont luck it.
You should try selecting Autodetection.
If anyway dont luck show us both verbose logs and send us a backup maybe your phone was damaged by another tool.
Connecting...
Phone Detected.
Flash Memory: EMMC
Initializing...
Operation Done.
Old 10-04-2014, 17:59   #7 (permalink)
Member: 798175
Sonork: 100.1645708
Thanks Meter: 26
Exclamation Please help
Connecting...
Phone Detected.
Flash Memory: EMMC
Initializing...
Operation Done.
Old 10-04-2014, 18:53   #8 (permalink)
elcapitel's Avatar
Member: 166270
Sonork: 100.1579747
Read here @zz_coder post and my answer about G6-L33
Best Regards
zZ-Team
Originally Posted by miguelshiro View Post
Connecting...
Phone Detected.
Flash Memory: EMMC
Initializing...
Operation Done.
Old 10-04-2014, 19:07   #9 (permalink)
Member: 798175
Sonork: 100.1645708
Thanks Meter: 26
Best Regards
zZ-Team
Backus
NOIMEI_android_fullback_04_10_2014_10_48_27 - Download - 4shared
Old 10-04-2014, 19:23   #10 (permalink)
elcapitel's Avatar
Member: 166270
Sonork: 100.1579747
Thanks for backup, past us here the 2 operations logs,
1 in autodetection and 1 selecting Huawei Ascend G6-L33 (correct model)
Best Regards
zZ-Team
Old 10-04-2014, 21:59   #11 (permalink)
kakaomar's Avatar
Member: 708305
Thanks Meter: 260
cecsufly unlock g630-20
Connecting...
Phone Detected.
Model: G630-U20
Build ID: G630-U20V100R001C00B112
Flash Memory: EMMC
Linux version 3.4.0+ ([email protected]) (gcc version 4.7 (GCC) ) #1 SMP PREEMPT Mon Mar 31 03:31:07 CST 2014
Initializing...
Imei: 864295020287****
Serial: DU2NQA144N019582
Unlocking Phone...
Unlock Done.
Restarting Phone...
Operation Done.
omar
The Following User Says Thank You to kakaomar For This Useful Post:
Old 10-05-2014, 17:05   #12 (permalink)
Member: 798175
Sonork: 100.1645708
Thanks Meter: 26
help please
Best Regards
zZ-Team
and is there any solution for my mistake
Old 10-05-2014, 17:14   #13 (permalink)
elcapitel's Avatar
Member: 166270
Sonork: 100.1579747
Hermanito acabe de enviarnos 2 log de operaciones,
1 en autodetection y otro correctamente seleccionando el modelo. Sin esa info que le solicite desde ayer no podemos seguirle ayudando
Best Regards
zZ-Team
The Following User Says Thank You to elcapitel For This Useful Post:
Old 10-05-2014, 18:27   #14 (permalink)
Member: 798175
Sonork: 100.1645708
Thanks Meter: 26
Question help please
Best Regards
zZ-Team
1-Autodetection
Connecting...
Phone Detected.
Flash Memory: EMMC
Initializing...
Serial: 4C2QNC1464037538
Unlocking Phone...
Unlock Done.
Restarting Phone...
Operation Done.
2-Seleccionando modelo exacto G6-L33
Connecting...
Phone Detected.
Flash Memory: EMMC
Initializing...
Operation Done.
Disculpa la demora es que el cliente avia llevado su equipo..
espero pronta respuesta
Saludos
Old 10-05-2014, 18:41   #15 (permalink)
Member: 798175
Sonork: 100.1645708
Thanks Meter: 26
Ya quedo full Liberado yaciel..muchas gracias.en el primer paso.
1-autodetection y unlock full 101% probado
Connecting...
Phone Detected.
Flash Memory: EMMC
Initializing...
Unlocking Phone...
Unlock Done.
Restarting Phone...
Operation Done
gracias
Page generated in 0.47886 seconds with 8 queries
